Question about RCA HD61LPW165 61" Projection HDTV
RCA HD61LPW165; Bad Color Wheel; How to get to it to replace
I have an RCA HD61LPW165 Scenium with, apparently, a bad color wheel. Apparently it's easy to replace, once I can get to it. How do I get access to it? I've replaced the lamp, previously, but need a little direction (or pictures) for the color wheel.
  • Anonymous Jan 27, 2009
    bad color wheel on hd61lpw164
  • Matt Moreno Oct 12, 2015
    The color wheel is replaced from the front, behind the screen. Remove the screws holding on the back and slide it out of the way. On the sides you can see where the back cover blocks access to 3 or so screws that are on the back side near the speakers. Remove these screws on both sides of the backside of the speaker grill. Pull out the top of the grill about an inch or two, then pull it straight out. It is on friction fasteners. Remove the remaining screen perimeter screws on the back then gently lift the screen off. Be careful there is ribbon cables attached. set the screen down in front of the TV. Gently disconnect the ribbon cable connectors, they are labeled but are identical size, and set the screen aside. There is a plastic cover below the mirror that houses the top of the light engine, remove the two screws on the front on either side. Then slide the cover up and out, careful not to touch the mirror. Now you can see where there is a aluminum finned heat sink, next to the side of the bulb on top, this is where the color wheel is. Remove the two ribbon cables the tiny gray and orange colored ones from the light engine module. There are two Philip head screws on either side of the color wheel, unscrew those and slide the color wheel assembly out straight up. It has a rubber gasket on it, be careful not to damage it. Remove the old color wheel with the three tiny torx screws (I think it is a T-10 but very tiny like that), then slide the color wheel out. Replace with the new one, be careful not to touch the flat surface of the wheel. Clean the lens in the color wheel assembly and re-assemble. Be sure to put the cables back into their grooves under the gasket. Be sure to also clean the main lens as well as the backside of the screen and your will be amazed at how much better the picture is due to the cleaning.
SOURCE: lamp replacement
Go to this PDF for instructions
www.911phone.net/Panasonic_TY-LA1000_Instruction_Manual%5B2%5D.pdf
Posted on Nov 06, 2007
SOURCE: RCA Scenium HDLP 50
Sounds as though your tuner module is not working or you have a lack of signal to the tuner. You need to be sure that the set hasn't been switched to a different mode ( ie: from tuner to video..etc ). If all is correct in that matter, are you using a satellite dish. If you are infact using a satellite dish, then the signal strength from the satellite is not suffecient. ( you may need to realign the dish ). If you are on a cable signal ( cable TV ) you may have a bad input cable and need to call the cable company to check their input line. If all is well with the signals coming in, then infact, you may a bad tuner module in the TV. Good Luck
Ed NC Electronic
Mills, Wyoming
Posted on Jan 06, 2008
Slinteriors
  • 8617 Answers
SOURCE: RCA HDLP 50W151 scenium color wheel
They make two different color wheels for the Rca DLP are you positive you got the right one. As usually its a straight forward install no adjusting needed. Post the chassis number off the back of your set and I will try to help you out with it.
Posted on Apr 07, 2008
  • 3 Answers
SOURCE: how to replace the color wheel on a RCA DLP
RCA DLP color wheel replacment is most efficiently done from the behind the screen, not the back panels where the guts of the DLP are located.
From there you do not need to remove anything but the color wheel and disconnect the two wires.
If you want to see pictures, email me and I can send you pictures. email: graphguy@gmail.com
Posted on Jul 27, 2008
Sparko1
  • 167 Answers
SOURCE: broken color wheel and lamp ballast on Samsung 4667W
www.tvrepairkits.com might have the parts you need. If not go to www.encompassparts.com
Posted on Jul 31, 2009
How do I remove the color wheel for an RCA HD61LPW165? Needing to send it in to get it rebuilt.
if you are talking about the light engine, your best bet is to have a tech do it.  if you are really talking about the color wheel, in my experience they are replaced not repaired ..
Jul 29, 2010 | RCA HD61LPW165 61" Projection HDTV
RCA HD61LPW165 Making squelling noise and color going in and out. Some of the shops i have talked to said that they cannot get the parts for these tvs. Is there any solution to fixing this tvs color wheel....
I have removed the color wheel from one of these and took apart to clean it thoughroughly this did work to fix one. Try an older distributor of parts for inventory they may have like Cumberland Signal Electronic parts in Pennsylvania. I have also found hard to come by parts on Sears Parts.com
Mar 05, 2010 | RCA Scenium HDLP61W151 61 in. HD-Ready...
The color apprears to be in like 3d I was told it was teh color wheel but its not making any noises
It's the color wheel. The color wheel does not need to make noises for the color wheel to be bad. Sometimes it can spin slower or malfunction all together and you'll get intermittent shadows or color splotches with messed up skin tones.
Feb 05, 2010 | RCA HD61LPW165 61" Projection HDTV
Need a color wheel for RCA Scenium HD50LPW165 50 in Rear-
that color wheel has been discontinued by RCA. Its the 267888 color wheel. You can get your color wheel rebuilt at the following link under color wheels.
http://servicemanuals.vstore.ca/
Oct 16, 2009 | RCA Scenium D40W20 40" Rear Projection...
Where can i buy a new color wheel for a rca scenium hdlp61w151yx1
You can buy color wheel of your RCA TV from Part Store, click the link for further info.
Thanks.
Aug 19, 2009 | RCA HD61LPW165 61" Projection HDTV
Color wheel was making a sqealing noise then locked up
The clorwheel is the problem. Once the bearings go bad in the colorwheel, it's toast. Replace the colorwheel and you'll be ok
Dec 18, 2008 | RCA HD61LPW165 61" Projection HDTV
Loud squealing noise first 5 minutes after tv is turned on
Sounds like the color wheel. It's the only moving part in most DLP's and the bearings can go bad. If it manages to get up to speed the picture may look normal. One temporary solution may be to let it run a few minutes, then turn the set off for 10 minutes, then turn back on. When my color wheel was going bad that would often quieten it down. For the rest of the day, try to leave the set on, especially if you're only going to be away from the TV for short periods. You can turn off your cable or satellite box but leave the set on and you won't have to go through the hassle of trying to quieten down the color wheel until the next cold start. Of course the best solution is to replace the color wheel which even with a rebuilt unit won't be cheap if your warranty is expired.
Nov 02, 2008 | RCA HD61LPW165 61" Projection HDTV
How to replace the color wheel on a RCA DLP
Jan 18, 2008 | RCA HD61LPW165 61" Projection HDTV
RCA HD61LPW165 61" Projection HDTV Logo
252 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
