Question about HP Pavilion 8560C PC Desktop
Disabled on board video
When ever i turn on pc, monitor just stays black. i disabled it because before did this my pc showed up some stuff on it about the pc. now i cant see anything , cant get into bios.
  • moctezja Jan 03, 2009
    thank you i moved those jumpers waited bout 5 minutes turned it back and everything worked out perfectly.thank you so much.
  • moctezja Jan 04, 2009
    i think that i did it, anyways tell me if i didnt and thanks for the help!
  • 679 Answers
You have to be able to get in to the bios in order to do anything. Did you try another monitor or try to reset the current one? Is there power?, the only thing you can try if you can't even get into safe mode or bios, is to first clear the cmos, by either moving the jumper "near the battery", from the two pins to the middle and last open pin, or removing the battery, making sure the machine is unplugged, not just shut down. Wait 5-10 minutes and make sure the jumper is the way it was before you moved it, if you moved it. Then start her up, let us know what happened, that should reset everything back to default .
Posted on Jan 02, 2009
  • George Bill
    George Bill Jan 03, 2009
    I am happy I could help, if you could perhaps give me a fixya rating the 4 little green things, as that is how we are compensated, although they don't tell the client that, but 3 is only like "good try" where 4 means we got it done for you, thanks, unless we get 4 we don't get elevated to a level that is commensurate with being compensated
Computer will turn on but the screen stays black , how do i fix it ?
Hook a spare monitor to the video output usually on the back, if picture okay it is the inverter board just below the screen, or the backlight behind the display, but if both show the same symptoms it is the video graphics chip built into the motherboard.
Jun 19, 2012 | Computers & Internet
Monitor turns dark
Hook a spare monitor to the video output, if picture okay! the inverter board is bad or the backlight behind the LCD is going. But if both show the same symptom, it is the Video Graphics Card normally built into the motherboard.
Mar 24, 2012 | Computers & Internet
My samsung sync master 151 -s screen is completely black, The rest of the pc opereates fine. The screen was working fine, then left to idle for a few hours now it appears really dark.
Try turning off the power to the monitor and the computer, check all the cables and power it all back up again. If the monitor is still black, try plugging it into another computer or into a laptop and see if it works there. If it does work, then the problem is the video card in the computer. If it is built into the mother board, then you can disable it in the bios setup and buy a PCI or AGP video card on eBay to plug into *********** board.
Nov 18, 2010 | Samsung SyncMaster 151 N 15" LCD Monitor
When I turn my monitor on, the screen shows the desktop momentarily and then goes black. If I turn it off and on a couple more times, the desktop will stay on and function normally. Where is the likely...
Try the monitor on another computer, to check-out the monitor.
Does the POWER lamp on the monitor stay on when the monitor goes black? If so, then the monitor probably is OK.
Try a different monitor, to trouble-shoot the video-card.
May 28, 2010 | HP Vs17 17" LCD Flat Panel Monitor
It won't start it is black
Dell systems have built in no post diagnostics, you can check them here:
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
if the system is completing post, but not showing any display, then you have either a Video Card issue or a monitor issue. Things to check:
  1. Ensure the monitor has the proper input selected for the cable that is connected (VGA, DVI, DisplayPort etc)
  2. Reseat cable connections
  3. If system was recently moved, make sure cable connected to correct Video Card Connection (Some systems have 2, and if an expansion card is inserted, generally on-board video is disabled.)
  4. If still no video and system has both expansion and onboard video, remove the expansion card, try the on-board.
  5. If still no go, try a different monitor
  6. if all the above fails, replace video card
Mar 19, 2010 | Dell Dimension 4600 PC Desktop
My monitor is starting to go black randomly. I
1. are your drivers new?
2. possible from video card
3. try not to wiggle cords :)) it's not from there
4. try testing the monitor on other pc's/video board
5. if it work on other pc/video board then try updating your driver or refresh rate to low
Jan 01, 2010 | Computers & Internet
Cpu no up, monitor shows
could be the whole pc is fried :(
Jul 10, 2009 | Computers & Internet
Monitor isn't working...shows desktop screen for a second then goes black.
reinstall windows ur screen resolution is not accepted by monitor
Apr 26, 2009 | Computers & Internet
Hp w2007 blank screen
we have here , like 1000s of black screens posted here now.
all the same all with CCFL lamps. that die. same solution.
older monitors have a power saver mode inside it,
push the front button called menu, then see OSD menu
then find and turn off power saver.
if the OSD fails to show up; the CCFL are dead.
this monitor was made in 2007, and 2010 is the starting year
for ending the usage of CCFL (starting on large screens working to small)
im reading your manual for you now, free.
page 4 tells you it has CCFT (T mean Tube, L means lamp)
same same.
https://www.manualslib.com/manual/1110533/Hp-W2007.html?page=4#manual
now lets look at the page on saver. power
page 7, (its on by default ) oops !
https://www.manualslib.com/manual/1110533/Hp-W2007.html?page=7#manual
turn saver OFF
see next page 8 and turn DDC ON.
see sleep timer and turn that all off.
if you push factory reset, it the problem begins again.
bad. for you.
https://www.manualslib.com/manual/1110533/Hp-https://www.manualslib.com/manual/1110533/Hp-W2007.html?page=8#manual
you can in fact download the whole manual.
for free. here. the site on the internet in this regard.
all old HP monitors are made for old PC 2000 year.
your PC is not 17 years old i bet.
so all this old saver stuff is now WRONG.
(all this is old school Energy Star , malarkey, )
Nov 13, 2017 | HP W2007 LCD Monitor
Liquid Video monitor goes black after 30 seconds
Capacitors on the power board inside the lcd monitor have blown they can be replaced with new ones and the monitor should return to normal operation.
service center or if you feel capable you can do it your self with a soldering iron and the correct caps that have blown you need voltage and micro faradays usually 25 v at 470 mfd (u)however monitors use different kinds and voltages can be different it will be marked on the side of the damaged capacitors.
l8r
Nov 11, 2008 | Computers & Internet
HP Pavilion 8560C  PC Desktop Logo
64 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
