Question about Acer Aspire 3610 Notebook
AC Adapter One day, my charger seemed to have simply become very touchy. It had to be in a particular angle just to charge my computer. After about a week of this, the whole thing ceased to work. The light on the charger comes on, however when plugged into the computer, it doesn't read. It won't turn on, nor does the charging light come on. Do I need a new charger, or is something wrong with the notebook?
  • Acer Master
  • 32,281 Answers
Hi Kayla,
It is most likely the power connector on the laptop is faulty and the power adapter is not making electrical connection with the laptop.
You stated that by moving the touchy power plug that you could get it to charge, this is proof that you have a faulty power input connector on the laptop.
Check the power adapter's laptop connector with a multimeter, if there is voltage at the connector then the adapter is OK, the voltage reading should be as stated on the label or slightly higher.
You may be able to get the power connector repaired (it may need resoldering because of a dry joint) or it may need to be replaced.
Posted on Jan 03, 2009
I would like to charge my 930 T on 120 volt A C adapter
Complete Guide to Using the Correct Charger or Power ...
www.groovypost.com/.../choose-right-power-adapter-charger-phone-lap...
Oct 18, 2015 - Read this guide on finding the right charger or power adapter. ... As part of that process, I took all my power supplies and adapters and threw them into a box. ...from a 120 V AC outlet in your home) and convert it to a specific DC output. ... Voltage is measured in volts (V) and current is measured in amps (A).
Is there a way to charge my 930 T on a wall socket AC adapter
www.fixya.com/.../t26037021-way_charge_930_t_wall_socket_ac_adap...
24 mins ago - is there a way to charge my 930 T on a wall socket AC adapter - PC Laptops ... I would like to charge my 930 T on 120 volt A C adapter. Jan 03 ...
AC versus DC charging - what is the difference? ' Plug In ...
www.pluginamerica.org > Blogs > Drivers Seat
Plug In AmericaOct 13, 2013 - It is simply a USB cable, which allows my tablet to charge from a DC USB ... When you plug in to AC power - whether you plug in to a 120V or .... 120vphone chargers and plugging in to 74 volts DC and charging their phones.
Jan 03, 2016 | Computers & Internet
Hi there.I ve got this strange problem with my satelite Toshiba A200 1AB laptop.the problem is with the battery actually it wont charge when I plug in the charger with battery in it.But when I extract the...
Is the AC Power adapter the original adapter of the laptop? If it is, try to drain the battery and charge it for 8-12 hours without using or opening the laptop just charge it. After charging, remove the power adapter as you open your laptop. Make this way a habbit of using and charging your laptop to make the charging and battery life last long.
Mar 11, 2011 | Amstron Toshiba Satellite A200-1AB Laptop...
How do i charge my camera?
You can charge the Olympus Tough 3000 / Stylus Tough 3000 by both AC adapter wall plug and via USB using your computer.
Please let me know if I can assist you further.
Regards,
KYTechnology
Mar 01, 2011 | Olympus ? Tough 3000 / Stylus Tough 3000...
Acer Aspire 5520 Power Problems! :(
1. Actually the problem is not with the charger / adapter!
2. The plug-in port / jack of the laptop has become loose.
3. Don't try to work out the charging by adjusting the adapter plug with different angles. It will just damage the plug-in port (the wire inside the port will become loose and unaligned)!
4. Contact the Acer authorised service center for repair / replacement of that plug-in port / jack in the laptop! It'll just cost some bucks!
please rate this advice if it helps....tc! :)
Jan 14, 2010 | Acer Aspire 5520-5156 Laptop
Hi,my nokia n95 wont hold charge i have a new battery and new software,do you know what the problem could be,also when it charges it doenst cut out when it is charging it just keeps charging,thank you
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Dear user,
Such issue may appear when Nokia charger adapter CA-146C is used with incompatible charger to charge Nokia N97. Currently compatible chargers for N97 with CA-146C are Nokia Travel Charger AC-4 and Nokia Compact Travel Charger AC-5.
Spangley, just plug it into your PC. If your battery needs charging, it will charge slowly simply while being connected to your computer. Nothing else to do!
Goodluck :)
Dec 11, 2009 | Nokia N95 Cellular Phone
Gateway MX8738 power adapter problem
Does the DC jack on the laptop wiggle or feel loose?
If that's the case then eventually the jack will go bad will have to be replaced. Most computer shops charger around 60-100 for the repair.
If it's the charger itself then just replace it with an ORIGINAL from eBay.
Hope this info helps and if you need more specifics just let me know.
--RescueTechLA
Nov 29, 2009 | Gateway MX8738 Notebook
HP iPAQ doesn't turn on
Failed battery pack most likely.
Jul 11, 2017 | HP iPAQ hw6510 Smartphone
Acer Aspire 3610 Notebook Logo
99 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
