Question about Canon ZR70MC Mini DV Digital Camcorder
Machine just shut off when opening the cassette door. Locked up!!
I plugged the charging cord into the machine to recharge the battery. The next morning with the battery indicator light showing full charge, I tried to open the cassette door to put in a tape for recording. The door came open and the cassette dock opened about half way and then stopped, locking up (freezing) the entire camcorder. No power, no viewing, nothing. Any suggestions?
  • 883 Answers
Look for a tiny pinhole and insert a pin while powered up to reset the device
Posted on May 27, 2007
2006 325i dead battery no key trunk and hood locked. how to open car
If the battery is under the back seat like some models, charge battery.
Jun 20, 2016 | BMW 325i Cars & Trucks
Error code
I believe this means that there is condensation in the tape mechanism.
Apr 06, 2008 | Sony Handycam DCR-HC14E Mini DV Digital...
The cassette compartment on my sony handycam won't retract!
Take out the battery and the AC cord.
Turn the camera on (tape, memory, edit settings) for 15 seconds.
Turn camera to off setting.
Plug battery or AC cord back in.
After doing this, my camera accepted the tape - door stayed shut and tape descended into the camera.
Sep 07, 2009 | Panasonic NV-GS15 Mini DV Digital...
Sony TRV530 has cassette holder stuck half way out
Thats an interruption of the ejection process, either you push it, you were on low battery, the energy was interrupted or you leave the camera in a car and th heat/cold affects it. Try to cheat/reset the camera system: Remove the clock cell, remove the battery or ac/cord at the same time you push the eject button once. Wait for an hour. Place the clock battery. Connect the AC/Charger cord or the battery (it MUST be completely charged). The camera will reset, check out and complete the ejection.
Jun 24, 2009 | Sony Handycam DCR-TRV530 Digital Camcorder
I'm having difficulty putting a charge on the battery on my panasonic ag 188...the battery hasn't been used in years. Some change is happening when I charge the batt onboard the camera (plugged into the...
I had the same problem. I hope you have a battery charger. The many older batteries I have needed charging, but they wouldn't hold a charge when I tried to charge them with the battery charger. My batteries were the kind that had a memory, and I guess that the battery memories are dead. So, I saw that I had a double ended power cord that came with my camera. I took the battery out of the camera and saw a power-in hole. I just tried connecting the double ended power cord to the camera and to a power hole I found on the battery charger. It worked and gave power to the camera. It did not explode. I could not find a manual on any of the many websites. I think that the camera I bought (Panasonic Palmcorder IQ PV-IQ403) doesn't exist in the available manuals. Maybe you can find a double ended power cord and a battery charger on line or in a store.
The following information might be useful to others. The camera cassette door will not open without having the power on to the camera. The camera connects to a TV with RCA cords.
My camera power switch has 2 settings. Use the camera setting to use the camera to record and see what you are recording displayed on the TV. You must change the power switch to the VCR setting in order to play back the recording and see it on the TV. Change the switch back again to use the camera. (You can also see the playback through the viewfinder.)
My camera has a remote control which is stored in a slot. I found that the battery is in a tiny sliding door. I had to use a screwdriver to gently dislodge it from the case, my fingernail was not strong enough. The movable tab had to be pushed inward to release the catch. The coin battery was not corroded. (CR-2025)
In order to play a VHS-C tape, you must have a VHS PlayPak. The cassette door will not open unless you have a battery loaded into the cassette. When the door opens, you can insert the VHS-C tape into the opening. The VHS PlayPak holder is the same size as a regular VHS tape. It can be found on-line.
May 17, 2009 | Panasonic AG-188 Camcorder
Maytag washer MAH 5500b FL code and door will not unlock.
Open the detergent dispenser door on top of mach. There you will find a small yellow nylon cord, pull on the cord and the door should open
Feb 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
BATTERY (Li Ion) NOT RECHARGING
in the case of my T23 laptop. when i plug in the ac adapter the battery will charge but when i turn on the power button. It won't boot and will shut off eventually. cant you help me with this
Nov 08, 2008 | IBM ThinkPad T23 2647 Notebook
Compaq Presario needed a new battery was installed labtop will not charge up!
When you install a new battery and remove a battery always make sure the laptop is completely shut off and have the power cord removed so that you avoid any possible power surge.
Batteries generally don't last much longer than a year and I have found removing the power cord or battery when it is off to be a good practice.
Before you charge a battery make sure it is run most all the way down. Recharging a battery when it is not run down can give it a memory and you may only be able to charge it up to the point you started charging it.
Anyway, if the computer won't charge a new battery then you could have a bad motherboard. To be sure try another battery.
Sep 09, 2008 | Compaq Presario Notebook
Mah9700AWW maytag washer dooer is locked
unsrew the lid to soap dispenser and search for the cord , you probably have a bad wax motor(lock motor)
May 15, 2008 | Maytag Neptune MAH5500B Front Load Washer
Canon ZR70MC Mini DV Digital Camcorder Logo
206 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
