Question about Brother Office Equipment & Supplies
Printing Problem The printing is not uniform in manner. Several BLANK lines intermittently appear on the printed page, therefore I don't get a complete print. I have replaced the drum and the cartridge, but the blank lines still appear. Thank you for your assistance, Tony (new Orleans)
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, if the distances between the "BLANK lines" are the same, then it is a mechanical fault. If the "BLANK lines" are intermittent with no apparent consistency in the blanking/missing lines of print, then it would be toner dispersion problem (cartridge). Remove the cartridge, shake vigorously to even out the toner/powder inside. Try again and print 2 copies of the same page. compare the 2 similar printouts. Note the "BLANK lines" if likewise identical. Alternately, since drum would refer to a laser system, print a test document, mark it as #1, then print a blank page, use that same blank printed paper immediately while still warm and print again the test document mark as #2. Notice/compare, if any significant change in the print quality. If yes, then it would be drum/heater issue.
Good luck and Thank you for using FixYa. Happy New Year.
Posted on Jan 02, 2009
  • Brother Master
  • 19,396 Answers
Try performing a print head cleaning procedure,, do that a couple of times.
If the lines are uniform and vertical, do also alignment and clean the encoder strip with isopropyl alcohol and cotton.
The encoder strip is the plastic strip that runs near to the traction belt.
    President:
  • 2,110 Answers
Try to update the driver from internet..pls tell me ur model..
    Novelist:
  • 163 Answers
First clean the printer road by using thinner.
  • ronny2051 Jan 02, 2009
    ss..
    open the printer panel and then clean the printing rod properly (rod on which the cartridge runs). check doing this first
Blank printing ir 2018 n
There can be several reasons for your printer is printing blank pages. To help you troubleshoot the issue, please follow the link given below and follow the instructions mentioned on it:
http://canoncanada.custhelp.com/app/answers/detail/a_id/2182/~/printing-blank-pages
GuruAid.com
Jul 20, 2016 | Canon ImageRUNNER 2018 Copier : 2018...
Yellow lines appear in printed outputs on my Epson 1280. Printer was inactive for about 5 months. ....have cleaned and soaked print head several times. Lines are less intense, but still there. Thanks...
There are two possible causes: 1. The ink dries on the plate around the head output (sprayer), 2. Thin coatings of yellow head broken. The first possibility can be tested by printing blank pages (or just containsthe line - full pages). If after about 50 pages to print, yellow lines had been lost, then the printer is ready for use again. But if not, then thesecond possibility happens. At the output of the head there is a thincoating. If until the coating is breached, then the ink will drip continues,although there is no voltage or current that supplies the headmicropiezzo.
Jul 12, 2011 | Epson Stylus Photo 1280 InkJet Printer
Printing blank pages on Lexmark C510 printer. Throws a 34 Short Paper error first, prints out a blank page. I have replaced the black toner, but problem continues. Demo page printed colors successfully but...
For 34 Short Paper error, reseat the tray guides and make sure it is set properly. Also, set the correct settings in the computer. For blank pages, always double-check the paper settings and again the settings in the computer. For not printing black, print the Print Quality page and see what color is not printed or not showing. If Print Quality shows black, try printing any document from any application in the computer. Check if you still have the problem. If problem is not resolved, leave a comment so I can get back to this.
Apr 09, 2010 | Lexmark C510 Laser Printer
Replaced ink, nothing prints not even tests
there are two main areas of concern: A waste sponge2c905eb.jpg located just under the printhead, and which helps to park the printhead when you turn the power off, and the actual printhead itself. There are also two ribbon connectors that attach to the printhead assembly--and if one of them is not fully plugged in the exact symptoms you describe will occure.
To reach the waste sponge require the dis assembly of the upper half of the printer. I can knock it out is about 5 minutes now! I have used about 50 Q tips to soak up the ink, and manually clan the long rectangular sponge as well.
It you want I can send you pictures of my printer all torn down.
Sep 04, 2009 | Epson PictureMate (C11C556001) InkJet...
Lines in the print
Nozzle check perfect? No ink drop outside lines? Cyan lines is random position. Print blank pages. It is still appear cyan lines? If yes, it caused by waste ink at bottom plate. Print blank pages more, it will clean itself.
Jun 29, 2009 | Epson Stylus CX9400 Photo Printer
My MF 6530 printer began printing light so we changed the cartridge and the machine began printing blank pages. When the other cartridge was put back in the machine, it too began printing blank pages. We have several of these machines in a couple of offices and have had this problem before. Canon is aware of the issue with this model, but I would like to know it as well. Can you help with what the problem is and the repair instruction? A friend of mine with this machine and the same problem, had called Canon and they had repaired it quite fast in his office. I'd like to do it myself in case it re-occurrs.
Apr 09, 2009 | Canon imageCLASS MF6530 Monochrome Laser...
Dell A960 printing blank pages
I just sprayed windex on bottom of cartridge several times and wiped with paper towel until dark streak of black appeared. Then I dried off cartridge and replaced. It works now. Must have been clogged.
Nov 18, 2008 | Dell A960 All-In-One InkJet Printer
Printing on the same line after a few pages printed
I first oiled the bar once more and while the printer was off, moved the head across the bar forcefully several times until it felt the ease to move. I then typed a document with numbers 1 to 10 each number typed two lines below the other and tried printing this document several times. This worked perfectly and the printer is now in order.
May 30, 2008 | Epson LX-300+ II Matrix Printer
Canon bjc-80 - no print appears but cartridge & paper move normally
I had this problem too. It turned out there was old dry ink in there clogging up the printerhead and it was fixed after I ran the cleaning programme several times. However I can't for the lifeof me remember how to do that now. I know I found it online but it has since vanished. Maybe check your manual?
Nov 12, 2006 | Canon BJC 80 InkJet Printer
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
