Question about Janome Memory Craft 9000 Computerized Sewing Machine
Janome Memory Craft 10001
How to adjust timing-bobbin thread is not picking up
    Problem Solver:
I also found that sometimes it may be your needle. I know it sounds crazy, but mine did that and I had put in a Schmietz needle and it didn't work--bought Janome needles #11 and worked fine.
Posted on Nov 15, 2011
  • 22 Answers
What Wiz said - check that stuff.  just a tip, often times when the timing is truly off on a machine, you can swing the needle to the left and sew with it in that position, it will likely produce a nice even stitch.
Posted on Jan 11, 2009
    President:
  • 1,952 Answers
Are you checking the simple things such as making sure you have the presser foot up when you thread and the tensions set between 4 and 6, bobbin in the correct way round and tension enough to pull the thread through with some resistence.
Posted on Jan 04, 2009
Janome memory craft out of sync
check to see if you have the thread in the bobbin case the right way
Oct 13, 2014 | Janome Sewing Machines
Janome 8100 manual
The bobbin thread on my Janome 9000 is showing in the stitching. The bobbin thread pulls over to the left when sewing a zig or multi zig zag stitch. What to adjust?
Jun 11, 2014 | Janome Memory Craft 9000 Computerized...
Needle will not pick up bobbin thread
Sounds like the timing isn't quite right. Your best bet is to go have it serviced and timed.
Jan 08, 2013 | Janome Memory Craft 3000
Clear bobbin out of thread
Memory Craft has a bobbin winder on top of the machine.  It works beautifully, but wind it on slowly for better sewing function.
Jan 08, 2009 | Janome Memory Craft 9000 Computerized...
Janome Memory Craft 9500 Troubleshooting
Have you tried a new needle?
If re-threading, changing the brand of thread, etc. does not work, then it's likely your machine is out of time. Search for sewing machine timing or take it for service.
May 24, 2017 | Janome Memory Craft 9500 Computerized...
My sewing machine is not picking up thread from the bobbin
Your timing is out and will have to be put in to have it adjusted.
Aug 09, 2008 | Janome Memory Craft 10000
Janome Memor Craft 10001 bobbin tension
There is an adjustment on the side of the black bobbin case.
Remove the needle plate, to gain access to the case. Lift it out, noting how it is positioned! On the side of it , there are two screws, one is the adjustment screw - its the one that sits out more. To increase tension, turn it clockwise 1/8th of a turn, reassemble and test sew. (make sure the top thread tension is back to where it should be). Repeat if required. DO NOT adjust too much at a time!
Good luck
Aug 17, 2007 | Janome Memory Craft 9500 Computerized...
Janome Memory Craft 9000 Computerized Sewing Machine Logo
217 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
