Question about Cuisinart GR-4 Griddler
Griddler wont power up
After plugging in the unit and turning on the main selector switch, the small light in the switch turns red. I believe this is normal. The problem is the other two dials (depending on witch on I select) light up green! I read the manual and it tells me; when the thermostat has reached operating temperature, a green indicator light inside the chosen control will indicate that the griddler is ready for cooking. The griddler never heats up, is the thermostat telling the unit that it?s already hot? If so where could I get a new part? I bought two of these units and they both have the identical problem. They are supposed to be factory reconditioned. Any help on this would be greatly appreciated Thanks for your time Robert McClay mcclayranch@hotmail.com
  • R house Jan 10, 2008
    Same problem!
Noggin
  • 944 Answers
SOURCE: Program light and time flash once per second
Here's the link to the user manual if you need it; http://www.cuisinart.com/share/man/34_man.pdf The water filter should be fine - if not it should be obvious to the eye that it is blocked/restricted - hold it up to the light. Try running through the descaling procedure in the manual if you havent recently - if it doesnt let you run a cycle, try it overnight without running it, and see if it will let you run a vinegar cycle in the morning. Try and pour vinegar into all the parts you can where it would go if a cycle was able to be run. If that doesn't get it running, check that none of the program/time setting features are still on - they should turn off after a few seconds, but maybe it is stuck in "time set" mode or similar. If none of the actions in the manual change the setting, try unplugging the unit and leaving it for at least half an hour unplugged, then hold down the power button when you plug it back in - this should reset the machine. If the reset doesn't work, it sounds like you have a control board fault - best solution is to contact cuisinart; http://www.cuisinart.com/contact/ Hope this helps :)
Posted on Aug 01, 2007
buffalonyman
  • 1865 Answers
SOURCE: top plate does not get hot, bottom plate is ok
The element could have a very fine crack in it, not readily visible. You must use a voltmeter to test if the element is getting power when the switch is turned on. If it is getting power, then the element is bad. If no power, then test the switch to see if it is sending power when turned on.
Posted on Jul 07, 2009
  • 85 Answers
SOURCE: would not turn on
Hello timpro,
I recently had this similar problem. If you still have you machine try the following.
Your described problem may be one of two problems. Let's start with the easier solution first. In the DCC 1200 there is a filter "stick or column" in the left rear. Pull it out and remove the clogged carbon filter(s) that are in there. Shine a light into the receptacle and remove the debris in the bottom. It is likely that this is causing the problem with you machine needing to be started on multiple times. See if this solution works. If it does, you might run 8 cups of water and 4 cups of vinegar through to help decalcify the units plumbing. Do this once or twice and then rinse with at least one pot run-through of clean water. If this works then you are good to go.
Next, if this does not solve your problem we can do the following: unplug the unit and lay it on its back. You will need a #10 torx driver (hardware store if you don't have one) to remove the bottom cover plate. There are 4 torx screws holding it on. When removed, you will find 2 orange hoses. Carefully attempt to remove the left hose without splitting. I used a eyeglas screwdriver to loosen it up. If it splits, just cut off the split and stretch it to reconnect when time comes. As you look into the hose you will find a little black valve inside as well a some gunk. Clean it all out with a fine wire as best you can. Rinse well. Attempt to reconnect the hose back onto the pipe. Slip the pipe clamp back into place. Replace the cover and screws and you should be good to go again. This is not as daunting as it may seem. You can do it. :o) Good luck! If this answer helps, please leave positive feedback for me. Much appreciated. Regards, NormanZ
Posted on Jul 08, 2009
  • 8 Answers
SOURCE: lost operating manual. is the temperature light
No it should not be blinking
Posted on Jul 11, 2009
  • 176 Answers
SOURCE: Went to plug in. Green light came on, no heat.
it's posible to have a disconected wire or a heating element burned. also is posible to have a problem whit saftey thermostat. good luck!
Posted on Feb 21, 2010
Why wont unit turn on?
