Question about Shure SM2 Professional Headset
Shure SM2 Headset/Mic wiring
I need the hook up schematic for the Shure SM2 headset with microphone. I am building a box with volume and on/off for our church.
Thanks!
John Bell
Headset connection: Blue wire to Pin 2, White wire to Pin 1, Yellow wire to Pin 3. Connect Pins 1 & 2.
Microphone connection: Black wire to Pin 3. Red wire to Pin 2. Ground wire to Pin 1.
I am using a male/female 7-pin XLR connector assembly to black box. I am using two 3-pin XLR connectors, one for SM2 microphone function, one for SM2 headset function.
Posted on May 26, 2010
Repair cable on shure wireless headset mic
If you unplug the mic, does the crackling stop? It so, replace the mic.
Feb 03, 2012 | Shure THD Wireless Headset Microphone...
Skype not working
Sir,
Click this link for more information........
http://support.skype.com/index.php?_a=knowledgebase&_j=questiondetails&_i=35
Also Check........
On a PC with external speakers and also a headset with microphone. Windows XP is configured so that standard audio are external speakers and standard microphone is the headset. Skype is configured to use the headset for audio in and out.
This way one can listen to sound from the PC and from MP3 players through external speakers and if there is a call to make or take, this is going through the headset.
But now there is the problem that the noise level for the headset is too low. Increasing volume has no effect on the headset, it only affects the external speaker's volume.
Now the solution: Going to the control panel and opening the sound setting, go to the audio tab. The external speakers are selected as default. Just temporarily select the headset and then click on volume just below. You can now set the volume for the headset, click OK and click cancel (!!!) on the sound control dialog box. This way the external speakers remain as default output.
Skype-->Tools -> Options -->Sound Devices-->audio device/USB/etc Audio Device (do NOT use windows default device)
You can also tick the ring pc speaker check box as this is a good backup to alert you even
if the main speakers are off or turned down.
Windows:
Start-->Control panel-->Sound and Audio devices
On the audio tab set the default playback device to your main soundcard(AC97/Audio-chip/add-on-adapter), etc.
Your installed audio device must be present there.
If not, reinstall audio device
thanks
good luck
Oct 29, 2008 | Altec Lansing Stereo Headset with...
Put new battery in shure T1-CV light still says low battery
Sometimes the low battery light is also the check light (same with BOSS pedals). The wireless headset mic I have has the same problem, though. There is a small short going to that light, but it doesn't affect the sound quality or functionality of the mic.
As for fixing it, you'll have to find a schematic and pinpoint the short, or have someone else work on it.
Hope that helps!
Feb 09, 2011 | Shure T1V Microphone
I'm useing the SLX1/SLX4 cordless combo with a Crown headworn mic (CM 311/E SH). Sometimes the sound cuts off ! I'm based in NYC. where can I go for repair? Thanks
If the problem is with the Shure wireless, you'll need to send it back to Shure (www.shure.com/service). If the problem is with the Crown headset, you'll need to send that back to Crown.
Oct 28, 2010 | Shure SLX1 Body-Pack Transmitter for...
VX-3000 microphone still enabled with headset. Is
TEST SPEAKERS
Right click on speaker icon in System Tray
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required mic as default - click on mic font to highlight and click "Properties"
In lower drop-box display "Use this device enable" click OK
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Dec 31, 2009 | Microsoft LifeCam VX-3000 Web Camera
Wireless Microphone low volume
The PGX1 bodypack has a switch on the side to set the gain. Make certain that switch is in the "mic" position. Otherwise, simply turn up the volume on your mixer.
Jan 24, 2009 | Portacom Porta-Com COM-60FC 6 Headset...
Can convert a stereo headset to a telephone headset?
hi only if you have some experience on how to add a mic in fact is a electret mike and are very cheap you joust cut one wire to hook the mic and thats set.....as you do this take a especial attention on which wire be the mic and the ear.......so you connect right..................saludos
Nov 18, 2008 | Portacom Porta-Com COM-60FC 6 Headset...
Microphone volume
I'm not 100% sure it's the microphone in your case, since I am experiencing the same problem right now with another microphone. I borrowed a working headset from my friend and it is not working either. My volume is up like yours and I can barely hear myself. I am updating the drivers soon and I'll let you know if that fixes it.
Oct 07, 2007 | Creative Labs HS-400 Headset
Cant talk
Try going to Control Panel -> Sounds and Audio Devices Click on Voice Tab and make sure the proper device is selected. Click on Volume and make sure levels are appropriate. Lastly, click on Test Hardware and wait until you can speak into the mic to see the voice levels. If you can see the voice levels, then your mic probably works and it is just an issue of configing the COD settings. goodl luck
Mar 15, 2006 | Altec Lansing AHS-502 Headset
Shure SM2 Professional Headset Logo
1,146 people viewed this question
Top Shure Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Shure Radio Communication Expert? Answer questions, earn points and help others
