Question about Belkin N1 Vision Router
Flashing image on the Display
I connect the N1 Vision to my Laptop and a computer image appears on the display to the right hand side of the other image that is the modem router, however when i connect the wireless router to the ADSL Filter using the grey cable which came with the router a server sort of image appears and flashes, is it supposed to do this? or have i gone wrong somewhere? thanks
Icons from left to right:
The world: The Internet, if blinks there's not connection.
The modem: Your ADSL/Cable modem attached to the yellow RJ45 port
The router itself
The computer: All the attached computers to the grey RJ45 ports
The WL computer: All the computers connected via WiFi
The lock: Means that there's WiFi security enabled
Posted on Feb 12, 2009
Why can't I find the connect to projector option?
Connect your Projector to PC Computer
Connect to projector
How to Connect Laptop to Projector
How to display computer image on TV or projector
How to display a computer image on a TV or projector All modern televisions and projectors have one or more ports which allow them to receive and display an image generated by a computer. Both desktop and laptop computers are capable of connecting to a TV or projector, provided that they have the appropriate cables. The following sections contain instructions for using your TV or projector as a computer monitor. For best results, we recommend reading them in order.
Identifying available connections
Connecting computer and projector or TV
Display using Desktop
Display using Laptop
I don't see an image on my TV screen
Identifying available connections The first step in connecting your computer to a TV or projector is finding an identical port on both machines. Once the matching port has been identified (one that is the same on both your input device and output device), you need the appropriate cable to connect them. This section contains a picture of the back of an Epson projector and its available connection ports; as well as descriptions of each.
The HDMI connection is very popular among display electronics. In fact, nearly all modern televisions and projectors feature HDMI ports. Most laptop computers support HDMI and it is becoming more prevalent on both desktop as well; even without a high-end video card. HDMI is quickly becoming the standard for all electronic equipment for its high quality signal and ability to carry both audio and video signals. The image to the right is that of an HDMI cable.
find-connect-projector-option-vga-hdmi-zonwsocbr3qazne24mugrpvs-1-1.jpg VGA
The VGA connection is the most common among both desktop and laptop computers, is found on most projectors, and some TVs. The VGA cable has a 15-pin connector on each end that plugs into a VGA port on each device. Due to the fact that most televisions do not support VGA, we recommend using HDMI for their wider range of compatibility.
find-connect-projector-option-vga-hdmi-zonwsocbr3qazne24mugrpvs-1-2.jpg Tip:VGA cabling is universal for devices that support it. For example, the if your desktop monitor that uses a VGA cable it, that same cable can be used by a laptop to connect it to a projector.
Note: If you are using an Apple desktop or laptop you need a VGA adapter to connect a VGA cable to the computer.
The DVI connection is newer than VGA and it offers a sharper image. Although the DVI port is not shown on the Epson model above, it is still somewhat common for projectors, not so much for televisions. It is mostly found among desktop computers for monitors, but some laptops have DVI connections as well (Apple laptops are more commonly known to support DVI than any other brand of laptop). Since finding DVI on a TV or projector is more difficult, we again recommend using HDMI cables.
Tip: There are special cables that convert from DVI to VGA or DVI to HDMI and vice versa.
Composite Video
The composite video connection is quite common on a TV or projector, but it is nearly nonexistent on modern computers. This connection is the yellow female cable on what is normally a three bundle of red, white, and yellow. The only time you should see this setup is on older video cards for desktop computers.
The S-Video connection is also commonly found on TVs and projectors, but solemnly on a desktop or laptop computer. This connection is a small step up from composite video, but is nearing obsolescence.
Connecting computer and projector or TV After you've identified what connections are available on both your computer and TV or projector, you're ready to connect the cables. If the same connections are not available for both the computer and TV or projector, you'll need to purchase a video converter cable that converts one signal into a compatible signal.
Desktop Computers For a desktop, you simply need to plug the cable into the computer and output device. If you don't see an image, you may need to change the display using the following steps.
  1. Press the Windows Key.
  2. Type Adjust screen resolution and press Enter.
  3. Find Display and click the down arrow on the right-hand side of the box.
  4. Select the appropriate output device.
  5. Click Apply then OK.
Laptop Computers If you're connecting a laptop computer to a TV or a projector you'll often need to "send" the video signal to the display device. The key sequence to do this varies depending on the laptop; but usually it's either: Fn + F3, F4, F5, F8, or F9. For example, pressing and holding Fn + F3 at the same time on my laptop sends the video signal to my connected TV instead of the laptop's screen. The corresponding key used with Fn may be labeled as CRT/LCD or have a picture of a monitor on or close to the key. Additional help and information with switching the laptop display can also be found on the link below.
Switching TV inputs Finally, if you're connecting a computer to a TV make sure it has been switched to the correct input. For example, if you connected an HDMI cable to your computer and the "HDMI 2" port on your TV, you'll need to switch to the "HDMI 2" input. This action can be accomplished by pressing the input button on your TV remote until the correct image is displayed.
