Question about Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
My dryer is not spinning? It comes on but does not spin.
  • 706 Answers
In most cases if the tub doesn't spin... its the belt that failed and will need to be replaced..
Posted on Jan 03, 2009
Kenmore Heavy Duty Plus Dryer 86273100 drum won't spin
How could the belt be in working order if the drum doesn't spin? Check to see if the belt has come off the motor. If the motor runs but your dryer doesn't spin, the belt is off. If the motor runs with the belt on but it still won't spin then you'll have a lot of black smoke because your drum is jammed. In other words, there are a number of things that could be wrong, but not very many.
Dec 22, 2011 | Washing Machines
Dryer doesn't spin
Look around for stiff wheels, bad bearings, glides and idlers. Its a good idea to oil the rollers with some temp resistant oil such as zoom oil. Dont use WD40 as this stuff is highly flammable and may cause a fire.
Some previous repair PICTURES
Oct 08, 2009 | Whirlpool WED5100SQ Front-Load Electric...
Dryer drum will not spin when you push start button.
can you hear the motor running? if so its probably a broke belt
Sep 03, 2009 | Dryers
Won't spin anymore. Comes on, but barrell won't spin. dead motor?
Do you hear the motor running? It may just be a broken belt. If it is in fact the motor it can be replaced.
May 28, 2009 | Kenmore Dryers
The dryer heat works but the drum is not spinning.
Raise the top lid and inspect the belt. If it is broken, replace it.
Apr 12, 2009 | Whirlpool LER4634J Electric Dryer
Dryer spins counter clockwise
When installing new belt the belt comes off the right side of the drum and through the idler and around the motor shaft, then up the left side
Jan 07, 2009 | Whirlpool LGV4634JQ Gas Dryer
Dryer no heat coming out
No heat coming out of my dryer it spins and there is good source of power...
Jul 21, 2008 | Whirlpool LER5636P Electric Dryer
Groaning sounds when dryer spins
yes it is, its the rear tub bearing. pain in the butt to change but that will solve it
Nov 20, 2007 | Bosch Axxis WTL 5410 Electric Dryer
Dryer wont spin
Doe the motor running ? if run w/out spinning the beltis the problem / bring sample to appliances center.
Aug 25, 2007 | Kenmore 45081 Front Load Washer / Dryer
Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer Logo
615 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
