Question about Microsoft Office Professional 2007 Full Version for PC
Opening 2007 microsoft windows office word document
I am having problems opening my files in "Word" that I previously saved. The program will start to open and then do nothing before the program then shuts down.
I have removed the program twice and reinstalled it and continue to have the same problem.
Any suggestions?
  • 679 Answers
That may be the problem right there. If you re-install some of Microsofts programs more that 1 time, they may have blocked you from installing it again. Run a windows update and look at the results, if it is saying that it had a problem with the autenticity of the program . I copied the following from a msft forum for you,
Re: How many times can you install Office 2007 on diff. comp?
if you were to look on the box, you would see that it can be installed off the original disk three times. not sure what one would do after that... might want to call m.s. and see if they have an extension or if you have to rebuy it. bought mine and installed it on the xp machine till it died due to sp2 and then reinstalled onto the new vista os. still have one left, i guess... in any event, m.s. will be happy to answer a question or two from a customer... opening 2007 microsoft windows office word documen - smile.gif
Posted on Jan 02, 2009
    Genius:
  • 1,011 Answers
Sir,
Click this link for information related to your problem.
The problem you're having with Word can be fixed by deleting a file named "normal.dot" (without the quotes) which can become corrupted.
First, make sure hidden files are showing by opening My Computer, going to Tools>Folder Options>View tab and check the box for "Show hidden files and folders," click OK.
Next, with Word closed, go to Start>Search and type "normal.dot" (without the quotes) in the "All or part of the file name" box, make sure "Local Hard drives" is showing in the "Look in" box and tell it to search.
If it doesn't find any, over in the left-hand pane of the Search window, click on "More advanced options" and put checks in the boxes for "Search system folders," "Search hidden files and folders," and "Search subfolders," then run the search again.
Right click on all instances of "normal.dot" it finds and left click on Delete. Word will make a new "normal.dot" file when you open it.
Thanks
good luck
  • Microsoft Master
  • 13,433 Answers
Try opening the files on another computer, are the files saved in office 2007?
What happens when the office turns off do you get a error message? are you able to turn office on at all? do'nt try to open a file just turn word on, what happens?
How do you scan a document to MS-Word?
You actually have 2 options.
First Option: (You can also see the instructions here.)
How to Turn a Scanned Document Into Microsoft Word Document:
1)Scan the page you want to convert into a Microsoft Word document.
2)Save the scanned image in *.gif, *.jpeg or whatever format.
3)Open that image, go to "File->Save As" and name it "xyz.tiff" in the "TIFF" format as shown.
4)Go to "Start->Programs->Microsoft Office Tools->Microsoft Office Document Imaging"
5)Go to "File->Open" and open your scanned document that has been saved in *.TIFF format.
6)Go to "Tools->Send Text to Word." You will get a prompt stating this process will take time, Click OK. This will take some time depending on your computer's speed (a minute or two at the most).
7)When it's done it will open up Microsoft word on its own and the scanned document will now be in editable mode.
Second Option: (You can also see the instructions here.)
Install Microsoft Office Document Imaging:
Follow the instructions based on the operating system that your computer is running.
For Windows Vista Users:
1. Exit all programs.
(Tip You may want to print this topic before you exit all programs.)
2. Click the Start button Button image, and then click Control Panel.
3. In Control Panel, click Programs, and then click Programs and Features.
4. Right-click the name of the Microsoft Office edition that you installed or right-click Microsoft Office Word 2007 (depending on whether you installed Word as part of Office or as an individual program), and then click Change.
5. Click Add or Remove Features, and then click Continue.
6. Under Installation Options, click the plus sign (+) next to Office Tools.
7. Click the arrow next to Microsoft Office Document Imaging, click Run all from my Computer, and then click Continue.
For Windows XP Users:
2. Click Start, and then click Control Panel.
3. In Control Panel, click Add or Remove Programs , and then click Remove a program.
4. In the Currently installed programs list, click the name of the Microsoft Office edition that you installed or click Microsoft Office Word 2007 (depending on whether you installed Word as part of Office or as an individual program), and then click Change.