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and precious time.
Aug 24, 2014 | Televison & Video
Panasonic TH-42PX60B
have you already service the main unit, or you an initial check on the parts of the TV..
kindly post back the TV model/maker..
Thank you
May 18, 2008 | Panasonic TH37PX60 37 in. Plasma...
Wont come on at all no blue light
If there is no blue light and no sound, then power is not making it into the unit. Is there a red light when it is plugged in? Many of these plasmas have a primary power switch located underneath or on the back. Make sure that is turned on. If you receive power, there should be an indicator light showing power is present. If it is just dead, as if unplugged, then either the main switch is off or failed, or the power supply may need service.
Apr 13, 2014 | Hitachi Ultravision P50S601 50 in. Plasma...
Tascam DP-01FX/CD wont turn on
Refer to your manual (1st) It appears that "maybe" your unit may be
locked - until you get through the menus - and type/press EXIT.
If you don't have a red indicator light - lit. Turn off power switch (rear)
and unplug unit for 1 minute. Plug in - then turn on switch (rear)....if
still no red indicator light....you'll need either Tascam or Samsung
tech to service your unit. Good Luck.
Feb 28, 2014 | Tascam Digital Portastudio Dp-01fx/cd
Compaq presario sr2020nx will not turn on
Just check the power suply behind computer case , or check your cable power.
May 24, 2010 | HP Compaq Presario SR2020NX PC Desktop
Top plate does not get hot, bottom plate is ok
Jul 07, 2009 | Cuisinart GR-4 Griddler
Hp pavillion power problem
Perform the following steps, in order, until power is restored or it is determined that there is a hardware failure:
CAUTION: This product contains components that are easily damaged by ElectroStatic Discharge (ESD). To reduce the chance of ESD damage, work over a non-carpeted floor, use a static dissipative work surface (like a conductive foam pad), and wear an ESD wrist strap that is connected to a grounded surface, like the metal frame of a PC.
1. Disconnect all cables from the computer, including the power cord.
2. With the power cord disconnected , press the power button on the front of the computer for five seconds.
Plug in the power cord and test to see if the computer can turn on. If not, continue using these steps.
NOTE: If the power supply fan makes an inconsistent grinding sound or stops and starts erratically, replace the power supply.
3. With the power cord removed, flip the red voltage selector switch to the opposite position. Wait about five seconds, and then switch the red voltage selector switch back to its original location. Ensure that the voltage selector switch is on the correct setting, 115V for North America.
Performing this step ensures that the voltage switch is engaged and set correctly for your country/region.
4. Remove all extension cords, power strips, surge protectors and any converters that remove ground. Plug the power cable directly to the wall outlet and test to see if the computer can turn on.
Dec 22, 2008 | HP Computers & Internet
Harmon Kardon AVR100
am in this field for more than 20 years n would never suggest such a solution ?if u do not know about electronics plz do not poke ur nose .the black box is called relay,it protects ur amplfier,when u push the main switch the relay enters into action.if all the sytems r ok then it energised after which all the set wrks.wat u have done is u have blocked this component n the whole protection system is off.
Jan 27, 2008 | Harman Kardon AVR 100
My back speakers wont produce any sound
OK I believe there is a small indented "Reset Button" around somewhere on the back of the unit, With the unit powered ON, & using a small diameter implement, straightened paper clip etc, press IN the button and this should "Reset" ya unit. This may indeed fix all your problems as the Unit "Reads" the speakers at turn on.
Aug 08, 2007 | Kenwood KAC-8403 Car Audio Amplifier
Power to the machine
Verify that there is power at the outlet. check power cord for breaks or scuffs. Check to see if there is a fuse in the back of the machine. I fall else fails...buy american.
Oct 30, 2006 | Saeco Vienna Espresso Machine
Cuisinart GR-4 Griddler Logo
51 people viewed this question
Top Cuisinart Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dale Anderson
Dale Anderson
Level 1 Expert
Tom Chichester
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
