Question about PANDIGITAL 7" Digital Photo Frame With Interchangeable Frames
Digital time display upper left corner of picture
How can I stop digital time from being displayed across pictures?
  • Anonymous Mar 06, 2009
    Simple? What's simple about it? I can't find the time on/off settings! This thing is a piece of ****!
After going through ALL the digital menus and not finding the solution, I realized there were some physical buttons at the top of my frame. Hmmm... how quaint... wonder if they are any different? Apparently... so while playing the slideshow (different menu pops up if you are in home page) - press the setup button up top and you'll see the "enable clock display" option.
Posted on Apr 02, 2009
It turned out to be pretty simple. I found I could go to the menu and simply turn the time signature off.
Posted on Jan 03, 2009
Set Date and Time Display to FinePix T410 Camera
The date and time appear in the lower-left corner of the screen, both when taking pictures and when reviewing pictures you've already taken.
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Apr 06, 2014 | Fuji Finepix T410 Black 16mp Digital...
How do you know when the memory sard is full?
When you turn on your camera, the amount of pictures available to take is displayed.usually in the upper right corner of the display
Please vote if my information is helpful or not. Recommend me. Thanks UAW 974
Jun 26, 2011 | Nikon Coolpix 5600 Digital Camera
Takes pictures but you cannot see image in lcd screen
This model only lets you see the image in certain modes. Test if it is properly working by changing the image mode to "P" and pressing the "Set" button (its in the middle of the arrow keys if you're having difficulty finding it. That should display the image on the LCD screen.
If that doesn't display an image, press "Menu" (upper left hand corner) and press the right arrow 4 times to get to the wrench with two dots menu (says "LCD brightness" on the first line. Press down 5 times and select Live view function settings and press "Set". Make sure the first line is set to enable. This should resolve the issue.
Please leave feedback if this was helpful, thanks.
Apr 18, 2011 | Canon EOS Rebel XSi Digital Camera
Camera not displaying pictures I have taken
are you sure that the memory card is in the camera? if not, thats probably the problem!
Oct 10, 2009 | Canon PowerShot SD1000 Digital Camera
Need instructions for my sr927w accurist watch
QUICKSTART - SET THE TIME
1. Push the bottom right hand button until the mode hand indicator points to TME.
2. Press and hold the upper left button for three
seconds. The hour and minute hand will retract to the 12
O’clock position.
3. Select the time zone on the digital display by pressing the
upper right button or the lower left button.
4. Pull the bottom right button out one click. The bottom part of
the digital display will start flashing. Press the
bottom left button to adjust for daylight saving time.
5. Press the upper right button. You will see the seconds
flashing on the lower half of the digital display. Press the lower
left button to reset the seconds to 00.
6. Press the upper right button. You will see the minutes
flashing. Press the lower left button to set the minutes to your
current time.
7. Press the upper right button. You will see the hours flashing.
Press the lower left button to set the hours to your current time.
8. Press the upper right button. You will see 12H or 24H
flashing. Press the lower left button to switch between 12 hour
and 24 hour.
9. Push the lower right button back in.
SET THE CALENDAR
indicator points to CAL.
2. Press and hold the upper left button for three seconds. The
hour and minute hand will retract to the 12 O’clock position.
4. Pull the bottom right button out one click. You will see the
month flashing on the digital display. Press the lower left button
to change the month.
5. Press the upper right button and the date will begin flashing.
Press the lower left button to change the date.
6. Press the upper right button. You will see the year flashing.
Press the lower left button to change the year.
7. Push the lower right button back in.
SET THE ALARMS
indicator points to AL1, AL2 or AL3.
4. Pull the lower right button out one click. You will see ON or
OF flashing on the digital display. Press the lower left button to
turn the alarm on or off.
5. Press the upper right button. You will see the hours flashing.
Press the lower left button to change the hour.
flashing. Press the lower left button to change the minutes.
SET THE TIMEZONE
1. Setting the time zones allows you to add or remove cities on
the digital display or switch between daylight saving and
standard time. Begin by pressing the lower right button to move
the mode hand indicator to SET mode on the bottom dial.
2. If the hour or minute hands are obscuring the digital display,
press and hold the upper left button for three seconds. This will
cause the hour and minute hand to retract to the 12 O’clock
position.
