Question about Microsoft Windows Vista Home Premium with Service Pack 1: Windows
Error 0x80070002 vista sp2
Log Name: Application Source: Microsoft-Windows-MSDTC Date: 9/20/2012 12:33:53 PM Event ID: 4209 Task Category: Unknown Level: Error Keywords: Classic User: N/A Computer: Description: A critical error occurred in an MS DTC component therefore the process is terminating. The category field identifies the component that encountered the error. Please contact Microsoft Product Support. Error Specifics: hr = 0x80070002, d:\longhorn\com\complus\dtc\dtc\msdtc\src\cservice.cpp:473, CmdLine: C:\Windows\System32\msdtc.exe, Pid: 2720 Event Xml: 4209 0 2 8 0 0x80000000000000 489847 Application hr = 0x80070002, d:\longhorn\com\complus\dtc\dtc\msdtc\src\cservice.cpp:473, CmdLine: C:\Windows\System32\msdtc.exe, Pid: 2720 4D005300440054004300
frcs68
  • 1605 Answers
SOURCE: Windows XP Error: category 102 event id 1003
look like a system crash.
try to go into save mode and do a scandisk
if not, remove any newly install hardware or software.
restart the laptop.
Posted on Nov 10, 2008
hardwhere
  • 13 Answers
SOURCE: ERROR IN COUNTER STRIKE GAME IN WINDOWS VISTA
before you run the game right click the icon that launches it and goto properties, goto compatibility tab, check the boxes run in compatibily with xp sp2 and check the box to run as administrator, click apply ok then run the program.
Posted on Jan 18, 2009
Fardinfard
  • 392 Answers
SOURCE: visual studio instalation problem
just take a look to this site:
http://www.codeproject.com/
you will get your answer there easily.enjoy it!
Posted on Feb 23, 2009
rtrahan
  • 741 Answers
SOURCE: 16 bit MS DOS Subsystem error
I found a website of people who have the same problem;as you will see Microsoft does not have a fix for it. The recommended fix is to backup your data and reload Windows.
http://www.techspot.com/vb/all/windows/t-5039-NTVDM-CPU-illegal-instruction-.html
Pls rate this solution.
Posted on Apr 13, 2009
  • 14 Answers
SOURCE: Trojans wont go away. Hijackthis SCAN help
I've had VERY good luck by using this Kapersky Antivirus rescue. Here is a link to that, courtesy Brothersoft: http://www.brothersoft.com/kaspersky-rescue-disk-197959.html
Scroll down, it is a 102MB download.
Download this to a known clean machine and burn a CD. Once burned, put it in the infected machine and boot. It is a linux based OS Live CD, so it won't be infecting this disc. Live CD's are great, they take a little while to boot though.
Make sure you have an active internet connection as the program will update itself before scanning. If if says it won't mount the internal drive, choose Force Mount. In Settings, choose scan all files, set level to highest threat level.
This CD saved my **** and is now a permanent part of my CD collection!!!!!!!
After this finds the problems, download and install and run both Malwarebytes (full scan) and also Superantispyware (full scan). After those, download Avira-Free AV software.
By this time, you should have killed the beasties dead in their tracks!
Best Regards,
Tom
Posted on May 11, 2009
Need firmware update as stated in error message
You should be able to Update the Firmware from the IBM website:
http://www.ibm.com/us/en/
Good Luck!!!
Apr 23, 2013 | IBM xSeries 346 Server
ACER ASPIRE X3910 EVENT ID 41 KERNEL POWER CRITICAL
If it just stopped and restarted proper is nothing to worry cause it seam just like a memory dumping error or so ..If it asks to choose a boot on start ..just start normally or choose to start with the last known configuration that worked.
If it do not want to start it may be a case of corrupted boot file ..and need to repair the boot configuration using a operation system disk or the recovery partition ..My advice is to reinstall a clean copy if it makes troubles again ..It may have something in the system that cause it ..and reinstalling will remove the settings and programs ..and when you install them again try them one by one ..and you will know which one is not supported..
Nov 21, 2011 | Acer Aspire X3910-U3012 (PTSED02010) PC...
T is constanly coming when i play brian lara cricket 07..i'm having windows vista ultimate.is there any solution to this prob.If so pls send it to me as soon as possible. Problem Event Name: APPCRASH ...
Problem signature:
Application Name: ICC2007.exe
Application Version: 1.0.0.1
Application Timestamp: 21444c52
Fault Module Name: ICC2007.exe
Fault Module Version: 1.0.0.1
Fault Module Timestamp: 21444c52
Exception Code: c0000005
Exception Offset: 001212f0
OS Version: 6.0.6000.2.0.0.768.3
Locale ID: 16393
Additional Information 1: 8a65
Additional Information 2: a977d7b616fbef91d447986a1e395fda
Additional Information 3: 902c
Additional Information 4: d3100cb634d31eedbe4c3e2cdaa33f77
Read our privacy statement:
http://go.microsoft.com/fwlink/?linkid=50163&clcid=0x0409
when i play brian lara 2007 it shows this error plz help me
Mar 13, 2009 | Codemasters Brian Lara International...
How to solve:
Please run the Game Executable in Compatible mode for Windows XP SP2 AND with administrative rights.
It will run without problem.
Hope it helps.
Thanks.
Mar 13, 2009 | Microsoft Windows Vista Ultimate Edition
Jan 18, 2009 | Microsoft Windows Vista Home Premium with...
Error in IE on windows Vista
if you open the website and your IE crash, don't open again. try windows update, maybe there is an update for your IE. Otherwise using mozilla firefox
Feb 20, 2008 | Microsoft Windows Vista Ultimate Edition
Microsoft Windows Vista Home Premium with Service Pack 1: Windows Logo
74 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
