Question about HP Photosmart 8750 InkJet Printer
Hp 8750 printer print cartridge cradle stuck
The screen displays print cartridge cradle stuck.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, clean the encoder strip. The encoder strip is the narrow elongated clear plastic strip running left to right of the printer. It has barcode like markings that guide/tells the printhead its location. Clean to ensure no ink stains, smudges or paper bits sticking to it. It has to be clear since the printhead uses light passing through the encoder strip to establish its position.
Good luck and Thank you for using FixYa.
Posted on Jan 05, 2009
    Scholar:
  • 100 Answers
Like Technodeal Said :)
    Sergeant:
    Scholar:
  • 199 Answers
Check out if something is blocking the cradle to move .it can be any foreign odject or a small piece of paper or something like dust.just off the printer for a minute and on it again and check out.also check out whether the cartridges are connected/fitted properly.remove and reinsert the cartridges and then check.
    Guru:
  • 558 Answers
Powr off Printer then Push the Cartridge Rack gently after opening the cover and move it to and fro gently. Resume the power back and then start working.
    Sergeant:
    Novelist:
  • 326 Answers
Just unplug the printer from the power outlet.
and move the cartridghe cradle with your hand manually and then again reconnect it and ON.and check out.
HP 8750 Ink cartridge cradle keeps jaming
Yes! it is possible to repair this fault economically. Usually you could have it replaced with a fairly used one if you don't want replace with a new one.
Mar 24, 2010 | Office Equipment & Supplies
I cant find the problem on my HP photosmart 8250. The screen says: Print Cartridge cradle is stuck. I have tried everything. Please help me? Kat
Although the support page of the following link is titled: 'Carriage Jam' this article (with pictures) shows the reader exactly what to look for when the Print Cartridge Cradle becomes stuck.
Click here: http://bit.ly/dpui4S
Feb 09, 2010 | HP - HP Photosmart 8250 printer
I keep getting a mechanism error, stating that the cartridge cradle cannot move. When I lift the cover, the cradle moves just fine. How do I fix this?
Try cleaning the encoder strip with Sprayway Glass Cleaner, clean both sides till nothing comes off on paper towel. The encoder strip is the semi clear plastic strip that runs the width of the printer just behind the printhead cradle. You should be able to see through this strip but not like clear glass. This will also help with this printer if it is printing crooked images.
Jan 08, 2010 | HP Photosmart 8750 InkJet Printer
HP photosmart 8750 - cartridge cradle jamb error
You need to check the encoder strip, the clear plastic behind the carriage, ink or grease will stop it from reading and give that error. Also ink buildup on the clean station will slow it's travel.
Dec 22, 2009 | HP Photosmart 8750 InkJet Printer
Hp photosmart 8750 printer cradle stuck
Hold the power cord in your hand next to the wall outlet and open the service door.
When you here the clicking noise, that is the release for the tray arm.
Pull the power and try to move arm back and fourth. Close the service door and power unit.
Hope this works for you.
Oct 29, 2009 | HP Photosmart 8750 InkJet Printer
Fast blinking red light, message says cartirdge service station is stuck
Solution
Follow these instructions to adjust the clutch on the printer.
Disconnect the USB cable.
Press the printer power button to turn off the printer.
Disconnect the power cord from the back of the printer.
Open the top cover of the printer.
Remove the print cartridges from the printer.
Slide the cradle to the right side of the printer.
Locate the clutch on the left side of the printer.
NOTE: The clutch is a flat, white, plastic component that rests just above the white roller gear wheel. In the HP Photosmart P1000 and P1100 printers, the clutch is black metal.
Figure 1: Printer clutch
Remove the rear access door from the back of the printer.
Press the clutch firmly towards the back of the printer, while rolling the wheels in the back of the printer upward two full rotations.
Release the clutch and roll the wheels up two more rotations.
Reinstall the rear access door.
Reinstall the print cartridges and secure the latches in place.
Close the top cover and reconnect the power cord.
Turn on the printer.
Print a test page.
NOTE: If the printer continues to display a Print cartridge cradle is stuck message or make grinding noises, click "contact hp" on this page for more support options.
May 26, 2009 | HP PhotoSmart 7660 InkJet Printer
Printer cartridge is stalled
While printing from an HP Photosmart printer, the printer screen displays Print cartridge cradle is stuck / clear jam and then press OK . The printer may also make grinding sounds. This can occur after a paper jam when another printer part blocks the cradle. Solution Follow these instructions to adjust the clutch on the printer.
  1. Disconnect the USB cable.
  2. Press the printer power button to turn off the printer.
  3. Disconnect the power cord from the back of the printer.
  4. Open the top cover of the printer.
  5. Remove the print cartridges from the printer.
  6. Slide the cradle to the right side of the printer.
  7. Locate the clutch on the left side of the printer.
    NOTE: The clutch is a flat, white, plastic component that rests just above the white roller gear wheel. In the HP Photosmart P1000 and P1100 printers, the clutch is black metal. Figure 1: Printer clutch c00020494.jpg
  8. Remove the rear access door from the back of the printer.
  9. Press the clutch firmly towards the back of the printer, while rolling the wheels in the back of the printer upward two full rotations.
  10. Release the clutch and roll the wheels up two more rotations.
  11. Reinstall the rear access door.
  12. Reinstall the print cartridges and secure the latches in place.
  13. Close the top cover and reconnect the power cord.
  14. Turn on the printer.
  15. Print a test page.
Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
May 09, 2009 | HP PSC 1315 All-In-One InkJet Printer
Print cartridge cradle is stuck ican't find where it is jammed
This might help . . . Mine finished printing one doc & then made a terrible noise & sent a message to my screen that "print cartridge cradle is stuck." When i opened door, i could see it was stuck off to the left side so left cartridge was obscured. I could not get it to budge, although i kept turning it off, gently pushing & turning it back on. Finally, i got my hand inside & determined that the little door to the left-side cartridge had popped open & was causing it to remain stuck. After some struggles (turn off printer first!) i was able to maneuver it around & close it tight. Now, all is well . . .
Apr 16, 2008 | HP Office Equipment & Supplies
Paper jam
is paper crinkled or is printer just giving a jam error/
Jan 15, 2008 | HP Photosmart 8750 InkJet Printer
I have had this problem with my 7550 for a while now and I finally found this on the HP website and it seems to have fixed my problem, I also replaced all of the cartridges:
Issue While printing from an HP Photosmart printer, the printer screen displays Print cartridge cradle is stuck / clear jam and then press OK . The printer may also make grinding sounds. This can occur after a paper jam when another printer part blocks the cradle. Solution Follow these instructions to adjust the clutch on the printer.
Nov 27, 2007 | HP PhotoSmart 7550 InkJet Printer
HP Photosmart 8750 InkJet Printer Logo
340 people viewed this question
Seeker5211
Seeker5211
