Question about Dyson Slim DC18 All Floors HEPA Bagless Upright Vacuum - Iron/Titanium/Yellow
Dyson 18 losing suction
Dyson slim 18 suction decreasing, vac is only 7 months old, any ideas?? kickstand also does snap back when vacuum is placed in upright position
  • 5 more comments
  • big-eon Jan 09, 2009
    I have exact same issues. Lack of suction and kickstand doesnt always lock out when stood upright resulting in vac falling over. Really annoying
  • kmshred Jan 24, 2009
    Same problem. Real disappointing.
  • hellionwheel Feb 05, 2009
    Have both problems - both started at the same time.
  • xczlowiekx Mar 27, 2009
    same problem, dissapointing...
  • emc35 Apr 07, 2009
    Same problem here.
  • jgille2560 Apr 20, 2009
    KIckstand won't snap back and the hoses are clogged and I can't figure out how to get the hose at the bottom on the backside out to clean it.
  • Anonymous Mar 20, 2014
    will not lock upright
    Problem Solver:
  • 5 Answers
Check the HEPA filter if it has one. This bit of foam gets clogged over time and significantly reduces the suction especially if you've been vacuuming a lot of very dusty areas i.e. dust from building work etc. Just wash the filter with lots of water and leave to dry before reinserting.
Posted on Aug 12, 2009
We had the kickstand problem - it was because the over-complex surface-switching gizmo on the 'foot' had somehow come apart. It was a brute to correct and was solved only by using trial and error. Dyson's are OK - but they weren't designed for ordinary people to use and as for the ridiculously complex hose and pipe system .... how do older or arthritic users cope?
Posted on Jan 02, 2010
  • mvasquez77 Dec 22, 2011
    What is the kickstand problem? I believe this is what is happening to us. Thanks
Dyson dc 18 slim product breakdown
Your question could be asking several things:
A copy of the manual can be found here at Sears (
http://www.searspartsdirect.com/partsdirect/user-manuals/DC18-dyson-inc-parts-UPRIGHT+VAC-manual ) if you are just looking for something that points to different parts of the vacuum and says what is where. A better copy is here (
Dyson DC18 Setup Guide ) (Trying to avoid places where you have to add some downloader bloatware to view the pdf).
If you're saying that the product is broken down, you'll need to be more specific. The manual covers general clearing of clogs and emptying. The most common aggravating situation I've seen in there for Dyson is that the upright units pretty much all shut off the brush head and suction when the vacuum is in the full upright position. This is the 'use the accessory tube' position where the suction is channeled up the handle. If you don't know that, and that there is either a button or hand-switch (For the DC18, a switch next to the main power button) that turns the brush on and off), then you can have lots of mystery working/not working behavior depending on whether the system is upright and whether the brush clutch is engaged.
Good Luck!
Jul 10, 2014 | Dyson Slim DC18 All Floors HEPA Bagless...
Dyson has no suction
Well, there must be a clog somewhere in the system, because as we all know, "Dyson's never lose suction." You haven't mentioned what makes you think there's no suction, or if there's no suction at a particular point, such as the wand/handle or at the floor unit. If you're familiar with your vac, there are a couple of places near the floor end that can be taken off and checked for plugs. Fully 95% of the time when there's a complaint of no suction, it's because there's a plugged up duct or hose somewhere in the system that's causing the problem.
Nov 09, 2013 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson Slim - suction is fine on bottom, but pipe has no suction at all. No blockage. When I remove pipe from the back at the bottom, I can see round white plastic thing in the opening. Right before it...
There is a diverter valve on those that changes suction from the hose to the floor when you pull the handle back. It usually makes the machine bind and not stand up. ( exactly what you are describing ) You need to take it to your local vac shop and they can fix it for you. The part that fell out was the retaining disc and a screw went in it to hold the diverter valve spring in place. Doubful if you can repair this on your own. It will not make since how it should go back if you've never seen it before.
Jun 10, 2017 | Dyson Slim DC18 All Floors HEPA Bagless...
Not picking stuff up and no suction in hose as well, suction sounds good until you go to vaccuum floor
Because this unit is bagless there are more gaskets to seal the suction portion of the vac. you are most likely missing a seal, can you remove the basket and place your hand near the suction on the vacuum? it is shielded so you wont lose fingers. if there is suction there, look at the bottom of the basket for a gasket, same for the top
Jan 01, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Wand lost suction
cleaning all filter Assy and all Handle Assy and Hose Assy...
Nov 06, 2009 | Dyson Slim DC18 All Floors HEPA Bagless...
Dyson Animal
Obstruction in the hose?
Your vac has developed a hairball possibly.... when a piece of flexible media ie.... cardboard, plastic etc... gets lodged in the hose, and begins collecting hair & dust to the point it no longer has enough draft to pull debris from the floor.
Here is a video that you may find useful
http://video.aol.com/video-detail/dyson-not-picking-up-dirt-no-suction-how-to-repair/2334249387
PS I Thought DYSONS were guranteed to NOT lose suction? What a RIP!
Jan 06, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Light on moterhead
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=34218&thid=498154
Light on moterhead
Posted by Arnold2 on Apr 08, 2008
The normal green light on the moterhead goes red and we appear to lose suction within the motor head
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
I checked with some of my contacts in the vacuum business and they told me that it may not be a United States vacuum and it might be a Canadian or European vacuum and may not be customer friendly to service, if you have a contact with a MAC or Snap On dealer or a metric auto store – as far as the green light on the powerhead the green light is supposed to let you know if the carpet is clean and the red light is supposed to be that the carpet is dirty, and laos it could be that your belt is loose and needs changing – a suggested belt change is every 4 to 6 months --- show them the screw and they might have something to fit or release the screw head, as per the removing of the wheel and replacing the electric cable, check with your local vac dealer or you may want to check with the Dyson dealer website and or phone # listed below:
http://www.dyson.com/homepage.asp
Contact Us
1-866-MY-DYSON
(1-866-693-9766)
Dyson Customer Care is available 7 days a week.
· Mon - Fri: 7am - 8pm, CST
· Saturday: 8am - 6pm, CST
· Sunday: 9am - 6pm, CST
questions@dyson.com
Don – The Vac Man
Go Ahead. Use Us.
Apr 08, 2008 | Dyson DC05 Cylinder Bagless Canister...
Dyson Slim DC18 All Floors HEPA Bagless Upright Vacuum - Iron/Titanium/Yellow Logo
1,346 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
