I have a 19? Dell Flat Screen TV that is about a year and a half old. A couple nights ago it just randomly cut off on its own. Last night it did it a few more times. And I even noticed in the middle of the night that it would make weird noises (while it was off) like it was trying to connect or cut on and it couldn't connect. The noise sort of sounded like it was coming from the speakers and it was a loud noise. The only thing I have the TV hooked up to is the cable and the actual outlet. I made sure all of the plugs were plugged in tight, and even tried plugging the TV into a different power outlet last night and that did not resolve the problem. After being woken up in the middle of the night by the loud noises the TV was making (while it was off) I just decided to unplug the TV all together and I have not plugged it back up since. Do you have any idea what could be causing my TV to automatically shut down on its own? And do you have an y suggestions as to what I may be able to do to fix the problem? Thank you, Lindsay
SOURCE: Dell no sound
I got this solution from an apprentice on the site, try it out.
http://www.fixya.com/support/t577255-dell_w3201c_no_sound_after_two_years
SOURCE: No Power in Monitor
If you are a tech. Check the voltages going to the Logic Board, if one is missing (12 or 5v. Then that is most likely due a an IC failure on the power supply board. IC 901 Don't quote me on this, but I know it is less than $10. Sorry, I only have 1 left, the last one I did was in Aug2006 so memory is fuzzy. Kegtapper
SOURCE: static noise
Check for the Third earth wire of your computer else check for the motherboard taking earth for the cabinet. Good luck
SOURCE: dell 32' lcd
I tried this and went from no sound to a popping noise that does not adjust with the volume switch. It is either on or off.
Is there anywhere we can a replacement for this???
SOURCE: DELL TV 32" LCD TV
the problem is the audio amp board has been fried. It needs to be replaced. This will restore the actual sound transfer to and from the speakers.
My tv cuts off every 15 minutes or so. After awhile it cuts off every time you turn it on. HELP!!!!
The t.v. I have is a sylvania and it cuts off about every five to fifthteen minuates. .. why is that?
Same problem. The tv cuts off for no reason. It has gotten so bad the tv is virtually unuseable. Has anyone figured out what causes this or how to fix it?
