Question about Kyocera FS-C5015N Laser Printer
Paper jam We bought a kyocera fs-c5015n used. When we got it back to the office it says "paper jam". We have followed all the steps to remove the paper jam and haven't even seen any paper in it.
  • jn62 Jan 06, 2009
    Thanks for responding. I have searched the whole machine. Everything is very clean and I haven't been able to find any paper anywhere. Could it be a bad sensor?
  • jn62 Jan 09, 2009
    Thanks, I think it may be a switch actautor because I have gotten it to print a couple of times by resetting custom paper type. It print a couple of copies then went back to paperjam again.
    Genius:
  • 2,120 Answers
Did you try the door in the back of the printer?
Pull the paper cassette out then pull on the green handle to pull out the feed unit.
Posted on Jan 02, 2009
  • Leroy Elliott
    Leroy Elliott Jan 06, 2009
    Nope, Kyocera's never lie about jams, there is a piece of paper somewhere or a switch actautor is stuck down.
    if you remove the rear door by flexing it at the bottom only 2 screws hold the fuser in.
Kyocera 2100dn says paper jam in duplex unit but there is no jam paper.how can i fix?
the duplex unit is on top of paper cassette remove the cassette pull down the green lever inside the machine and remove the paper jam you cant see the paper otherwise
Feb 08, 2017 | Kyocera FS-2100DN Laser Printer - FS2100DN
My kyocera FS-C5015N printer is printing all my pages with blue background, also get alot of paper jams
Reclean the cyan corona wire/grid with the cleaning block that comes with each toner.ensure that you leave the corona unit as far out of the machine as possible for 30 seconds to allow the grid to dry.If this does not work then you will need a technician to attend to the printer.
Jul 29, 2010 | Kyocera FS-C5015N Laser Printer
Kyocera laser printer toner refill
refill...uh oh probably wouldnt try it..there's is like only 1 company that does kyocera refill toners.....call KATUN... you can try to find that on the internet..you most likely willl have to buy actuall kyocera toner..
Jan 24, 2010 | Kyocera FS-C5015N Laser Printer
How do you clean dried toner from colour developer units
Kyocera toner for the FS-C5015N is dry. If you have excess toner outside the developer use the cleaning cloth that comes with the toner kit.
Do not wipe the magnetic roller at the bottom of the developer. Along with the toner, the agent is on the roller. If the agent is removed the toner will fall out of the developer. There is agent in the toner container but not enough to replenish all of it if it has been wiped away.
Nov 14, 2009 | Kyocera FS-C5015N Laser Printer
Kyocera FS 1920 paper jam
Please install printer cartridge with drum unite properly.
Aug 24, 2009 | Kyocera Mita FS-1920 Laser Printer
Kyocera FS-C5015N colour laser printer. -printing grey backgound
it seems very important to shake the toner before using your printer.
it is not too late
remove all toners and shake them well
you will find after a short time that the grey background goes away
Jul 09, 2009 | Kyocera Office Equipment & Supplies
Kyocera FS 1010 printer. Not printing even with new cartridge
may be moisture.just switch the dehumidifier on for some tine.
Jan 18, 2009 | Kyocera Mita FS-1020D Laser Printer
Kyocera Printer has a paper jam in a very awkward place and I cannot work out how to remove it
Hi, go to this link, the pdf gives concise instructions to remove a paper jam
http://www.kyoceramita.com.au/files/1/FS-C5015_5025_5030_BOG-ENG.pdf
Dec 17, 2008 | Kyocera FS-C5015N Laser Printer
Kyocera C5015N paper jam can't remove
I guess it is stuck in the Fuser at the back, concertinaed at the exit claws,
Remove paper tray complete, pull green handle right side where paper tray came out, another tray will stop 3/4 of way out, there is a tab on each side, that you press in, one on each side of the rail, these are the bits stopping tray from coming out all the way, once you have the "process tray" removed you can see in to the fuser entry side and they may be enough to grab and remove it. If not unplug, top and sides off, unplug 2 cables, remove fuser screws and remove fuser.
Kyocera FS-C5015N Laser Printer Logo
691 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