The Configuration Wizard opens.
Create a document that you can edit
Scan your document according to the instructions for your scanner.
Before you continue Convert the file that the scanner created to TIFF format. You can use Paint or another program to convert the file.
1. Open Microsoft Office Document Imaging by doing one of the following:
In Windows Vista Click the Start button Button image, click All Programs, then click Microsoft Office, click Microsoft Office Tools, and then click Microsoft Office Document Imaging.
In Windows XP Click Start, click All Programs, click Microsoft Office, click Microsoft Office Tools, and then click Microsoft Office Document Imaging.
2. On the File menu, click Open.
3. Locate the document that you scanned, and then click Open.
4. After Microsoft Office Document Imaging runs, press CTRL+A to select the entire document, and then press CTRL+C.
5. Start Microsoft Office Word.
6. Click the Microsoft Office Button Button image, and then click New.
7. Click Blank document, and then click Create.
8. Press CTRL+V to paste the contents of the scanned document into the new file.
You now have a document that you can edit. Be sure to save the new file so that you don't lose your changes.
Hope this helps!
Apr 06, 2011 | Office Equipment & Supplies
Tip
Computer Tips: Open Office 2007 Files into Office 2003
How to open office 2007 files into Office 2003?
Today tip will help you to resolve the compatibility issues between the Office 2003 and Office 2007. Because all programs in office 2003 used the old file extensions for its different programs. For example Word 2003 saved files with extension .doc, Excel 2003 with .xls and PowerPoint with .ppt. but on the other office 2007 used the new file extensions for its different programs. For example Word 2007 saved files with extension .docx, Excel 2007 with .xlsx and PowerPoint with .pptx. Now the problem is that when you will try to open office 2007 files into office 2003 and you will not open the file due to compatibility issues between both office versions. Microsoft provides a free compatibility pack to convert office 2007 documents to the office 2003 format. There are many third party free converter are available but here we are using Microsoft office compatibility pack.
Follow the given steps to download free Microsoft compatibility pack and install it.
To use this feature, you will need to be logged into your computer with administrative rights.
Visit the following link to download the Microsoft compatibility pack:
http://www.microsoft.com/downloads/details.aspx?FamilyId=941b3470-3ae9-4aee-8f43-c6bb74cd1466&displaylang=en
When you have downloaded the file, double click on FileFormatConverter.exe file to start the installation.
7154964.pngNow here it’s simply a case of pretending you’ve read the license terms and clicking continue.
Now click on OK button to complete the installation.
on Mar 08, 2010 | Computers & Internet
I cannot open .docx and xlsx files.
The files extensions you have listed, .docx and .xlsx, are files that have been created using the Microsoft Office 2007 or 2010 suite of programs. Specifically .docx is a Microsoft Word document, and .xlsx is a Microsoft Excel spreadsheet. You will have to have either of the Microsoft Office programs mentioned, or you can also use the Open Office suite of programs. This is a free program that you can download at the following website:
http://www.openoffice.org/
Mar 05, 2011 | Microsoft Windows XP Home Edition
I have Microsoft Office 2007 which I purchased from Dell and installed late last year or earlier this year, however, the Excel keeps getting lost and I cannot open documents which I have done or received...
Use http://www.magicaljellybean.com/keyfinder/ to find the serial number. As for the corrupt Excel program, you may need to determine what exactly is the problem there.
