Question about Saws
How do i change the blade on craftsman circular saw?
How do i stop the blade or engage the brake?
    Sergeant:
  • 359 Answers
Some saws don't have a blade brake , i always take a pair of vise grips and adjust to grip blade tightly and hold or bind against housing then remove bolts works well for me
Posted on Jan 02, 2009
Bolt that holds blade well not loosen what is the correct direction to loosen bolt
Remember that on a circular saw, the bolts are typically left-handed thread so it is the opposite of a typical bolt. This is because the blade spins to the right so if a normal bolt was used it would loosen as the saw operates.
Jul 19, 2011 | Sears Craftsman 7-1/4 in. Circular Saw...
My Craftsman 7&1/4 inch 12 amp Circular Saw(Model 315.108330) slips while cutting. The motor keeps spinning but the saw stops rotating. Can I Fix it?
Most circular 7-1/4 saws have a bolt and a compression washer that acts as a brake shoe that holds the blade secure but under dire circumstances will allow the blade to slip some rather than hold the motor shaft and allow burn out. The compression washer under your bolt has become worn and doesn't grip the blade securely. You can find a split washer that will fit under the blade and give you some more friction, or go to sears and order another compression washer for your saw.In the Sears Parts List found at: http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Saw-Parts/Model-32018780/0247/0744410/50035950/00001?blt=06&prst=&shdMod=
see part no. 44
Feb 23, 2011 | Craftsman Evolv 12 Amp 7-in Circular Saw -...
Cannot tighten blade on old craftsman circular saw.bolt turns blade shaft and motor without tighting blade
Is the washer/spacer in the blade too thick and you are perhaps tightening up on that instead of the blade. Also check the threads on the bolt, see if the bolt turns all the way in without the blade in position. It may be jamming up before gripping the blade.
Jan 24, 2011 | Sears Craftsman 7-1/4 in. Circular Saw...
How do I change the blade
Isn't there a lock mechanism on the saw?
Engage that and wrench off & then on.
Be sure blade arrow direction is correct.
PS You're not the sharpest blade in the pack----are you?
Dec 30, 2010 | Craftsman 7-1/4" Circular Saw Blade Pack
How to engage spindle lock?
The spindle lock should be a short rod that sticks out on the motor side of the saw. Push this in and rotate the blade until the rod pushes in and locks the spindle. This will hold it tight so you can use a wrench on the nut that holds the blade on.
Sep 10, 2010 | Craftsman 13 Amp 714" Circular Saw
Craftsman circluar saw blade replacement
There's a small hole in the blade. Insert a nail or screwdriver through the hole and tutn blade until it stops. Ypu can also use a piece of wood place in one the blade teeth and turned until it stops at the show plate.
May 16, 2010 | Craftsman 10871 13 amp Corded 714"...
Can not remove the old blade
1. Unplug the saw.
2. Locate the blade lock button used to lock the motor shaft when changing a blade. For your saw, this button is usually located on the left side of the blade guard somewhere around the motor housing.
3. Push the button while rotating the blade until the button engages and the blade will no longer turn.
4. Use the wrench that came with the saw (or another wrench) to loosen and remove the blade bolt. For your saw the bolt should have standard right hand threads which means you loosen the bolt by turning it counter clock-wise.
5. Remove the old blade and replace it with a new blade of the same mounting type. Some blades have a round through hole and some blades have a diamond through hole.
6. Re-install the blade bolt and tighten clock-wise while holding the blade lock button down.
Oct 03, 2009 | Sears Craftsman 7-1/4 in. Circular Saw...
Craftsman # 315,10851 7 1/4 inch circular saw.
In the past I have clamped a pair of vice grips on the old blade so I could remove the bolt from the arbor.
Sep 12, 2009 | Saws
Changing circular saw blade
near the guard should be a button u hold and rotate blade(unplug first)until it locks, some old and cheap saws have no lock pin, so lock blade with vise grips and let rest against base plate and loosen nut.
Jul 16, 2009 | Saws
My 7 1/4 in Craftsman circular saw stops running.
Is there anything jammed between the blade and the body/guard of the saw?
Jun 26, 2009 | Sears Craftsman 7-1/4 in. Circular Saw...
Saws Logo
2,261 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
