Question about NetGear MR814 Wireless Router
Can't access settings page
I have a MR814 v2 router which has worked well now for a few years. I have run into a problem since Telstra have changed their access method to cable. I don't know if this co-incidence or not. When I type in 192.168.0.1 I get back the message "Internet Explorer cannot display the webpage" and thus cannot access the settings page. Yet if I ping that address it sends and returns the relevant packages. I am still able to access other internet pages through the router albeit what appears to be at a slower speed. Help please.
  • Alex Kennedy May 12, 2007
    Thanks for your help. I went through Benimur's power down process and I can now access the settings page. I have software V5.03 from Nov 18 2003 which seems to be the latest. Is there some way of testing the efficiency of the router?
  • mrmuse Dec 08, 2007
    Having the same problem, can't access the router @192.168.0.1
    Have tried the reset and it won't reset the router either...
    PC directly to router won't talk at all....Tried straight thru and crossover with no luck...
    It's like the DHCP portion is not functioning as you can't release or renew and get a 192..........It just passes through the charter info.
  • 560 Answers
Now login with 192.168.1.1
It works.
Posted on Oct 15, 2012
    Brigadier General:
  • 6,966 Answers
Hi, you may want to try: 1. reset the router to default settings - depress small button at the back of the router. all the leds in front wil blink and/or die. continue pressing on until one of the leds lights up again (might take a couple of seconds. if you can't still log to the web interface, you can try: 2. power off then disconnect all connection to the router. 3. connect your PC directly using a lan cable to one of the 4 lan connectors at the back and to the Lan Card/NIC of your PC; 4. Set your PCLAN to 192.168.0.2;255.255.255.0; 5. Power on the router and try to login to 192.168.0.1 with username: admin & password: password. Normally on power on, the router front leds blinks to indicate power on reset. Leds which remained steadily lit indicates a hardware failure (except for the power led). I have flashed this model with mr814v2_v5_03.img which solved internet slowdown and a couple of other problems. Hope this be of some help. Pls post again how it turns up with your router.
Posted on May 11, 2007
    President:
  • 2,961 Answers
The web page of your router cannot be changed by the isp, but what may have changed is your network cards ip address, as thats the only wat the router cannot be reached if you are on a different address route, so check that your card is 192.168.0.X, the last being different to the router. the only other way this may have happened is if you have used an installation disc and it has changed all address so that they are different to what the routers manufactured address is and therefore cannot be altered but is allowing a static ip address or mac addresses for internet connection. The outer may have simply froze out, and you may have to reset the router by way of a pin hole button at the rear of the unit or underneath or firstly try a restart by unplugging it.
I am trying to set up my wi-fi kindle and I don't know what to enter
Get the directions from NetGear, for free, and use their install wizard.
Here are the (generic) highlights of what needs to be set:
Wireless Router
It is usually easiest to run the install wizard, but be sure to be ready to set the items listed below.
Things to set:
Note: Routers are intended to be set by geeks. You have to SAVE EVERY page, or the changes will be lost. A geek knows this (apparently). The router gives no protest...just dumps your changes.
1. Login password (RECORD THIS!!). Consider taping to bottom of the router. Physical access is not the security issue.
2. Set a recognizable system ID.
3. Invoke wireless security of at least WEP.
a. Assign your own access code, 10 digit home or cell #. Consider taping to bottom of the router. Physical access is not the security issue.
4. Check that your router is set to broadcast its' presence.
Dec 31, 2010 | NetGear MR814 Wireless Router
It wont work
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Aug 26, 2010 | NetGear MR814 Wireless Router
I need to set up a password on my net gear MR814 .. What do I do?
How to secure the wireless network
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Click Here for step by step instructions
Jul 20, 2010 | NetGear MR814 Wireless Router
Using Windows XP. can't remember NETGEAR DG632
Is there any computer online using the router.
check the IP address on that computer.
If yes then you can open the router set up page on
that computer.
router set up page is the page where you can check
all the router settings.
and network
Feb 13, 2010 | NetGear MR814 Wireless Router
I can not access my wireless internet network with my new computer. I have a netgear wireless router model MR814v2. I can get onto the internet when directly connected to my modem. However, when I try to...
Hook directly to the router hard wire. Go to configuration page for router and look at wireless security settings. it will show you Wep or some other encryption technique. It will also give you a place to view or change your wireless key. Once you do that write the key down and then connect wirelessly.
Nov 08, 2009 | NetGear MR814 Wireless Router
Have just upgraded my router from a Netgear MR814 to a Netgear WGR614 and have eventually got my network up and running except for my Netgear WGE 111 wireless game adapter (connects to Xbox 360 and was...
you can simply go to that computer , which is connected hard wired to the netgear router...
Open up a web page(internet explorer or Mozilla firefox )
In the address bar type 192.168.1.1 or www.routerlogin.com.
It will ask for username & password...
Username : admin
password: password
On the left hand side(blue panel)
Wireless settings --
You will see ur SSID & passphrase there...
In case of any other assistance u can ravert back to me....
Jul 13, 2009 | NetGear WGE111 802.11g Wireless Game...
Can Not connect to NetGear MR814 v2 Router with Acer Extensa 4420
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Mar 31, 2009 | NetGear MR814 Wireless Router
Connecting XP wireles Client to Netgear MR814 v2
Please see if this things are done:
  1. Power on your wireless device - now a days, laptop have a manual switch aside from software-base application. It usaully a tiny switch witch is mostly located at the edge of your laptop.
  2. You might have entered an invalid key - use notepad to enter your security keys then cut and paste it on your application setup.
  3. Reinstallation of your device driver.
  4. Your router networking is not broadcast so do it manually by supplying SSID and security keys on the setup menu.
If this thing are done correctly, better see your supplier.
If you think this things are helpful, please rate me.
regards,
-engrkoiled-
Mar 27, 2009 | NetGear MR814 Wireless Router
Connectiob problem
This can be a problem with the firmware of the router, firmware is the the software inisde the router so if you have problem with the speed of it a firmware upgrade should make everything working fine again, I advice you to upgrade the firmware of the router to the latest one...
Nov 07, 2008 | NetGear MR814 Wireless Router
Have a problem with my netgear router
Please use the manual you can find on page :
http://kbserver.netgear.com/products/wgr614v7.asp
You need to change option :
"Wireless access point enabled": to yes
regards,
Konstantin
Jul 12, 2008 | NetGear MR814 Wireless Router
NetGear MR814 Wireless Router Logo
108 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
