Question about Whirlpool Duet GHW9150P Front Load Washer
Wont cycle the machine wont go to the drain cycle..it shuts off and just gives an f code
  • Rick Ahern
    Rick Ahern Jan 03, 2009
    i learned from another post here to put the machine into a diagnostics code which in turn gave me an f2 error code..I then took off the front bottom face ( 3 star screws ) unscrewed the pump plug , cleaned it out and now it works fine.We found a lost key some change,a pen and some other stuff in the plug.I also found ..taped to the inside of the washer ... the technicians service manual :)...This all took less that an hour and probably saved me alot of cash and technician waiting time..THANKYOU FIXYA !!!
I know it's not a solution, but this happened to me before, and it was because I did a full load of straight towels.
Posted on Jan 03, 2009
I had the same problem. Unplug the washer for at least an hour and then restart. Apparently the central control unit is sensitive to power fluctuations. Plug it back in and try again. According to online posts from another site and the information/maintenance manual, if that doesn't work, you have to replace the central control unit.
Washing machine wont drain,rinse,spin,water wont drain out start a cycle but seems not to rinse,spin,drain
Could be a failed lid switch. This is a safety switch that shuts the machine off during cycles.
May 19, 2016 | Washing Machines
The water wont drain and has a code in think is'ts Cu I think its the control panel any suggestion. We accidently shut the water off during s cycle to fix a sink, since then it wont work,
Could the error code displayed be UC for a unballance detected during the start of a spin cycle?
If you remove the wash load and place the washer in a Spin Only cycle it should complete the cycle and drain the machine. You can turn on the drain pump in Service Mode also but this is the quickest way for now.
Please confirm the error code and the machine model number. If you want help to DIY the fix I can help. you but you need to move to another forum. You can't get the Service Manual from this forum and I can't find my post most of the time. This forum is not really well thought out for DIY owners.
See this post 5th post down I the issue and fix if you are taking unballance errors in Spin Cycle
You can get the Service Manual from this location........Rich
Feb 10, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My maytag bravos 580 quit working. It stopped towards the beginnging of a cycle. It kept beeping and lights went around and around the dial. It wont let me change the cycle and wont shut off unless I...
Hello & Welcome to FixYa
LD error code means long drain, you can try to check the drain hose and clean it completely. Also take out the agitator and check any stuck clothes there. After this if the problem is back then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Jan 16, 2011 | Maytag Bravos MTW6600T Top Load Washer
Holds water wont compleatly drain shuts down before spine cycle
Hello
If the washer shuts down before spin cycle it indicates that it is unable to drain properly. Please check the drain hose/drain pump filter for any clogs/blockages and try cleaning them to solve this problem. Also after cleaning check if the pump is working fine.
Kevin
Nov 10, 2010 | Maytag MLE2000 Front Load Stacked Washer /...
Washing does not go through the drain cycle, All lights flashing, cycle does not complete
Several issues could cause this, and if all lights are flashing could indicate a issue with the motherboard or that its trying to flash a mechanical code, depending on the exact model. Best reconmendation is to unplug the machine for 2 to 3 mins giving it enough time to reset. Also check the drain hose for clogs and if mechanically incline, go ahead and open the back service panel or font panel and service the pump. Possibly sounds like a draining issue which could cause this as when the water goes through the pump and if its not exiting the machine at a certain speed can send a signal to the board to shut down and flash codes.
Draketech
Oct 14, 2010 | Kenmore 44102 Front Load Washer
Have an affintiy front loader that wont do its final spin. Passes all the diagnostic tests that comes with the machine but when timer goes from 6 min left it just shuts off and gives the end of cycle...
there may be something blocking the drain pump.if you have standing water in the tub use a wet dry shop vac and attach it to the end of the drain hose to remove the water.
once you remove the water check the drain pump for obstruction the main drain boot the comes from the bottom of the tub to the pump make sure everything is clear.
If you do not find anything then there is a chance that the door lock mechanism is faulty
Jun 02, 2010 | Frigidaire ATF6000ES Front Load Washer
Washer stops after aggatating and wont drain
My Kenmore 70Series washer goes through the wash cycle then just stops when it is to drain and then spin.
Jun 10, 2009 | Whirlpool Washing Machines
Miele G 7856 Commercial Dishwasher
Hi. The above machine stops mid cycle and drain/fill light is on, also error code F3E, have cleaned both hot and cold water inlet filters, also checked drain pump and drain line, all ok. Machine drains with no issues and fills with hot water, runs for a while then shuts down.
Any ideas?
Aug 20, 2008 | Miele 24 in. G638 Plus Free-standing...
Washer code
the drain sump area is clogged axcess through front panel. F02 is telling you its taking too long to drain the water pretty soon it wont drain at all.
Sep 29, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
