Question about SanDisk Sansa Clip MP3 Player
1GB sansa clip mp3 player will not turn on
It will only turn on when connected to a computer via the usb cable
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jan 09, 2009
Sansa clip music uploads but I can't locate it on clip
MP3 players can only play music files in mp3 file format.You can download mp3 music files from the Internet toyour computer and then copy them to your MP3 player using the USB cable.For your CD collection, you need to convert your CDs tomp3 music files onto your computer or download them from the Internet and thencopy them to your MP3 player after you have connected the USB cable tothe MP3 player and the computer.
You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track.Click on this link for instruction on converting musicfiles to mp3 file format :- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
May 16, 2012 | SanDisk Sansa Clip MP3 Player
My sansa clip mp3 player wont come on
Connect the Sansa to your computer via yoru usb cable.
Press and hold the Power On button and the Play button (>||) for 20 seconds
Jan 07, 2010 | SanDisk Sansa Clip MP3 Player
I NEED TO KNOW HOW TO DOWNLOAD TO THE SANSA CLIP MP3
First, connect your SansaDisk to your computer via the USB cable. Secondly, open your Windows Media Player. You can sync the musics from your Windows Media Player to your MP3 player.
Dec 24, 2009 | SanDisk Sansa Clip MP3 Player
Sandisk sansa mp3 - port power limit
Try unplugging a few of your other USB devices,
Apr 21, 2009 | SanDisk Sansa Clip MP3 Player
My sanDisk Sansa Clip MP3 Player will not charge anymore. At least not on the computer I'm on. I have had it hooked up to charge for 2 days now and nothing. Why is this and how can I charge it?
This is direct from the sansa FAQs at http://www.sansa.com/support/sansa_clip/faqs 02. Why won’t my Sansa Clip charge when I connect it to my computer? USB Cable
Make sure that the USB cable is properly plugged in and use the original cable.
Computer in Hibernation mode
Make sure that the computer isn’t entering hibernate or sleep mode while the device is connected. The computer must be on in order to charge your player.
USB Port 2.0
Make sure your player is connected USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location
Try plugging in different USB port (i.e. USB port in the back of the computer); sometimes the front USB ports have problem charging up the device.
Battery
Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery.
Latest firmware
Make sure to update firmware by downloading and installing the Sansa Firmware Updater.
I hope this helps, and don't forget to rate the answer.
Mar 05, 2009 | SanDisk Sansa Clip MP3 Player
How to download music to my sansa mp3 1gb.
I use Windows Media Player v. 11 (free software) with Windows XP transferred via the USB cable. This program will use the "sync" settings to add the music on your computer to the player. But, if the music is not in the MP3 or other compatible format for the player, then the WMP program will have to convert it first, which can take quite a few minutes if you have a lot of music.
Dec 21, 2008 | SanDisk Sansa c200 MP3 Player
Charging my SanDisk Sansa Clip MP3 Player
You will definitely need to get that USB charger cable.
Dec 09, 2008 | SanDisk Sansa Clip MP3 Player
Computer doesn't recognize MP3 player -
Make sure you are using a data transfer cable, and not just a "Charge Only Cable"... There is a difference, and they may look similar and both connect via USB so it can be tricky.
Apr 06, 2008 | SanDisk Sansa Clip MP3 Player
My mp3
Put the Clip into hold (left-side switch down) and press the center button down while connecting the USB cable.
Mar 11, 2008 | SanDisk Sansa Clip MP3 Player
I have a 1GB mp3 clip player. It was playing for about an hour. Then it stop playing. It does not have any batteries. How do I re-charge
If you are referring to the Sansa Clip, then you must connect the mp3 player to the computer using the USB cord - make sure that your computer has a USB 2.0 port, or it may not have enough juice to recharge the player.
Mar 07, 2008 | Audio Players & Recorders
SanDisk Sansa Clip MP3 Player Logo
60 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
