Question about Porter Cable Cable 12" Compound Laser Miter Saw 3802L
Porter cable 3802L laser not working
Porter cable 3802L laser is out. Trying to find out if replacing the power supply is the way to go (<$50) but not finding any 'known issues with saw. Local tool repair will price repair & part at least at $150.
karmacanic
  • 16 Answers
SOURCE: Older Porter cable circular saw blade removal
Clamp a pair of vise-grips onto the blade to act as a blade-lock to stop rotation of the blade.
Posted on Oct 27, 2008
roniecon
  • 6927 Answers
SOURCE: no air pressure thru quick connect to tools-bag regulator?
I dont know if it is like mine,but if you can let the air out of it and remove the regulator knob,and it`s components,you may can set it to just to be open all the time,in other words,by pass the control knob valve.Shout back at me if I can help.
Posted on Nov 06, 2009
Mentorcase
  • 5 Answers
SOURCE: Can't take off front off porter cable tiger 747 (rubber boot
Remove 2 screws from under front grip and the swivel foot should slide forward and out (might need a bit of a twist to loosen) plastic grip should now slide forward and off.
Posted on Dec 08, 2009
  • 1388 Answers
SOURCE: I have a Porter cable 18 gauge nail gun. I think
Check the parts breakdown for your model and see if seal #894737 is listed. This seal is cause of problem that you describe. It is included in the rebuild kit or available separately. If this seal is not listed, then problem is fine scratches on oring contact surfaces in head. Use magnify glass to examine surface and remove fine scratches with 400 grit paper. Apply silicone paste lube to all surfaces that contact orings and seals. (Silicone lube is available at Lowes in plumbing department, used for faucet orings). Parts for gun are available at Dewalt service center or at www.toolpartsdirect.com. Good luck with your repair.
Posted on Aug 31, 2010
woobie dog
  • 1273 Answers
SOURCE: Our porter cable 5500 starts but doesn't put out
reset the circuit breaker on the panel, and try again.
--W/D--
Posted on Jan 31, 2011
Need a power cord for a porter-cable circular saw model 146
All of Porter-Cable's circular saws have model numbers starting with a 3. Assuming your saw is a 346, Porter-Cable's part number for that cord is 330079-98. If your model number isn't 346 or you can't get that part number, most any nine to twelve foot 14-2 power cord will work on your saw.
Feb 24, 2013 | Porter Cable Saws
Will not cut 45 miter cuts perfect
Possible but I would think not likely
Try this
Put a new blade on
Set a magnet on the table or fence with phillips screw driver stuck to it
Slide the point of the screw driver up to within 1/16" from the blade just above the teeth
Run the unplugged saw by hand and watch for any side to side movement of the blade
Can you move the blade up and down or side to side?
If everything seems normal the plug the saw in and run it again watching the screwdriver
Please be careful don't allow the screw driver to contact the blade at high speed you will create a bullet
Mar 10, 2010 | Porter Cable Cable 12" Compound Laser...
Dec 07, 2009 | Porter Cable Variable Speed All-Purpose...
Change the blade on my porter cable 347
Here is the owners manual for your saw. It details the procedure for removing and installing a blade.
Please rate this positive if it helps!
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/Porter-Cable/En900003.pdf
Jul 03, 2009 | Porter Cable Cable 7 1/4" Quik - Change...
Variable speed quit working
You would need to replace the switch, give me a model number and a location with zip code and I will try and find one locally for you, Its not that hard
Apr 25, 2009 | Porter Cable Variable Speed Quik Change...
No recip on Porter Cable 647 saw
In a manner of speaking, the problem solved itself. The required parts are obsolete with no replacement and no source for the originals that I could find. The saw will soon be gracing the landfill, and I will not be purchasing any more Porter Cable products.
Apr 10, 2009 | Porter Cable Saws
Porter Cable Cable 12" Compound Laser Miter Saw 3802L Logo
209 people viewed this question
Top Porter Cable Saws Experts
Frank Mangiapane
Level 1 Expert
Jim Thurston
Are you a Porter Cable Saw Expert? Answer questions, earn points and help others