3. Now pull the lower right button out one click. You will see the
digital display flashing. Press the upper left button to select
SET to display the city or OFF to not display the city. Press the
lower left button to turn summer time on or off. Summer time is
indicated on the lower part of the digital display. Daylight
savings time must be manually set for each city.
4. Pressing the upper right button will allow you to scroll
through all the cities. After setting, push the lower right button
back in.
USING THE TIMER
1. Press the lower right button to move the mode hand
indicator to TMR mode on the mode dial.
position.
3. Pull the lower right button out one click. You will see the
minutes flashing in the digital display. Change the minutes by
pressing the lower left button. Once you have set the minutes
on the timer, push the lower right button back in.
4. Pressing the upper right button starts and stops the timer.
5. Press the lower left button when the timer is stopped to reset
the timer to its initial preset time.
USING THE CHRONOGRAPH
1. To use the chronograph press the lower right button to move
the mode indicator hand to CHR mode on the mode dial.
3 .To start or stop the chronograph press the upper right
button. If you press the lower left button it will display the split
time for 10 seconds.
4. When the chronograph is stopped press the lower left button
to reset back to zero.
SET THE TIME ZONE
the mode indicator hand to SET mode on the bottom dial.
savings time must be manually set for each city..
through all the cities. After setting, Push the lower right button
back in one click.
Hope this helps. =)
Oct 10, 2009 | Bulova Watch
Lines on upper left corner, inside of screen
its problem with the display cable (not the one you connect to your pc)
open the lcd display and look for a cable that is attached to the front glass display. check whether it is dameged.. it cannot be replaced
you need to replace the whole display that would be better. and cost effective
Jun 11, 2009 | Princeton Digital VL1918 Monitor
Can i make my digital camera to work as webcam
The webcam ability you get by using the round button on top of the camera with all the icons, between the flower icon (macro) and the Printer icon is the webcam icon. Press it and you get the Little red movie icon on the display window, upper left hand corner. If you then press the button where you take pictures the red icon in the display window will start to blink. This is an indication of that your webcam is working and is in motion. How long time your movie is going to be all depends on the memory card.
The webcam ability sucks up a lot of battery power.
Hope that helped!
Jan 05, 2008 | Panasonic Lumix DMC-LZ2 Digital Camera
Saved images to the internal memory or to the optional xD-Picture Card
The internal memory and the xD-Picture Card cannot be used at the same time. When the card is inserted the internal memory is disabled. When you want to use the internal memory, remove the xD Picture Card. The LCD display will indicate that images are saved to internal memory by displaying [IN] in the lower right corner of the screen. When using the xD-Picture Card the camera’s LCD will display [xD] in the lower right corner of the screen. These indicators are displayed just above the number of available frames.
Aug 31, 2005 | Olympus D-545 Zoom Digital Camera
Internal memory or to the optional xD-Picture Card?
The internal memory and xD-Picture Card cannot be used at the same time. When the card is inserted the internal memory is disabled. When you want to use the internal memory you must remove the xD-Picture card. The LCD display indicates the images are being saved to the internal memory by displaying [IN] in the lower right corner of the screen. When using the xD-Picture Card the LCD will display [xD] in the lower right corner. These indicators are displayed just above the number of available frames.
Aug 31, 2005 | Olympus Camedia D-435 Digital Camera
Saved images
The internal memory and the xD Picture Card cannot be used at the same time. When the card is inserted the internal memory is disabled. When you want to use the internal memory, remove the xD Picture Card. The LCD display will indicate that images are saved to internal memory by displaying [IN] in the lower right corner of the screen. When using the xD Picture Card the camera’s LCD will display [xD] in the lower right corner of the screen. These indicators are displayed just above the number of available frames.
Aug 31, 2005 | Olympus Camedia D-425 / C-170 Digital...
PANDIGITAL 7" Digital Photo Frame With Interchangeable Frames Logo
199 people viewed this question
Top PANDIGITAL Audio Players & Recorders Experts
Tom Chichester
Greg Ulan
d3yavu3
Are you a PANDIGITAL Audio Player and Recorder Expert? Answer questions, earn points and help others
