Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Whirpool gold both freezer and refrigirator stopped cooling & freezing. What can be the problem? whirlpool gold GD5LHGXKQ00 MANUF. 7/2001. fridg. and freezer not near cold enough but trying to work. problem started all at once, been fine until last night found soupy ice cream etc.
  • 2 more comments
  • jmurphy1964 Jan 02, 2009
    yes, I can hear the fan inside the freezer and you can hear the unit running in general when you walk up to it...thanks
  • Camlaura Jan 04, 2009
    I have the same problem.. I have cleaned it out completely...but though it sounds like it is running, it isn't cooling. Every couple of minutes you hear someting kick in and buzz...it lasts maybe 20 seconds and then stops?
    Both fridge and freezer are set on coldest settings, and don't seem to be working. All vents are not blocked.
  • Ken Bledsoe May 11, 2010
    Can you hear a fan blowing inside the freezer?
  • Anonymous Mar 15, 2014
    Whirpool gold fridge
I did some research online, and read that the Start Relay is most commonly the problem. My husband bought the part, (about $50) and reattached it to the side of the compressor....and was cold immediately! apparently a very common problem on these fridges.
Posted on Jan 09, 2009
Water pooling and freezing in lower freezer, whirpool gold french door? How do I rmove liner in fridge to follow line?
Sounds like a clogged drain. Remove food, remove bins and shelves. Remove ice maker if freezer is in the bottom. Remove back panel. .melt ice on drain pan and run hot water into drain.
Feb 14, 2015 | Whirpool Refrigerators
Can you tell me why please?
All the big cooling happens inside freezer compartment. Freezer gives little cool air to fridge compartment. Now when the vent blocks that little cold air cannot go into fridge compartment. Thus your freezer works good but not fridge compartment. Milk goes bad but frozen meet keeps good.....
Vent freeze up either due to defrost problemt, defrost drain line problem, Evaporator fan problem or even can be your damper motor not opening due to unit failure or frozen damper door.
Sep 19, 2014 | Whirlpool GX2FHDXVY Gold Stainless Steel...
Whirlpool refrigerator not cooling after storm
Assuming that both freezer and refrigerator temperatures have risen and the humming sound that you heard was followed by a sudden click more than likely the start device on the compressor has gone bad. This is a common problem with all Whirlpool refrigerators (KitchenAid is Whirlpools top of the line product and suffers the same problem).
May 11, 2012 | Refrigerators
Freezer (top) is cool, but refrigirator at room temperature
Your first step is to make sure the condenser coils and the fan are clean and there is nothing blocking air flow around the outside of the fridge. A good vaccuming and brushing will do it wonders.
If this does not improve the operation. Tell the landlord that it is bad and if it is part of the supplied appliances, he should replace or repair it for you.
If he is not cooporative, do some online searches for methods to convince him to do his job or who to contact to ensure he doesn't cause you harm.
Sep 20, 2009 | Whirlpool ET4WSKXK Top Freezer...
The fridge and freezer is not chilled
power to the house was shut off for repairs, when power was restored the freezer part of the fridge stopped working but the compressor still runs.
Mar 19, 2009 | Hotpoint HSS25GFP Side by Side...
Whirpool gold
Sounds like the unit may be stuck in to defrost . The defrost clock is usually inside of the refrigerator compartment up by the thermostat controls. you can take a screw driver and advance the controller to make the compressor come back on . usually when they start to stick they neeed replacing. good luck and please don't forget to rate the answer please. Thanks for using FixYa.
Jan 01, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirpool side by side refrigerator ,fridges is not cooling at all
HI.YOU MIGHT WANT TO CHECK IF THE FAN IS WORKING WELL OR IF THE UNIT IS NOT OVER FREEZING WHICH CAN E A CAUSE OF THE FRIDGE NOT COOLING PROPERLY.FEEL FREE TO REQUEST MORE ADVICE IF NEEDED
Nov 13, 2008 | Roper RS22AQXKQ Side by Side Refrigerator
Whirlpool Gold Conquest side by side (stainless steel front)bought in 2004. Freezer stopped freezing, fridge cooling fine, freezer is running. Thank You!
sounds as if you have an ice buildup restricting the fan from moving airflow to the freezer. Inside the freezer take apart the lower shelf and see if this area is full of ice, if so clean it and defrost it.
Jun 12, 2008 | Whirlpool Refrigerators
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
400 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
