Question about Panasonic KX-FL511 Plain Paper Laser Fax
Printer won't print
I have a new computer, and the printer is also about 4 mts old. It worked fine with old computer, but with the new one, when I try to print it has a box that drops down and says printer subject. And a place to write, I don't know how to get past that, or what should be in the box, I have tried subject, "prn" and other things and it will not print, computer shows printer is connected and says printer is ready, it just won't print. Thanks mcanni_99@yahoo.com
Cannot get my printer to print
Posted on Jan 04, 2009
Printer shows Invalid Cartridge but it is not?
I ran into the same problem with the same printer. At first I was able to take it out and turn of the printer. Put the toner cartridge back in and it would work fine. But recently, so such luck, ended up buying a new toner cartridge and works great. Slightly disappointed as the old toner is 3/4 full but its also very old and has been in the computer since purchase date. I notices when I took the old toner out I could smell the ink like it was almost burnt. If changing cartridge doesn't work I recommend a HP. I only use this printer for bulk prints but my HP for everything else. HP is the way to go....
Mar 12, 2012 | Dell 2335dn Multifunction Laser Printer
I just purchased a Kodak printer to print my digital pictures. When I try to look at the pictures wheather the memory chip is in the camera or directly in the printer it will only read 46 of the 200 or -...
If that's the case try connecting the the camera to your computer then print all the pictures then format your memory chip to make sure this is not a problem with the memory chip...
Hope that helps.......
Aug 21, 2008 | Fuji Cameras
HPC3180 PhotoSmart printer - works great - I use brand X ink cartridges, and they work fine. But I just formatted my computer and downloaded the latest HP driver and software. My printer just ran out of...
Not Familiar with brand "X".. Know about brand "X" washing powder anmd "DAZ". I take it is not the same.
OH! I hate the words "Just Formatted My Computer". Ypou have actual answered your own question, please please say you have the "OLD PRINTER PROG" or a copy lurking on a long forgotten copy CD?
Yes! it will be trial and error, reload the old version of your printer. New updates sometimes leave out differant suppliers and their progs, infact they may have fallen out, we will never know.
As a matter of interest, reinsert the old cartridge and see if it sees that though empty, then if fails to see that you have your answer.
Were's is "WV" I'm in the UK. Hope all works?
May 12, 2011 | HP Photosmart C3180 All-In-One InkJet...
New printer. HARDLY USED Worked fine when first installed. . Now shows as offline on all five network printers. Ethernet connection. Power is on. Tried rebooting, Checked connections. Is the printer...
1. Try to print from local system if it does not then reinstall printer driver. check catridges.
2. Now right click on the printer using sharing options, share it again.
3. On the other computers using network icon, browse the printer connected system. Explore the system till you see the shared printer and double click it. It will take 2 to 5 Minutes and then your printer is network connected.
4. Now remove the old printer icons. And check printing using the new one.
Sep 11, 2010 | HP OfficeJet Pro K8600 Printer
Tvalue 4 for windows will not print with a new printer
This is a work around as I have the same problem. If I change the default printer to something other then the HP printer, then select Page Setup, I can then select the HP without the program erroring out. You can even set the HP back to default and TValue will continue to work fine until you restart the computer.
Feb 06, 2009 | TimeValue Software TValue 4.0 for PC
Can't print to old applications
The issue your having is with the Operating system compatability. The HP 3055 is compatible with 98, ME, XP, Window 2000 and forward. It won't do windows 3.1 or 95 well even if your computer will, the disconnect comes when the software is sending old print commands to a new style print driver.
Your best hope is to download and install the HP Printdriver for Windows 98 and try it as it's the most tolerant of old gear. Download the PCL 5 as the PCL6 is too new and probably not going to work.
As an alternate try to download each of the printdrivers for the differnt era windows and try them. It's a hard problem that may not have a solution other than upgrading the accounting software.
If it's simply a connection problem, they do make a USB to Parallel addaptor which may help you with the physical connection issue.
Here's a link:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=1140780&taskId=135&prodTypeId=18972&prodSeriesId=1161389&submit.y=4&submit.x=3&lang=en&cc=us
Hope that helps you.
Aug 24, 2008 | HP LaserJet 3055 All-In-One Printer
Vista with IE7
why dont u check HP deskjet website for printer driver update? may be its avaible there.
May 29, 2008 | HP DeskJet 5650 InkJet Printer
Vista
Have you tried turning off your firewall?
That may be the issue.
FIrewalls will block printers. Can you ping the printer and not print to it?
Feb 12, 2008 | Office Equipment & Supplies
Does not print text
Hey there thedeligirl,
It does sound like hardware problem. If the hardware is 4 yrs old, and the people at Epson recommend you go with a new printer, then it may be time to head to wal-mart =).
The only thing I could suggest, is run some kind of calibration, or "clean headers" option on the printer.
Dec 08, 2007 | Epson Stylus Photo R300 InkJet Printer
HP 1350V all-in-one
Hi, You need to get a new ink cartridge. It is really not recommended to refill ink cartridges but if you do then it is advisable not to exceed 3 times because it could damage the printer head. If the new inks still gives error, then your printer head may need to be checked to see if it needs replacing. Good luck!
May 25, 2007 | HP PSC 1350v All-In-One InkJet Printer
Panasonic KX-FL511 Plain Paper Laser Fax Logo
60 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
