Question about Westinghouse WRS6R3EW 36" 25.8 Cu. Ft. Side-by-Side Refrigerator w/ Built-In Water & Ice Dispenser &...
I cannot get water out of the water dispenser and the icemaker isn't making ice.
I know this seems like an issue with the water supply, but water is flowing through the tube to the refrigerator. It doesn't appear to be reaching the icemaker or water dispenser. Any clues?
  • NormanR Nov 26, 2007
    I have no problem with ice but the cold water dispenser does not work.
  • 35 Answers
You might need to call in an on site tech.the water is probably not getting pass your water valve.
Posted on Jun 05, 2007
  • kelsey johnson Jun 05, 2007
    you might have a freezing problem.therefore you would need to manually defrost ref.also you could have a water valve problem.try defrosting first.if this does not solve your problem.call in your local tech.
    Sergeant:
  • 236 Answers
Is the water freezing up en route? try a full defrost to see. if not a blockage may have occured.
Posted on Jun 04, 2007
The ice maker makes ice for awhile and then clogs up with ice. How can I prevent this?
It's possible that the system is either no longer sensing that its ice reserves are full (if I am reading your question correctly) or that the water supply to the icemaker isn't shutting off, instead slowly drip flowing over the ice cubes until they solidify into a continuous glacier. I recommend thawing the icemaking system out and cleaning everything up with a bleach-water mixture, then testing your sensor and water supply.
Aug 04, 2015 | Kenmore Refrigerators
Water will not stop flowing in to icemaker
Dirt in body of icemaker water supply valve. OR. Ice maker timer stuck when it selected "add water to icemaker.
The first solution is simple, change icemaker water filter and disassimble valve to clean.
The second is simple, buy a new icemaker.
May 15, 2012 | LG LFC25760ST 25 Cu. Ft. Panorama French...
Water dispenser and icemaker not getting water on a maytag fridge
pull line off of the back of fridge to see if water comes out if not its where ever you have that line taped into yuur water supply for the fridge had the same problem hard water clogged up the tee off take it off poke some thing in the little hole make sure you have the water shut off to the water supply when was the last time you changed the filter in you fridge it could be tht too
Nov 12, 2011 | Refrigerators
I would really like some help with hooking up the ice maker. The line is there bit no ice or cold water, water is warm. Can you hep?
The routing of the water line is
house water supply into built i filter on refrig,
out of the filter into the water inlet valve on back of ref,
larger dimeter tube from valve into water tank behind crispers in ref,chills water,out to door,
smaller diameter tube from valve into icemaker
seeing where you said all lines are in place i believe the issue is that the refrig isn't properly cooling? the first to affected when not cooling is icemaker/water dispenser
Hope this helps
Gene
Jul 29, 2011 | Hotpoint HSS25GFP Side by Side...
Icemaker doesn't work
chack water valve and make sure it is getting water if so and there is ice in ice maker then your heater is bad and not releaseing ice
Jul 08, 2009 | Whirlpool GS6NBEXR Side by Side...
Water not going into icemaker. Water dispenser works fine.
Check the water valve at the back of the fridge if present.
Even if you used blowdryer, ensure that linse are not frozen by performing a complete defrost.
Disconnect water lines from icemaker, and blow with compressor if the above did not work.
May 20, 2009 | Kenmore Refrigerators
New water valve not filling the ice maker.
take the supply line to water valve and blow into it
you will feel it if it is clear if blocked remove tube
and clean
Apr 13, 2009 | Refrigerators
Icemaker quit working
Hello.
First of all you need make sure that your freezer is freezing enough. Sometimes everything will seem to be freezing ok, but it won’t be cold enough to make the icemaker work. The best way is to squeeze your ice cream, if you have any that is.
Then you need to make sure that the ice level sensing arm is in the down/on position.
If all of this checks out ok, then you need to make sure that nobody turned off the water supply that is sometimes located under the kitchen sink. Also make sure that the ice bucket is positioned properly so as to trigger the ice bucket sensing switch.
If all of this checks out ok, let me know and I can guide you through an icemaker diagnosis by forcing it into a harvest mode.
Nov 20, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
New Kenmore Elite ice dispenser not working but water is
Should be no longer than 24hrs. Is the freezer good and cold.. has to reach a certain temp before icemaker activates. Might take little longer if you put a lot of warm things in freezer or refrig. when you made the change. Is there any water or ice in the icemaker itself? Water may not be getting to icemaker call them back out if it dont work soon thats what warrantys for :0)
Sep 02, 2007 | Whirlpool ED2FHEXN Side by Side...
Westinghouse WRS6R3EW 36" 25.8 Cu. Ft. Side-by-Side Refrigerator w/ Built-In Water & Ice Dispenser &... Logo
187 people viewed this question
Top Westinghouse Refrigerators Experts
Sal De
Jose Pino
Vincent_G
Vincent_G
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
