Question about Rancilio Rocky Espresso Coffee Grinder - Doser
Replacement portafilter holding fork
Need a part for rancilio rocky coffee grinder
  • Sulejman Sulejmani
    Sulejman Sulejmani May 11, 2010
    tell me you country please to tell you nearest part shop.
  • 137 Answers
I will give you one web adress, i hope it is near you.
Posted on Mar 30, 2009
Our Silvia, almost 8 years old, is putting out shots too fast (10 to 15 seconds), even though we've been dialing down the grind on Rocky more fine, putting more coffee in, and tamping harder. We...
Try to redo what you have been doing, but set it to the extremes to see if everything is functioning. If you set the grind say to 4, it should come out very slow or maybe not at all.
Jul 11, 2011 | Rancilio Silvia Espresso Machine
Rancilio Rocky w/ doser: clean sweep of coffee grounds
The Rancilio Rocky coffee grinder is a superb, highly recommended machine, but its doser is pretty useless in the home. First reason: you want to grind coffee instants before you brew or pull your espresso shot; otherwise, the grinds just lose aromatics and flavor. The doser only works for multiple doses, so you're better off just grinding the amount you need each time. If you're buying a Rocky, get the doserless model.
If you have the doser model, like I do, you also find that the vanes which sweep the coffee into your portafilter or cone leave a layer of grounds on the doser floor. If not cleaned out, they turn rancid. There are coffee web sites with fairly complicated instructions on how to modify the vanes to do a clean sweep. Here's the simple way:
Flip up the doser cover, and spin the vanes while pressing your finger lightly on the outer top edge of one vane. The vanes have enough play so the pressure brings one into light contact with the doser floor, sweeping 99% of the grounds into your waiting portafilter.
on Jan 03, 2011 | Rancilio Rocky Espresso Coffee Grinder -...
Doser on Rancilio has worn (I'm guessing) to the where the "ratchet" mechanism doesn't always move forward but hangs and I have to go in and manually turn the vanes. I tried to take the...
Hi There is a spring that holds tension on the paul (ratchet) underneath that is broken. You need to replace the spring. Remove the plate on the bottom of the doser to see the paul and spring. The spring is flat on most Rocky's.
Jul 02, 2011 | Rancilio Rocky Doser Espresso Grinder...
Coffee exits portafilter too quickly. Rocky grinder with burrs set as close as possible. Grinders and rubber recently replaced.
Sounds like your group handle needs a new basket (the piece with all the small holes in it). Presuming that grind is set correctly and that coffee is being tamped enough? Sometimes as the basket gets older, the holes can get larger and coffee doesn't have enough time to infuse with the coffee before exiting.
Mar 30, 2011 | Rancilio Silvia Espresso Machine
The coffee comes out in little logs or clumps. The coffee is weak- no crema.
There are 2 things that can cause this. Either the burrs are bad and need replacing or you grinder is out of adjustment and you need to turn to a finer grind. If you have taken it apart, you are not adjusted close enough so your burrs can't grind fine enough. Readjust the burrs closer together.
Oct 11, 2009 | Rancilio Rocky Electric Burr Grinder
I have a Rocky Grinder. The spring that pulls the
no, dont worry. Just return the lever by hand. Replace the spring and it will break again. It is a hassle to replace and not having it will not affect the function
Sep 19, 2009 | Rancilio Rocky Espresso Coffee Grinder -...
Not fine enough for espresso
solved please donate on my paypal account to get the answer
Jul 09, 2009 | Rancilio Rocky Espresso Coffee Grinder -...
Rancilio rocky grinder setting
to get starting point you adjust burrs to touch each other. when they touch each other you have finest grinding, after you hear metal voice you turn back 3 dots and grind only for 1 dose. you check it, if it goes to slow, you go one more back and clean gruinder, THAN you grind 1 dose more. 2 or 3 times and you will get perfect grinding.
Mar 28, 2009 | Rancilio Rocky Espresso Coffee Grinder -...
Rocky Calibration
  1. replacement of burrs after 500 kg grinded coffe
  2. if upper burr holder and the body of grinder does not hold stabile, teflon aplying does not help too much, it is only temporary solution. new upper bur holder would do better.
  3. before inserting upper burr holder you should check if lower burr is rotating syncronized, you should take a bit chalk and sof touch while burr rotates. after that you stop grinder and look do you have circle with same thiknes, that would give you idea where is the problem, if it is in lower burr.
Apr 07, 2008 | Rancilio (RAROCKYND) Grinder
Coffee Makers & Espresso Machines Logo
160 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
Level 1 Expert
Craig Butler
Craig Butler
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
