Question about JVC 5CD FRONT LOAD CHANGER REM CD Player
NO SOUND FROM SPEAKER
I had a JVC CD player installed in my car in June 07 by a auto-electrician. Everything worked perfectly untill the car went for a service and they worked on the clutch (detaching the - terminal of the battery). After I got the car back, i couldnt get any sound...? The whole system works perfectly ( switch on, load cd's, play them, search radio stasions, skip songs, adjust volume) BUT NO SOUND AT ALL. I removed the whole system to check all the connections at the back ( the atenna, i think it is, and the little box carrying all the different wires). They all seem perfectly attached. We stay in Bonnievale, making it diffucult for me to reach a pro!! Could u please guide me to what might possibly be faulty?
Thank you so much!
Regards
Jacques Liebenberg
    President:
  • 196 Answers
One speaker cable to ground.check the front left speaker wire. 100% this is the problem.
Posted on Apr 28, 2010
My jvc kd-g820 will not produce any sound and not accept cd
try to find the reset a little indent on the face or hole when you remove the face and push in for 2 to 3 secs with a pen or paper clip. Then try your cd again. Still dont work check to see if you have another cd jammed inside and your trying to put two cds at once.
Ok for your no sound problem. a bad speaker, short speaker (one 1 speaker shorts out all will not work cause the radio is in a protective mode), factory amp needs to be turned on, bose system or amplified system in car needs to be rewired to bypass factory amp), buy special car harness to make factory amp compatible with aftermarket radio, late ford models the back speakers are crisscrossed.
Next time please give car info and type of system you got in it so I could narrow down the possible problems a little bit easier.
Apr 08, 2010 | JVC KD-G820 CD Player
Ihave a JVC G230 and there is no sound
you have one speaker that has a short, a good way to find it quick is turn radio off and on if any of them pop even the slightest that is where your problem is...if you dont hear a pop check that all wires are not touching a ground somewhere this send the unit into protection, just one speaker or wire will do this .it keeps the radio from burning up...
Nov 27, 2008 | JVC KD-G230 CD Player
Cd keeps ejecting
use a product called cd kleen it.you can find them on ebay.they take care of problems like this.
Sep 06, 2008 | JVC Arsenal KD-S6250 CD Player
No Sound Through Speakers
Hi Jake,
If you haven't done so already, I'd try double checking the speaker wiring, you may have some exposed or badly kinked wires behind the unit.
Cheers,
Matt Coyote
Feb 20, 2008 | Car Audio & Video
No SOund
cheak sound output settings and cable to pcm not dolby digital
Feb 02, 2008 | JVC DR-M10SEF DVD Recorder
JVC KD-LH300 no sound on cd or radio anymore
was there a pop or anything, if so it could of been the audio chip in the radio,
also depending on the type of car, does it have f factory amp to? best way to troubleshhot this is if you have a seprate speaker you could hook up to a lead off the back of a deck :-)
Jan 03, 2008 | JVC Sirius KD-LH300 CD Player
At high volume sound shuts off, subs still work
You most likely have a shorted or damaged speaker, which is causing the internal amp chip to shut down (but does not affect the preamp outputs). A test you can do is to fade to one speaker at a time and turn it up to se if it shuts down. Repeat with each speaker until you find the one that causes the fault. Then replace it.
Dec 08, 2007 | Pioneer DEH-2100 CD Player
Installing
You should test all of the speaker wires by putting the negatieve wire (the ones with the stripes) to the negative end of a AA battery and the positive wire to the positive end. You will hear a light, high pitched noise if the speakers are working correctly.
Nov 30, 2007 | JVC KD-G210 CD Player
JVC 5CD FRONT LOAD CHANGER REM CD Player Logo
160 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
