No power to VCR
Hi- I love this VCR, but it doesn't power up or even light the LED when plugged in. Hate to toss it when it's been so good for past decade, but before i attempt repair was wondering if this is fixable or whether parts are easily obtainable.
Thanks
Zenith VRC4225HF (circa 1995)
First place I'd look is the fuse. Take the top off and there should be a fuse located near the AC power supply. If it's blown try replacing it. Make sure you replace it with the same value though.
Be prepared for it to pop again though - often when they blow it's because there is a more serious issue further downstream.
Good luck! :)
Posted on Jan 04, 2009
My Magnavox VCR/DVD combo groans when I set the timer recording. It doesn't make the noise when I turn it off.
I hate to sound elitist or negative, but VCR is over, much in the same way that cassette tapes are over. It is even getting hard to find DVD recorders which stand alone. Additionally, I would urge you to record all of your home movies and significant recordings to DVD while you can. VCR tapes degrade pretty rapidly compared to DVD. And now, even DVD is on the way out. Get up to speed. You'll be glad you did!
Jan 18, 2018 | Magnavox DV225MG9 DVD Player VCR
Wii power light is flashing red
Wii red light going batty flashing like every 1/3rd of a second, and it will not turn on. I FIXED MINE BY UNPLUGGING EVERYTHNIG CARDS, CABLES, FROM EVERYWHERE, AND REMOVE SDCARDS ALSO, AND DISCS, BOTH GC & WII CARDS, SENSOR BAR PLUG, POWER Plug *ALL THAT'S PLUGGED OR INSERTED... Now i plugged everything back in ACCEPT Not Sensor PLUG To back of wii, then the light quit (This is after 4 min break all undone...) And then plugged the Sensor plug and THEN as i finally plugged in the POWER Plug I first held the SYNC red button on the Wii, and then plugged it in and WAH-LAH Isue Resolved Immediately, KUDOS for the hints Cheerz & Peace Love Banish Fear/ hate to not even give it thought in root thoughtfulness.!. www.fb.com/stanleydeanparker/
Dec 29, 2012 | Nintendo Wii Console
I have a remote oneforall i need codes for a SHARP VCR please help need codes
There are two codes for Sharp. You'll have to try both to see which one works. 0048 & 0807. I am assuming you don't have a manual.
On the remote press and release the VCR/DVD button. Press and hold the SET button until the LED blinks twice. (it will blink once when you first press it, that doesn't count.) Just wait a few seconds. After it blinks twice, release the SET botton, and enter the CODE..
The LED should blink twice. Aim the remote at your VCR and press
POWER.. The VCR should turn on. If not, try the other code.
0048 worked on mine. Good Luck!
Aug 15, 2011 | Universal Remote Control Remote Control
The printer is frozen, all the lights are on, even the led nuber is lit up as 8 (all parts of the led). the power button does not work. Unplugging it and plugging it back in makes no difference. What is...
I hate it when I post a problem and nobody has posted a solution! We had this same thing happen to our F2210 deskjet twice in one week. Both times were the result of a power failure. We thought it was fried, but after about 36 hours of sitting there, we unplugged it and plugged it back in and it came back on!
Dec 27, 2010 | HP Deskjet F2210 InkJet Printer
I need help to get a code for my sanyo tv and how to set it up.
Hi
Configuring codes:
1.Turn on a desired device (VCR or DVD player)
2. On the remote control, press a device key once (i.e., DVD/VCR,
CBL/SAT or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo, or TV/VCR/DVD Player Combo press DVD/VCR once. After programming a VCR Combo device, you will be able to control channel selection,volume, and VCR functions.
To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD/VCR once. After programming a DVD Combo device, you will be able to control channel selection, volume, and DVD functions.
To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer’s Codes to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly,
the LED will blink twice.
5. Aim the remote control at the device and press POWER once. The device should turn off. If it does not, repeat steps 2 to 5, trying each code for your brand until you find one that works. If it still doesn’t work, try Searching For Your Code on next page
Auto Code Scan:
1.On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice, then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly press POWER button.Stop when the TV turns off
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 to 5, but substitute the appropriate device key for the device you are searching for.
Code for sanyo tv is 0154
Thank You
Sep 13, 2010 | One For All URC-3021 Remote Control
I need to program the one for all URC-3021B00 to my sony tv
Configuring codes:
CBL/SAT or TV).
then release SET.
Auto Code Scan:
blink twice.
Code for sony tv are 0000, 1100, 0810
Thank You
Dlink DIR-625 Doesnt work. Power light blinks when plugged in
hi.. all,
i am facing the same issue.. my new DIR-615 , when plugged with power cord ... make the power led blink continuously... and hence so, no network is accessible neither wifi works in simple terms noting works, no combination of power cord with network cable with computer works.
i have even tried resetting using the reset button.. but still the power button keeps blinking.
and yes it was working in past, its a brand new product(3 months old).
Please help and its urgent..
thanks a lot for your help..
Regards
Dharmendra
Nov 25, 2009 | D-Link DIR-625 (790069292637) Wireless...
Tungsten E will not get past Tungsten screen to sync.
Hate to say this but, back it up and toss it.
Nov 01, 2008 | Palm Tungsten E Handheld
E2 error
Just had the same E2 come up on my HSU-445. The only thing we could figure out was to try a different tape than the one that was in there when the error came up. That seemed to do the trick. Not sure how long that will work. Good luck.
Jan 11, 2008 | Mitsubishi HS-U445 VHS VCR
Won't Charge Any Battery--Even a New One
Check for loose solder connection in the power supply and the terminals that connects the battery to computer.
Sep 03, 2007 | Gateway 450ROG Notebook
Televison & Video Logo
294 people viewed this question
Top Televison & Video Experts
