Question about Dryers
My dryer was making a horrible scrubbing noise and now won't dry
My 14 yr. old Maytag dryer made the same type of noise. It was the fan. The plastic had broken loose around the shaft. As the shaft turned fast, the fan turned more slowly, hence the noise. Replaced the fan ---- perfect drying and no noise. $26.00 for new fan.
Posted on Jan 02, 2009
Dryer makes loud rattling noise while drying
How old is your dryer? My dryer was making a horrible rattling noise and it turned out to be the idler pulley.
Sep 19, 2016 | Kenmore Elite HE4 Electric Dryer
Whirlpool duet dryer makes a horrible grinding noise while running. Clothes still get dry but drives us insane!
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jun 29, 2011 | Dryers
My dryer is making a horrible noise when turned on and then when the cycle is stopping. the noise continued to happen then began going through the whole time cycle. The dryer is getting hot but it is not...
heatman101
Jun 17, 2011 | Crosley CDE6000 Electric Dryer
My Maytag Performa dryer is making a horrible sound...still working though. Wondering if it is a belt?? Can I fix myself?
go to Sears and purchase the belt with an idler pulley with it. It comes as a kit. The pulleys bearing has dried out bearing that went flat in spots which causes this horrible noise
the top and the front of your dryer needs to come off to access these parts
Jan 13, 2011 | Maytag Dryers
Dryer makes a scrubbing noise then stops
heatman101
djdgh
Jan 17, 2010 | Whirlpool LER4634J Electric Dryer
Makes a horrible noise. Seems to dry fine but before its done it sound like it going to explode.
The blower wheel may be stripped out or broken.
This will cause a loud rumble noise while operating.
Jan 16, 2010 | Maytag PYE2300AY Electric Dryer
The tub is making a scrubbing sound as it dries any idea what might cause this?
Could be your drum rollers needing lubrication.
They will make a thumping noise when the wheels are flat, a squealing/scrubbing noise when they need lubricant.
Also could be you drum rubbing on the felt seal at the mouth of the drum, the seal might be loose or worn
Sep 27, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer making horrible squeeling noise
this is normally a problem with rollers that have gotten dry bearings , take the drum out check the rollers if they turn hard or act sticky you may clean them up and and oil with turbine oil , do not use wd-40 or 3in 1 as these will dry the bearing, check the idler pulley while you have this apart also oiling it if need be
Dec 30, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Horrible noise
The noise could be coming from the blower housing, as this unit does not have bearings, it does have 4 rollers however. If the unit is working on timed dry and not sensors there may be a problem with them. Check your venting though, if it is too short it may not have enough back pressure for the sensors to operate properly. This could also cause your thermosats to blow, the one is a manual reset, either way you are going to have to get a gas tech out there.
Sgt 48
May 30, 2008 | LG DLG5988 Stainless Steel Gas Dryer
Dryer noise
open the door and if u can lift the drum up or down more than an inch the drum bearings are worn out. big job to repair unless under warranty.
Feb 07, 2008 | Dryers
Dryers Logo
147 people viewed this question
Top Dryers Experts
