Question about Garmin nuvi 200W GPS Receiver
What size SD card do I need for the 2009 update?
Garnim 200W
What ever size fits daaaaaaaaaaaa
Posted on Jan 03, 2009
Bought life time map update for my nuvi 200W. download tells me I'm lacking 459MB. I took every thing off that I can think of and cleared my personal settings. still lacking 459MB. bought 8 GB sdnc...
The reason that the download is telling you that you're short of space when you have the memory card in is that it's trying to download to the satnav rather than the memory card. The solution to this problem is at http://www.fixya.com/support/r5628920-update_garmin_satnav_maps There may be more information there than you need but everything you could need to ask about updating maps is there including how to get the map onto your memory card.
You will probably have problems getting the satnav to recognise the 8 Gb memory card. The smaller and slower the card is the better chance you have but unfortunately older satnavs like the 200w is hit and miss. I have got some of them to work with SD cards while others just will not.
Dec 23, 2010 | Garmin nuvi 200W GPS Receiver
I purchase the lifetime updates for my Nuvi 200W GPS and now it will not allow me to download any updates on to it due to not enough memory. What can I do. I am pretty upset because I spent the money for...
Unfortunately the garmin 200W, like most of the garmin satnavs, doesn't have much storage space so you should be given the option to download part of the map only to your satnav. To get the full map the only option is to download the map to your computer. When you go to download the map from the garmin website select OPTIONS. In the options menu select download to computer. This installs a program called Mapinstall on your computer which contains the map. If you need to use more of the map you can then either replace the part installed on your satnav by running the mapinstall program from your computer or install it to an SD card. Note however that while garmin say that nuvi satnavs support SD cards up to 16 Gb some cards don't seem to work in them. Before spending all the time it takes to put your map on the card test it in your satnav first by putting music or pictures on it to see if it works
Sep 03, 2010 | Garmin nuvi 200W GPS Receiver
Need a sd card or cable to load 2009 maps i only have the gps and the 12 volt cable how and what do i need to update my maps
Hi;
Any local electronics store can sell you the USB cable - make sure you get the mini-size connector on the end for your GPS (take the GPS into the store to be certain). The go to garmin.com and see what you want to purchase.
But - BEWARE! The garmin.com site will be glad to sell you map updates (for a ridiculously high price) that might not fit. Might be better off buying the maps on an SD card. I'm struggling right now with the Lifetime NA update for the nuvi 200W; can't get the entire map to fit, even though the original map purchased with the unit in Jan 2008 had all of NA. (can anyone help with this? I've tried all the obvious - deleting waypoints, languages, updating firmware, etc. Really bugs me!
Raargh
Jun 17, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi 200w can't update all 49 lower states
OK, I just finally am getting through all of this myself.
First, the bad news. You cannot load all of the lower 49 states onto your Garmin 200W as-is. The map file is over 1GB and the 200W only has 991MBs of memory.
So, go out and get yourself a SD card. I got a 2GB card at OfficeDepot for $8. It was at the counter, not back with the other cards they carry (Note: The speed showed as 60x. The slightly more expensive ones, $12-$15, may be faster, like 150x.)
You'll also need to get yourself MapInstall, available from the Garmin site. BUT, don't try to use this right away, a mistake I made. If you do, you basically get a message that MapInstall can't be installed because it's not already installed. Seriously.
BUT, MapInstall GETS installed, or whatever, when you load your 2010 maps (or partial maps), so after you do your partial install, THEN you can install the MapInstall program. (May not be necessary, but remember, I did this out of order. Look for a "Garmin" folder under your Programs, or All Programs, and see if it's already there after you install your 2010 maps.)
Next, run MapInstall. The next mistake I made was that at the window where it finds your device, I clicked on the NEXT button. DON'T. Notice that your device is shown in a drop-down box. Click on that, and you can select your SD card for the destination.
THEN click NEXT. On my system, it appears as if it shows you what IS already on the 200W, and lets you select whatever you want to add. I put everything else available on the SD card.
I just this minute finished loading "the rest" and checked it out. Works flawlessly. I easily found a seafood restaraunt in Anchorage (Alaska was not loaded in the intitial install.)
Just remember that you have to keep the SD card in the Garmin at all times to use those maps. That really shouldn't be a problem though.
Hope this helps eveyone.
JDCrownover
Huntsville, AL
Apr 29, 2009 | Garmin nuvi 200W GPS Receiver
Not enough space for maps?
The garmin does not have any space on it for maps,any additional maps are stored on a memory
card. I don't see where garmin says the size limit of the card but in most cases unless it says
SDHC memory card,then the max is a 2g sd card, I think the models 500 and over can use over a 2g card.,
Mar 27, 2009 | Garmin nuvi 200W GPS Receiver
How do youcess your sd card on the garmin nuvi 200w series please
i lost my card for my garmin nuvi 200w series do i really need it
Mar 21, 2009 | Garmin nuvi 200W GPS Receiver
City Navigator Lower 48 States NT 2009
Hello parteeboy24,
The on board memory in your Nuvi 200 may not have enough free space to hold the map. You may be able to free up some space by deleting maps or language packs that you don't use. (Be careful to back up any files you are going to delete.) Or you can add an optional SD memory card to the unit to increase the storage capacity on the GPS.
Best Regards,
Ken
"Go Ahead. Use Us."
Jun 30, 2008 | Garmin nuvi 200W GPS Receiver
WHAT IS SD CARD FOR??
Hello TRICOUNTY,
Your Garmin GPS has an SD card slot. You can use this slot to insert a removeable SD memory card into the unit SD memory cards for used for storage by many portable devices. The most common useage for the GPS is to view pictures taken by a digital camera (which also uses an SD card) with the GPS's picture viewer function.
I am not sure what the ads you are referring to are. Where are you seeing the ads? On the GPS screen? After inserting a SD card into the GPS?
Best Regards,
Ken
"Go Ahead. Use Us."
Jun 22, 2008 | Garmin nuvi 200W GPS Receiver
Garmin Nuvi 200W SD card Problem
The problem is that the US 2008NT map takes up about 900MB, the update itself will push that up to 947MB. The Nuvi 200w has an internal memory of 1GB, the Help folder takes about 35MB and the text and speech files for all those other languages that you don't use or understand takes up about 30MB. So if you add all those up you come up with more than 1GB, and the SD card cannot be used for the US mapset (preloaded). It can only be used for additional map sets that you want to add like Europe, Mexico, Australia etc etc. So how do you update? Well you are going to have to decide if you really need all those extra voice and text languages such as Aafrikans, German, Spanish etc etc. If not, get rid of them. Also consider getting rid of the Help Folder since it's actually pretty useless, but I leave that up to you to decide.
Now for 3-belmont-E, your friends and yourself should have realized that the Garmin units read SD, not SD-HC which are different. When you got the 1GB SD card, it should come up as another drive. It will not show up as a folder on the Garmin unit itself, for example....
Your main drive is C: and your CD/DVD is D:, when you plug in the Garmin it becomes E: but if you have an SD card that will become F: so in reality your Garmin device will now be E and F, with F being the SD card. This is of course if the SD reader in the unit did not get damaged by you guys putting in the SD-HC card into it.
Jun 03, 2008 | Garmin nuvi 200W GPS Receiver
Nuvi 200w map download and sd card
Guys and or ladies... I know that you have to create a folder named "GARMIN" in the sd card so the maps can be recognize. Maybe this solves your problem. Let me know if it works.
BR from Spain,
Carla
May 11, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi 200W GPS Receiver Logo
48 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
