Question about Toshiba Satellite Pro M15-S405 Notebook
Trouble w/ heatsink?
I had some trouble with my fan and heatsink being all clogged up and took it to myself, bad idea I know, to clean by taking the laptop apart. I put it all together and things are great but the fan works every other second and I can use the computer but things run slowly. Like for example, loading/ importing cds into itunes or playing even a google video. Please help because I have no other options. I live now in Austria and dont really want to go to a pc doctor here.
  • Andrew Gerke May 11, 2007
    thank you responding fast. I am new to this type of things and do not know what to do once in the hardware devise manager. Am I to fix something? Or is there something special I am looking for. I took the memory back out and it seems like I put it in the right way. and I scaned for viruses and nothing was found. I am still not doing something right. Any ideas?
    Scholar:
  • 125 Answers
The fan is supposed to work only according to the CPU temperature. If your machine is slow, check f there are hardwares affected when you disassemled it. Us the hardware device manager to look for devices with error or missing. Of course you have to the configuration before you dismantled the PC. It is also a possiblity that the reason why the PC is slow is that the memory was not inserted correctly. Check the size of the memory if it is the same as it was before you dismatled the PC. Look for software problem, maybe you are just thinking that because you dismatled the PC now it is slow. Maybe there is virus, spmams, worms, trojanns, etc. Check for resource usage, CPU load etc.
Posted on May 11, 2007
  • Michael Ifurung May 22, 2007
    You can monitor the software activity by invoking task manager (ctrl-alt-del).
    on the poerformance tab, you can view the CPU load. It should indicate less than 10% activity. If the cpu load is high, click the Process tab and look for process that is eating your memory and CPU power.
Asus m32 loud fan
Fan speed does increase for a reason.....heat. Check you BIOS settings and verify that the CPU temp is not getting too high. Desktop computers are dirt magnets. It is common for the CPU heatsink to get clogged with dust and dirt. This will reduce cooling and increase heat, eventually to the point that the fan will speed up. Get some electronic duster (canned air) and blow out the fins on the CPU heatsink. DO NOT remove the heatsink from the CPU. There is a special compound that is on the heatsink surface that allows proper heat transfer from the CPU. Removing the heatsink means that this compound is disturbed and would need replaced. Most users do not have this compound and thus should not remove the heatsink to clean. If the heatsink is so clogged that you cannot get the dirt out with canned air, you may be able to remove the fan from the heatsink, depending on the fan/heatsink design. Then you can use a brush to get into the fins to clean them.
Apr 18, 2015 | ASUS Computers & Internet
My hp pavilion model g6-2240as when restarting, states that the fan is not working properly and then cuts out in about 15 seconds. I do not know what to do. It has windows 8.1 operating system and the...
This is a common issue with laptops. Quite often, however, the problem is not the fan, but the heatsink that the fan blows the air over to remove heat from the processor. People tend to lay their laptops on their laps, beds, sofas, and carpets when they use them. This sucks massive amounts of dust, hair, lint, etc. into the cooling passages and clogs the heatsink. Many laptops are now made so that the heatsink can be removed for cleaning. If the heatsink is clogged, the fan cannot cool the processor and the processor overheats. This causes the cutting out for processor protection.
Aug 23, 2014 | HP Pavilion Computers & Internet
Acer 4339 keeps shutting off
Acer were well known for this, bad cooling fan, or to much dirt build up, laptop must be dismantled down to the motherboard level, remove fan and heatsink, use a can of compressed air to blow out all ports and fins on the heatsink and don't forget the fan. It is a good idea to clean off the old thermal paste with rubbing alcohol and paper towel, then apply a fresh amount to the processor and heatsink, "small amount"
Apr 12, 2012 | Computers & Internet
Hi there is a toolbar coming up the whole time saying,,,,,WARNING a problem with the cooling system has been detected, please turn of the computer and return for service immediately
Try to fix the problem without taking the laptop apart first but I would recommend using a powerful air compressor instead of a vacuum cleaner.
Welcome to FixYa! Based on the error you have received, this means that the cooling fan of your laptop needs to be cleaned and checked at. This is a common problem with any toshiba laptop. I suggest checking the heatsink of your laptop. If the CPU heatsink is not clogged with dust and lint completely, you can use canned air and just blow it inside the laptop through the openings on the bottom and on the sides. It's nice as a precaution measure, but it might not work if your laptop already has a problem and the heatsink is completely clogged.
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes (for example Toshiba Satellite A70/A75) you have to open the laptop case all the way down.