Go to Start, All Programs, Microsoft Office and see if Excel is listed. If it is, then click on it to launch it. Does it open? If so, then go to where your excel spreadsheets are saved to (e.g. My Documents) then right click an Excel spreadsheet & click on "Open With". Select Choose Program. Select the Microsoft Excel. If Excel is not listed, click the browse button and browse to C:\Program Files\Microsoft Office\Office12. Click the Always use the selected program to open this type of file checkbox. Click OK
Nov 26, 2010 | Microsoft Windows XP Professional
Window 2007 files not open
Microsoft uses a new document format by default in Office 07 (.docx instead of .doc). A lot of people have ran into this problem, mostly because Microsoft didn't even care to tell you. They also fail to let you know that you can still save documents as .doc to ensure compatibility with previous versions of Word.
What they do offer though, is a converter (in the form of an update/patch) so you can open your docx files in previous versions of Office.
Click on the link to get it.
http://www.microsoft.com/...
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Sep 25, 2010 | Microsoft Office Professional 2007 Full...
What is the meaning of X in the word DOCX?
The X stands for XML (Extensible Markup Language), which is the programming language behind the scenes in Office 2007 programs.
Previous versions of Word were based on binary data. Binary data is, by nature, prone to corruption, and "bloated."
By changing the background code, Microsoft was able to create new tools and features in Word 2007 that would not have been possible otherwise.
Jul 29, 2010 | Microsoft Windows XP Professional
Microsoft Home and Office Student product key
Your program (ms-office) has been upgraded to Office 2007, and so you are asked for the License key. If you would like to use it, your only means is to uninstall the program and again reinstall your program. And remember if you don't like to upgrade to office 2007, don't install additional upgrades. There's a problem when you open an office 2007 on your previous version, but you can solve it by telling to those who send files to you. Let them save the file in the previous version format, if they save it in the office 2007 format, you'll not be able to open it. The file extension of previous version office is .doc but the new version has .docx, they can still save it in .doc format. You can convert .docx format using converter, but i don't recommend, you might loose formatting. Good luck. Thanks for using FixYa.
May 29, 2010 | Microsoft Office Home and Student 2007...
I got MS office 2007 uninstalled and MS office 2003 installed now word documents doxc ,Wps files do not open .How to recover them?
To open Microsoft Office Word 2007 .docx or .docm files with Microsoft Office Word 2003, you need to install the Microsoft Office Compatibility Pack for 2007 Office Word, Excel and PowerPoint File Formats and any necessary Office updates. By using the Compatibility Pack for the 2007 Office system, you can open, edit some items, and save Office Word 2007 documents in previous versions of Word.
Apr 05, 2010 | Microsoft Windows XP Professional With...
Please let me know how to Operate Function keys on the Key Board (Teclado Intel A27982).
Close F6: Closes the document or the file in the active window. Forward F8: Forwards the e-mail in the active window. Function Lock (F LOCK) Switches between the standard function key commands (F LOCK light on) and the Microsoft keyboard enhanced commands (F LOCK light off). Leave it on or off, or alternate between modes for increased key press functionality. Help F1: Opens the Help system for the active window. New F4: Creates a new document in programs that support this command. Office Home Starts the Web browser and goes to the Microsoft Office Web site. (This is not available on all keyboards.) Open F5: Opens a document in programs that support this command. Print F12: Prints the file in the active window. Redo F3: Cancels the previous undo action. Reply F7: Replies to the e-mail in the active window. Save F11: Saves the file in the active window. Send F9: Sends the e-mail in the active window. Spell F10: Starts the spell checking program in the active document, if the document's program has this feature. Task Pane Shows or hides the Office task pane that was previously displayed. (This is not available on all keyboards.) Undo F2: Cancels the previous action.
Jan 05, 2010 | Intel Dot Station (INTC300AIO) PC Desktop
In which we can open .docx files
You can open docx extension files only with MS Office 2007. If you wish to open it in earlier versions you have to save it again in compatible mode. Click on File (top left most corner with the logo), Save As, Word 97-2003 Document. Just using Save option will save your document as "docx" and not "doc" document.
Aug 30, 2009 | Microsoft Windows XP Home Edition
Microsoft Office Professional 2007 Full Version for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