Jul 14, 2015 | Computers & Internet
While seeing through display area it shows blurred vision
Your camera has a feature called MF (Manual Focus) if it is switched to MF, the autofocus won\'t work. If on the right side of the screen is MF, you are sure the camera is in that mode. You can change that in Recording Menu 2.
The manual is still online.
Jan 13, 2014 | Sanyo Xacti Cameras
Model: Packard Bell Easynote GN45 - Display has "shifted" to the left; thick black chunk down the right hand side of the screen. Display at top of screen also appears at the bottom of the...
Test the laptop using an external monitor
If this works fine, then the issue is with the screen, or possibly the vga cable. I notice this is referred to as a compatible screen, was this obtained new, or is it 2nd hand. Although most 15.4 screens fit most 15.4 laptops, some do not display correctly, this might be your problem. If you know the screen to be good I would suspect the connection at the back of the screen
If this still shows issues with an external monitor, you have a problem with your graphics chip on the motherboard
Jan 22, 2011 | Packard Bell EASYNOTE GN45 COMPATIBLE...
N1 Vision Router: i cannot connect to my belkin router...
Check the routers gateway IP address is in the same subnet as the other computers or laptop.
Ie 192.168.1.X . (X is between 1 and 254)
In addition, the sub net mask is
If all is ok then it is probably a miss configuration with WPA /WEP options
May 18, 2010 | Belkin N1 Vision Router
N1 Vision keeps losing internet connection from modem.
Hi Friend,
Please check it by updating the Firmware for your router from the below website
Apr 13, 2010 | Belkin N1 Vision Router
Hi Friend,
Please follow the below mentioned steps one by one
Step 1:Take a cable,connect one end to the modem and other end to the router (In the port named,Modem)
Step 2:Take another cable connect one end to the Computer at the back side and other end to the router (In any one of the port named,Wired)
Step 3:Open an Internet Explore and type
Step 4:Now you will see a belkin router Setup page
Step 5:On your left hand side you will see a menu named,Restore factory default,Click on it
Step 6:Now It will prompt you for a Login Paasowrd,You leave it blank and click on Submit
Step 7:Click on Restore Default,It will complete the process and bring it to the front page
Step 8:Now On the left hand side click on MAC Address
Step 9:Now it will prompt for a Login Password,You leave it blank and click on Submit
Step 10:On your left hand side click on Wifi protected setup (WPS)
Step 11:Change the WPS to disable and click on Apply Changes
Step 12:Unplug the power cable of both the modem and router
Step 13:After 10 secs,put the power cable only to the modem,and wait until all the lights in the modem gets litup(If all the lights doesn't got litup then please check with your Internet service Provider).After all the lights got litup,put the power cable to the Router,Check all the lights in the router will be stable
Step 14:Now check in your computer that you are able to go online in both wired ,wireless computers and in the wireless devices like IPOD,IPHONE,PSP
If you have any clarification,Please feel free to contact
Mar 13, 2010 | Belkin N1 Vision Router
The display cuts off the bottom quarter of the image
you have a weird display resolution set somewhere on the laptop. The vplcs7 is relatively old. It only supports 800 x 600 (SVGA). If you are cloning your monitor, you need to set the output to the projector also to 800x600. Depending on how your laptop is configured you may need to set your laptop monitor to 800x600 while using the projector, then going back to the normal resolution when you are finished.
Feb 02, 2018 | Sony VPL-CS7 Multimedia Projector
Dell laptop connected to 1209s page indicates searching for signal and can't
Using the Display When you start the computer with an external device (such as an external monitor or projector) attached and turned on, the image may appear on either the display or the external device.
Press <Fn><F8> to switch the video image to the integrated display only, the integrated display and an external CRT monitor simultaneously, an external CRT monitor only, the integrated display and an external DVI monitor simultaneously, external DVI monitor only, and external CRT monitor and external DVI monitor simultaneously.
May 15, 2009 | Dell Latitude D800 Notebook
Xbox 360 router wont work with Belkin N1 Vision.
make sure u are looking for the right connection when the box opens for the connections on the left hand side u will c a small box click it u will get wireless /dialup/vpn just make sure you look for the right one also go onto ur computer into windows media into library options into sharing and search have your xbox on it will appear click on it to allow it to share with your pc i would appreciate it if you could rate this solution
Jan 02, 2009 | Belkin N1 Vision Router
Belkin N1 Vision
DHCP Host name is what your looking for.
you need to name each item ie. psp as psp and ps3 as ps3 when you setup each item for connection. so when you setup or edit the settings for your ps3 on your ps3 you need to look for DHCP Host name and name it ps3. etc
do the same for all.
Nov 26, 2007 | Belkin N1 Vision Router
Belkin N1 Vision Router Logo
105 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
