Washing machine leaks water
The GE washing machine is spraying a mist of water out the back component that sits to the left after taking the back off the machine. It does not seem to be coming from the hoses or the connections. It happens only when the water is being drained from the machine. The model number is WWA8470VCLAD...not sure if the 0 is a number or a letter.
  • mrfixit64857
    mrfixit64857 May 11, 2010
    This component, could it be the pump, down low to the rear? or the component where the hoses connect to, the mixer valve?
    Problem Solver:
  • 6 Answers
Check your water inlet hose in the back of the machine to make sure there tight. The vibration of the machine can loosen them up up.
Posted on Jan 02, 2009
GE washing machine stops mid cycle
Bad computer. Not ''DIY'' situation.
HOWEVER, you could check back of unit where water valve is. It _may_ be leaking and spraying water on the computer. That is about the only ''DIY'' possible in your situation. Otherwise, bad computer.
Aug 15, 2015 | GE Washing Machines
Why does my GE front load model#GFWH1200DOWW leak water from the back?
had same problem on my washing machine. got some plumbers tape from the hardware shop and wrap in around the screw thread before fitting the plastic screw connector of the hose to the washing machine.and tigthening it up.
Jan 07, 2015 | GE GFWH1200DWW Laundry : Front Load...
How to take the back off GE Profile washing machine
take off the bottom on the front, then pull the drum. cant take the back off.
Oct 08, 2012 | GE Profile WPRE6150K Top Load Washer
Water leak ge clothes washer
Replace the anti-siphon valve
Anti-siphon valves prevent water from siphoning back into the water supply. Also known as vacuum breakers, anti-siphon valves are used on washing machines, faucets, toilets, sprinklers and other water sources. A leak on an anti-siphon valve can cause deterioration of the appliance's external components and damage the flooring material underneath the washing machine. Therefore, a leaking anti-siphon valve should be attended to as soon as possible.
Jun 08, 2012 | GE WBSR3140DW Top Load Washer
Washing machine leaks at bottom left corner. Water still machine after drain/spin cycyle
My GE washing machine leaks while filling up in the first cycle in the left back corner. Need help!
Jun 16, 2010 | GE Profile WPRE6100G Top Load Washer
Washer appears to be leaking towards the top back right..
sounds like your main tub seal is leaking, also check the hose running to your water level switch,,and your outter plastic tub could have a crack in it
Feb 15, 2010 | GE WBSR3140DW Top Load Washer
Our washing machine started leaking lots of water during the fill and empty cycles. Water pours out of front bottom left corner. Any ideas as to what is wrong?
My Maytag Ensignia washing machine leaks large amounts of water when filling and during spin cylce. What could be wrong?
Jan 04, 2010 | GE WSXH208A Front Load Washer
GE whre5260e1ww zh133346g top load washer is leaking small amount from the bottom of the machine during wash cycle? I took the back of the machine off and the pump and motor assembly had broken off from...
Hello there:
Here is a few tips that might help you out
Hope that they are very helpful for you
Best regards Mike
Washing machine is leaking Washing machine leaks are very common. There are many places a washing machine can leak from although most leaks come from the same few places. The most common cause for a leaking washing machine is the door seal. Door seals often get holes in them and water leaks down the inside of the washing machine which then runs out under the front. Water leaking down the front of the washing machine from the door can be caused by a worn door seal (the flange part that the door glass presses against when closed) or something trapped between the door seal and the door glass which breaks the seal. If the door seal doesn't look worn, or it's too young to be worn, then try cleaning the door seal's flange and the door glass on the inside of the door. Bits of cotton, un dissolved washing machine detergent etc can cause a leak.
Soap dispenser leaks
The next most common cause of a leaking washing machine is the soap dispenser. Leaking water from a soap dispenser is often caused by a blockage, or water pressure that is simply too high. Despite seeing many leaking soap dispensers, I've never seen a soap drawer with a seal, they just rely on water not getting to the front which is not really good enough. Some Hoover soap dispensers in particular, are renowned for leaking, and over the years Hoover have had to introduce modified soap dispensers twice.
Some washing machines, can flood water out of the soap dispenser when a hose gets blocked (usually with un dissolved soap powder) Indesit, and Candy, as well as some of the later Hoover washing machines suffered from this design flaw. The hose where the water is flushed down, was right at the front of the soap dispenser on these washing machines and the hose wasn't wide enough. Un dissolved powder from a tablet or lumps of detergent through poor hot water pressure can block this hose solid. (Note: water flooding out of the front of a washing machine's soap dispenser can also be an indication of overfilling or a partial pump blockage if it does it when spinning)
Finally, black gunge in the top of the soap dispenser can cause water to spray towards the front and leak. Take out the soap dispenser drawer and look at the roof of the soap dispenser. If it's covered in black gunge, blocking some of the water holes, it could be causing problems. In extreme cases I've had to replace the dispenser.
Tips for finding a leak on a washing machine
  • If you have a leaking washing machine, and you can't see where it's coming from, shove some newspaper underneath the washing machine. The slightest drop will give a clue where the water is leaking from. Pull the sheet out regularly to check for water leaks.
  • Water can run round things and drip onto other parts. Be careful with your diagnosis, as water dripping from a hose at the bottom could actually be leaking from somewhere else higher up.
  • Leaks usually leave marks, so it's possible to see something is leaking even without witnessing it. The soap suds that come out with the leaking water leave white trails. Rust is a good indicator of a water leak too. However, if you have had a previous leak cured, the "evidence" of a leak may still be present so be sure you don't blame a part that was repaired in the past.
  • If the washing machine leaks only at the end of the wash, when water is being pumped out. Make sure water isn't backing up and cascading over the top of a blocked drain pipe in the plumbing.
  • WARNING: Don't get electrocuted trying to witness a leak. It's dangerous running the washing machine with the top or back off.
Nov 13, 2009 | GE WDSR2080D Top Load Washer
Tub is leaking
You could have a crack in the pump housing. Take the back panel off the machine and run a small amount of water in it, then turn on the spin cycle and see if you can see any water spraying from the pump itself. 20 yrs is not unreasonable for most older models.
Mar 11, 2008 | Washing Machines
Maytag top-loading washing machine at least 10 yrs. old
Sounds like the water pump is leaking.If you can raise the front of the unit you should be able to see the pump and hose connections.If it is the pump,you can get a replacement at you local appliance supply.
Dec 09, 2007 | Washing Machines
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
