Question about Fuji FinePix A500 Digital Camera
My a510 finepix wont work on windows vista!
I have just bought the A510 fine pix and i have windows vista. when i have tried installing it, it says i need windows xp. Surely there is something i can download for it? Help!!
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Fuji Master
  • 102,366 Answers
You don't need any software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Windows Photo Gallery or Picasa.
Posted on Jan 01, 2013
t00nz
  • 4738 Answers
SOURCE: canon digital camera power shot A510
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Feb 10, 2008
old marine
  • 2039 Answers
SOURCE: How do I use the
Press the Function button. Use the down button to go down to 'Drive Mode' on the left side of the LCD. Use the right button to select the clockface with 2 or 10 (2 second or 10 second delay). Be sure to set back to single shot after you're done using the self timer!
Posted on Apr 20, 2008
  • 12 Answers
SOURCE: fuji finepix a510
Check out this link: www.digitalcamera-hq.com/digital-cameras/fuji-finepix-z1_question.html?qid=4289
After the basics, try dropping the camera on a carpeted area from about 2-3 feet. It worked for my Fuji A500 and 90% of the responders on the link. Everything on the web said it would cost ~$100 to fix. I was in the process of researching new cameras to buy and had nothing to lose by dropping it on the floor.
The error may be caused by debris in the zoom mechanism preventing it from working. Dropping the camera loosens the debris and voila!
Posted on Jul 07, 2008
SOURCE: Canon A510 As webcamera
can i use canon power shot a510 how web camera??
Posted on Jan 19, 2009
t00nz
  • 4738 Answers
SOURCE: Canon Powershot A510 black screen when taking photos
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Posted on Jun 20, 2009
Fuji FinePix A510, DPC-256 memory, card not initialized msg
I had to re-format the card losing all the photos but I had saved them in iPhoto so that was ok. I think the problem was caused by me incorrectly closing down after downloading them to iPhoto, so my fault and lesson learned.
Jan 07, 2010 | Fuji FinePix A605 Digital Camera
Canon Powershot A510 - black screen
well giving it a tap/thump it might have a dry joint ....
Sep 14, 2009 | Canon PowerShot A510 Digital Camera
Can't format memory card in A510 Canon digital camera.
Have you used this card in the past? Is this a new card?
Is this card rated to be used with this camera. Some cameras can only support cards of certain sizes.
If the card is compatible, take the card to target or best buy and format it on a camera there and see if it works then put it back in your camera and see if it works after.
Mar 07, 2009 | Canon PowerShot A510 Digital Camera
I am
Possibly. How much is free? Id delete any files that are already copied.
Also, did it find any problems and did you check "automatically fix file system errors"?
Thanks.
By The Way/ It is possible that it's corrupted beyond help...
Aug 14, 2008 | Canon PowerShot A510 Digital Camera
Intel d101ggc p4
please download ur motherboards as well as hp 510 photosmarts drivers from internet after it only ur all device will work..
hero302
Apr 25, 2008 | ASUS K8V-MX Motherboard
A510
Fuji USA does not offer the Finepix software as a free item on their website. The upgrades can be downloaded though. Here is the driver link for the A500:
http://www.fujifilmusa.com/JSP/fuji/epartners/ServiceSupportProduct.jsp?prodcat=842411
The United Kingdom site has the drivers for the A510:
http://www.fujifilm.co.uk/consumer/digital/digital-cameras/legacy-cameras/finepix-a510-zoom/support
Jan 08, 2008 | Fuji FinePix A500 Digital Camera
Fuji FinePix A500 Digital Camera Logo
56 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
