Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
I need more suction. The Head is too high on my carpet.
We have owned our dyson for less than a year and it only worked well in the first few months. Something is off. If we manually push the head or front of the vaccume down to hug the carpet we get better suction.I am dissapointed, but will be thrilled to solve this, so that our new vaccume does its job. Please help.
  • Anonymous Jan 03, 2009
    vacume
  • rrei Jan 03, 2009
    vacume dyson animal dc 07 no ajustment to lower the brush head closer to carpet for better dirt pick-up!!!!! e-mail at richardreiser@comcast.net with solution
  • 372 Answers
Hi.
A slitght adjustment can be made by either screwing on short transparant internal hose on top of floor head tighter or undoing it turn.
Do this on A table as you need to get down to be able to view sole pate movement
Each time you adjust hose stand vac up on the table & pull handle back as if cleaning carpet you must not push head of vac down on the table.
Now look at sole plate usually when they are wrong the sole plate bottom back end tilts up lifting brush from carpet.
Now tap front of head down if sole plate springs back up lifting brush up again adjust hose a bit more.
What you are trying to do is get sole plate as horizontal as you can.
If you really cant get it to pick up dirt any better try fitting new hose they are more sprigier from new,
http://dysonmanuals.llc.nu/
Posted on Jan 11, 2009
My dyson dc25 has reduced suction at the base, suction is fine at the wand
This is a guess but I have experienced it on other vacuum cleaners I have owned.
Check the hose that connects the at the base for breaks. Not just the easy to disconnect one connected to the wand, the one that goes into the head, if you are sure there are no blocks I can only imagine this being a possibility
dyson does offer a 5 year warranty if you have not past this age it might be worth sending out.
Stinks having issues with such expensive devices.
Sep 21, 2017 | Dyson DC25 All Floors Bagless Upright...
We had an older dyson vacuum that worked great until it had to be replaced and now our new one it works great on short carpet but is very difficult to push on thicker carpet.
Hi Ronnie, it's Jack at Dyson.
I'm sorry to hear you're having difficulty using your new Dyson vacuum on this particular type of deeper-pile carpet. It's possible your new machine has higher suction at the cleaner head, and this could mean it needs slightly higher push-force on certain carpets with deeper, denser pile, or thick underlay. You may find it helps to use the vacuum with the brush bar switched - carpet manufacturers will sometimes advise vacuuming deep-pile carpets in this way.
However, I would encourage you to get in touch with us directly so we can take some further details about the issue. When you have your Dyson vacuum easily to hand, please call the Dyson Customer Helpline on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU). Our experts will be happy to discuss your concerns.
We'll look forward to speaking with you.
Jun 03, 2015 | Dyson Vacuums
I have a Dyson DC44 Animal that I cannot get to work properly. It seems to have lost its suction after the first use, which wasn't that impressive. I have two cats, and when I run the vacuum over my carpet...
Hi Lauren, it's Jack at Dyson.
DC44 has twice the suction of other cordless vacuums, and we certainly wouldn't expect concerns about performance. Boost mode provides 8 minutes of highest suction power for really stubborn dirt or clinging pet hair, but for day to day vacuuming normal mode should be sufficient.
From your description it sounds like your machine may have a blockage in the floor tool, wand or bin inlet. Without suction to carry debris through the machine and into the clear bin, hair may be more likely to wrap around the brush bar. We're happy to help you check for this, and to remove any obstructions.
You may also want to wash the filter if this hasn't been done recently. We recommend doing this at least once a month, using cold water without detergent:
When you have your DC44 fully-charged and near to hand, please give our experts a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU). We look forward to providing further assistance.
Jan 12, 2015 | Dyson DC44 Animal Cordless Vacuum
Mt dyson has too much suction
Hi there, it's Jack at Dyson.
I'm sorry to hear you feel your DC40 has too much suction. This sounds unusual, and in order to help you resolve things we would need to take some further details about your machine, and the particular flooring type you're having difficulty with.
When you have your machine to hand, please call us directly so we can talk you through some simple troubleshooting checks to make sure everything is correct with your DC40. You can reach us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Sep 27, 2014 | Dyson DC40 Animal Upright Vacuum -...
Just purchased a new Dyson animal vacuum and cannot push it thru the carpeting. I have it set to the highest pile carpeting but it is impossible to push. Seems to work fine on less thick carpeting.
I'm sorry to hear you're having difficulties using your Dyson cleaner on this particular carpet. You may want to contact your carpet manufacturer to check it's suitable for cleaning with a vacuum cleaner equipped with a revolving brush. Manufacturers sometimes recommend cleaning certain types of carpeting using suction only.
If you have any further queries about using or maintaining your Dyson vacuum cleaner, please get in touch with us directly. One of our experts will be happy to provide the information and assistance you need. You can call us free on 08002980298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Dyson Online Customer Support
Sep 21, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
I have a DC32 animalpro and there is very little suction on the large carpet cleaner head. When I use another head the suction works normally. I have checked for blockages and there are none. Any...
I'm sorry to hear you're having difficulties with your DC32 Animalpro. If the turbine head doesn't seem to be working correctly, and is not blocked, you may need to wash the cleaner's filter. Under normal use, this needs to be done at least once every 3-6 months. Use cold water without detergent, and allow the filter to dry completely before replacing it - this may take up to 24 hours. For guidance on washing the filter, please see the guide linked below:
http://www.dyson.co.uk/support/help.asp?article=1847&product=DC32-ANIMAL
This should allow you to resolve your issue without further assistance, but if your problem with the turbine head persists, please get in touch with us directly. If it's necessary to replace the turbine head, it should be covered by our 5-year warranty, as long as the cleaner has been used in accordance with the terms and conditions listed in the user guide. You can call us free on 08002980298 - our Helpline is available from 7am until 10pm, 7 days a week.
Kind regards,
Jack
Sep 10, 2011 | Vacuums
The suction on my DC08 feels like it is down to 10% to what it was when I had it new. I had a similar problem about 2 yrs back and even changed the head unit. It worked fine for a few months but has...
Some of the dyson units strip down further using torx bits, sometimes the internal holes of the plastic components get clogged with fine dust that hardens, causing loss of suction. Although the filters are cleaned regularly the airflow is reducedthus giving poor cleaning power.
Aug 04, 2011 | Dyson DC08 Cylinder Bagless Canister...
My DC17 is only a few months old, but I've already had to clean the filter. Since I reassembled everything, I'm finding chunks of carpet fiber and dog fur on top of the filter inside the filter container....
Everyone needs to own an air compressor,
if you own a bagless vacuum
You blow it out every other time you use it.
Without compressed air, all vacuums will just
basically quit
May 04, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
My dyson vacuum cleaner doesn't seem to have the same suction power it used to. I have cleaned out the canister and have taken apart the vacuum head (for cleaning carpets) and it doesn't seem to be...
Hello, this is Ava with Think Crucial.
Most of the time the reason why the vacuum is not picking up is due to loss of suction. You may need to check for blockages of your wand and hose. Remove the wand and hose from your cleaner when checking for blockages and any damages. Make sure to turn off and unplug your vacuum from the power before doing this.
You can purchase a wide variety of high-quality Dyson replacement parts for your Dyson Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Mar 08, 2011 | Vacuums
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
165 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
