Question about Kenmore 15899 Built-in Dishwasher
"Lock-on" light flashing
Kenmore dishwasher, Model # 665.17777990, Serial # FK2418301. Turned on before I went to bed. Got up to the "Lock-On" light flashing. We've tried holding down the "No Heat Dry" pad, as instructed, but that does not work. Any help appreciated. Thanks!
  • Anonymous Mar 18, 2014
    controls locked and holding heated dry for 4 seconds as the instructions say doesn't reset it. Locked light just flashes then stays on solid.
  • 530 Answers
Heated dry and normal toggle untill all lights light up then turn unit off. try that
Posted on Jan 05, 2009
How to program the safety lock on and off model 66517039402
From Page 15 of the complete owners manual available here:
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0409033.pdf
Lock On
Use the Lock On to prevent unintended use of the dishwasher.
You can also use the lock feature to prevent unintended cycle or
option changes during a cycle.
When LOCK ON is lit, all buttons are disabled.
NOTE: The dishwasher door can be opened while the controls
are locked. However, the lock must be turned off and the Start/
Resume button pressed to resume the cycle.
To turn on the Lock
Press and hold HEATED DRY for 4 seconds. LOCK ON glows.
If you press any pad while your dishwasher is locked, the light
flashes 3 times.
To turn off the Lock
Press and hold HEATED DRY for 4 seconds. The light turns off.
Sep 24, 2015 | Kenmore Dishwashers
Old dishwasher, lock on light blinks all time
Is this a Kenmore? If so here is Searspartsdirect. User and installation manuals, parts diagrams and parts lists and repair help.
KENMORE Dishwasher Parts Model 66515817990
Oct 26, 2014 | Kenmore Dishwashers
Kenmore Ultrawash dishwasher Model 665 15810000. Originally "water heating" light was flashing and no water in dishwasher. Replaced water inlet valve. Turned power back on, normal wash light goes on...
lock light is locking the panel push this child lock button for 3 sec and see if it un locks . then try it again .. may have a pannel out. mm
Dec 06, 2009 | Washing Machines
Kenmore dishwasher ultra was quiet guard 3 model 56516012403 control panel will not activate red lights blinking on normal wash and cancel drain. did the hold the heat dry button then the normal wash...
that would be model # 66516012403 correct??
you may have inadvertently set the lock on function..
check this out from your manual...
Lock On
between cycles. You can also use the lock feature to prevent
unintended cycle or option changes during a cycle.
To turn on the Lock
flashes 3 times.
NOTE: If the Heated Dry option is selected, the light will
temporarily turn off until Lock On glows.
hope this helps,
best of luck,
ttfn
Oct 25, 2009 | Kenmore 15912 Built-in Dishwasher
Kenmore dishwasher 665 Lock on light
You may have a stuck button as this will cause flashing of lights, try pushing button and see if it returns if not strike lightly above it with plastic spoon etc.
If this does not work u can buy the control panel from Sears for 190.00 but first go to searspartsdirect.com then type your model no. In required space click on shop parts on appropriate model, then go to troubleshooting then to won't start, then go down to how to replace control panel.
According to instructions you will only need torx screwdriver and less than 30 minutes to replace.
Jul 13, 2017 | Kenmore 16602 / 16604 / 16609 Built-in...
Lock on light flashing
I finally decided to calm down and use my head and managed to solve the problem. I read the instructions that are on the top of the dishwasher door. ( Smart move on my part HUH!) It said that when the door lock light is on everything is disabled. Hold the air/dry button down for 4 seconds and the lock light will go out. Guess what, IT WORKED. Here is what I learned from this. Always read all instructions. I spent $9.95 for an answer that was right in front of me. Humans can be so dumb I am!!!!
Jan 28, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Kenmore ultra wash dishwasher
More than likely it is a shorted key. replace the touch panel.
Dec 04, 2008 | Kenmore Dishwashers
Kenmore dishwasher Lock On light flashing
holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
will go back to normal, normall takes more than four seconds to unlock the unit, this is something
the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
Dec 29, 2007 | Dishwashers
Kenmore dishwasher Lock-On light flashing, will not start
Push the heated/dry button on the dishwasher for 4 seconds and that will unlock the dishwasher. This is just a safety feature that allows you to lock the dishwasher to stop kids from pushing buttons.
If that doesn’t’ work they will send out a tech to fix it.
Mar 07, 2007 | Kenmore 24 in. 15079 Built-in Dishwasher
Kenmore 15899 Built-in Dishwasher Logo
252 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