  2. Carefully disconnect the fan cables on the system board and remove the fan. If the fan makes unusual sound when it spins (grinding sound), I would recommend to replace the fan.
  3. Clean the fan and the heatsink with compressed air.
  4. I would also recommend removing old thermal grease from the CPU and applying new grease for better heat conductivity.
  5. If your laptop is still under warranty, you can take it to any Toshiba Authorize Service Provider and fix the problem at no charge to you.
Hope this helps! Thank you for using FixYa!
Jul 27, 2011 | Toshiba Satellite 1715XCDS Cooling Fan...
My laptop keeps shutting donw after a short period of time and the cpu area is hot during this time. any help
Clogged heatsink and fan / copper radiator. You need to remove the CPU cover (if possible) and hoover around the fan area to remove dust and debris. You mat have to take it apart to get to the cooling parts though. IF you chosoe to remove the heatsink to clean thoroughly, remember to apply some CPU grease between the cpu and heatsink.
Jan 12, 2011 | Toshiba Satellite P35-S605 Notebook
My Toshiba laptop suddenly shuts down by itself without any warning. Sometimes it works fine for hours, sometimes it shuts down in 10-15 minutes.And from yestarday it is shetting down after 30seconds after...
  1. The keyboard and the bottom of your laptop are very hot when the laptop is working.
  2. The CPU fans are working all the time at maximum rotation speed and operate much louder than before.
  3. The laptop suddenly shuts down by itself without warning. When it just started, the laptop was shutting down after 1-2 hours and how it shuts down after 5-10 minutes of operation.
  4. The laptop works fine when it runs idle, but shuts down as soon as you start using any memory demanding applications (DVD player, image editing software, video editing software, etc.).
Solution:
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes you have to open the laptop case all the way down.
I decided to use a shop vac to suck the dust out and it worked. I tested it by letting the machine run all night and it worked. It's been a couple of weeks now and I'm glad I did it. I was ready to take the machine apart, now I'm glad I didn't. I'd suggest you use a heavy duty shop vac to clean out the fan and heat sinks first.I agree. Try to fix the problem without taking the laptop apart first but I would recommend using a powerful air compressor instead of a vacuum cleaner.
Toshiba Satellite A15 Clogged Heatsink
Toshiba Satellite A35 Clogged Heatsink
Toshiba Satellite P15 Clogged Heatsink.
Aug 25, 2017 | Toshiba Satellite A205-S5855 Notebook
Pc shuts down when running bullguard virus scan,or loading Flip-Flash videos,or when watching videos on Network sites (CBS,Fox,NBC,etc.)...Why???
Those are all very cpu intensive. That means heat is generated. Id check the cpu heatsink fan for being clogged. then id check the chipset fan if it has one. are the fans clogged? siezed? if everything is clean and air flowing and it still does it I would remove the heatsink from the motherboard and clean the old compound off then apply some good silver based heatsink compound.
Dont even try this if you are not computer savvy. if you forget to put the heatsink back on before powering the computer back up it could permanently destroy the processor.
Mar 09, 2010 | Computers & Internet
My dell inspiron 1300 shuts down automatically and doesn't turn on after a few minutes. I believe it has something to do with it heating?
I think your right.Heating most of the time will cause a premature shut down.It may be your ram getting hot or video card and possibly your HDD.The ac adapter could also be overheating/going bad as well.You could blow it out through the vents, with it off and unplugged.You maybe able to get a notebook cooler to use with it.It MIGHT help.If you could get it apart and blow it out ,you may increase you chances.
Aug 03, 2009 | Dell Inspiron 1300 Notebook
CPU Shutting Down the PC
The clips attach on either side of the heatsink. They usually just pry up to remove (take a pic if u can of the heatsink b/4 removing clips). I'm guessing the fan is loaded with dust. Cleaning a fan will usually fix any problem you're having with the fan itself. If after cleaning the fan it works and PC still shuts down, you have 1 of 2 problems:
  • Bad power supply; make a not if the fan for the power supply is still working; a can of compressed air does a nice job of cleaning the inside of the PC including the power supply
  • Bad motherboard; only cure for bad motherboard is replacement
I hope this clarifies your issue and please don't hesitate to post back with other PC issues. All the best!
Greg
May 12, 2009 | Acer Power F1 PC Desktop
Overheating
yes its probably the fan but it could also be the screen brightness. replacing the fan and turning down the brightness will cool the laptop. but i agree try a new fan first.
Dec 26, 2006 | HP Compaq Presario V2000 Notebook
Toshiba Satellite Pro M15-S405 Notebook Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
