Question about Frigidaire GLTR1670A Front Load Washer
Front load washer loud noise and drum loose but not dropped
New Year's Eve Frigidaire front load went into spin cycle and suddenly sounded like it was spinning BRICKS..was so loud it was scary...I turned it off, unplugged and took a look..springs fine and shocks brand new..loose drum but not "dropped"...please help!! I MUST figure this out on my own..don't have the $ for repair person and have two sons and 4 dogs...laundry is piling up!!
Spider arms attached to stainless steel drum inside of tub have probably broken. This is a known problem with Frigidaire front loading washing machines. The stainless steel drum has a 25 year warranty but this does not include the spider arms. You cannot buy the spider arms separately, you have to buy the unit as one. The drum cost about $250.00 and probably about $300.00 in labor to install. You can do it yourself but it is pretty involved. Good Luck!
Posted on Jan 20, 2009
How is this done
Posted on May 30, 2009
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 6 Answers
Spider arm broken,
it may able to wash,
but in spin cycle, it makes loud noise and unbalance movement.
replace the spider arm.
if you are handy,
you can use few strong enough pieces of steel iron to drill holes to mount on the broken spider arm with screws.
better to mount the same weight to the other arms to make the drum in balance.
a cheap way to fix.
Posted on Oct 09, 2019
SOURCE:
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
I have a Fridgedaire Gallery front loader, was making a loud banging noise on spin cycle, now the whole drum has dropped! help!
The symptoms that you describe sounds like the spider arms that support the drum are broken. It is a very expensive repair. Get a few estimates, before deciding whether it is worth repairing or replacing. Sorry.
Oct 06, 2010 | Frigidaire ATF6000ES Front Load Washer
Very loud noise during spin cycle - drum still spinning at normal speed. sounds almost like a broken belt - are there more than one belt?
only one belt on machines, ur looking at one of the following
  • loose counter weight
  • something stuck in drum, eg bra wire, sock
  • bearings failing
  • broken shaft
  • machine not level maybe?
Sep 23, 2010 | Frigidaire GLTF1670A Front Load Washer
Loud clunking sound during the spin cycle, washer is balanced and on 2nd floor
If you get a very loud noise coming from the machine, and this noise islouder when it spins faster, then it is often because of a problem with the drum bearing.
The drum bearing is bad, probably drum bearing spider had broken.
On a front load the drum bearing is located at the back of the drum.
To replace the part you take apart machine, undo the belt and depending on the model you may need to remove more parts.
You can find parts and diagrams for most models here.
Nov 13, 2009 | Frigidaire GLTR1670A Front Load Washer
Loud noise in final spin
Verify that the inner drum isn't broken. Sopin by hand it should trun smoothly and staight.
Aug 30, 2009 | Frigidaire ATF6000ES Front Load Washer
My model #gltr1670aso makes loud noises during spin cycle
Usually this is due to either the drum support breaking or the back bearing being bad-neither easy to fix- or worth it. Try lifting the drum up and down, if it moves up and down they are bad. I see this a lot, and the price of repair isn't worth it. Craig
Aug 02, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmore front load washer
My Kenmore front-load washer starts to make the huge noise. The noise happens during the wash cycle, but is mild. During the spin cycle, the noise becomes really loud. It looks like the drum is getting loose and hitting other part of the machine.
I checked the drum, and I can sway the drum easily with my hand. So it looks some supporting structure is broken. I don't know if it is easy to open the washer to check what has been broken.
May 20, 2008 | Kenmore 44072 Front Load Washer
During spin cycle started making loud noise now drum feels loose DURING SPIN CYCLE DRUM SOUNDS AS IF IT'S HITTING SIDE.. FEELS LOOSE WHEN I PUSH IT AROUND FRIGIDARE GLTF1040ASO
ckd your warranty papers sounds like rear drum support(spider) has broken will require new basket and rear drum half est cost 400-600 spider is not a separate part and rear bearing is probably damaged that too is not a separate part and require rear tub replacement
May 20, 2008 | Frigidaire GLTF1670A Front Load Washer
Drum makes loud noise when spinning
HI thanks for the question. Frigidaire has a life time warranty. on that part .call them. thanks the appliance doc. please rate my answer. thanks.
Apr 29, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire top-load washer Loud noise during spin
its either the upper spin bearing or lower spin bearing. the upper can be replaced by itself but the lower requires the transmission the be replaced
Nov 20, 2007 | Frigidaire FWS833A Top Load Washer
Frigidaire GLTR1670A Front Load Washer Logo
2,385 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
