Scandisk card can you download pictures from your computer to the scandisk scandisk card
  • screwgdriver May 11, 2010
    Yes you can, but if you try and view them on a camera, you will most likely get an error. You can use it with a USB card reader and have a protable drive that you can store just about anything as long as you do not fill it up.
  • Carlos Ra?l
    Carlos Ra?l May 11, 2010
    you should be able as long as you have a scan disk reader. if your computer doesnt already have one you can buy one for really cheap.
  • 3 Answers
It matter if its a phone cam or just a ca. phones don't come up errors but only some phones do. its matters not all phones or cams give errors plug phone or cam in the computer select send to removable dis.G. and c no harm no foul right.
Posted on Jan 04, 2009
How do I refresh my micro scan disk?
With the scandisk inserted in your computer, locate the drive where you inserted and the file folder with the data you want to erase and delete or empty the file folder. If you do not have an available drive to place the scandisk, connect the media device with the scandisk included and locate the data via drive/file folder. You can locate the drive/file folder by clicking start>computer>drivelocation>scandisk folder.
Apr 19, 2013 | SanDisk 2GB microSD Memory Card
How to transfer pictures from nikon coolpix L25 to computer which is taken without using scandisk
Insert the memory card, press the MENU button, select the Playback menu (right-pointing triangle), then select the Copy command.
Mar 24, 2013 | Nikon COOLPIX Cameras
Formatted scandisk in casio camera
Unfortunately, yes. That is why we always advice to back up all data before proceeding with the format.
Jun 16, 2010 | SanDisk 1GB microSD Memory Card
Scandisk memory card keeps saying error
Some cameras will not work with the larger flash cards. Also the SDHC requires an adapter that accepts the high density. Many built into the computers do not accept the high density and will demand they be formatted. Verify the requirements of the devices you have for compatibility.
Apr 27, 2010 | SanDisk 4GB microSDHC Memory Card
Scandisk micro syncs all 'My documents' with comp plugged into
open scandisk settings and disable that feature.
or else you can simply delete scandisk software and use your pen drive.
Sep 08, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Garmin does not read scandisk 2 gb.
it might be due to the fact that you garmin cannot read AAC music format(the format itunes uses). try using windows media player to rip the CD then put the music on the card using windows media player. this should take care of your issue.
hope this helped.
please rate good.
Nov 12, 2008 | Computers & Internet
Camera card not holding pics
Van D UK is right. It seems suspiciously like a memory card corruption problem - maybe caused by the combination of the red battery light coming on and the act of taking the picture.
If you remove the scandisk card (camera off) and use a card reader to view the contents on a computer, you maybe can see if the file structure on the scandisk makes sense.
Presumably you have the camera user manual. This might help.
There might be some info about how to set up a new scandisk card. You might be able to rescue all the photos you have already on the existing scandisk card. I suggest you rescue them as a priority if you can. I suggest too that, in future, you download as a matter of habit all your photos (regardless) onto a computer. Having rescued as much as you can you can either re-format the existing scandisk card using the camera (if you can) or buy yourself another scandisk card.
I have had similar problems with my Sony camera and card. Try and get the correct card for your camera. I got some cards simlar to a Sony card but in the end I could only use one of them in the camera. The other had to do duty as file storers/transferers.
Mar 17, 2008 | SanDisk Memory Media
Error 30
The "E30" error code indicates reading/writing data on a SD card has failed. Especially, the error code "E30" may appears when you tried to remove a SD card while the camera was processing data. Solution To clear the "E30" error, try performing the following procedure. 1. Try using another SD card. If you have another SD card, try loading it in the camera. If the error code is not displayed when the other SD card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the SD card for errors. Use ScanDisk to check the SD card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the SD card on the computer before you check the SD card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the SD card. Follow ScanDisk's on-screen instructions to solve the problem. 3. Format the SD card with your camera Try to format the SD card with your camera. Please refer to the "Camera User Guide" for your camera for instructions on formatting SD cards. Also, please note that formatting a SD card will erase all data on the card. Once the SD card is formatted, follow the procedure described in step 2 above and use your computer's ScanDisk on your computer to check the SD card for errors. If a card error or card failure occurs when you are using computer's ScanDisk, there is something wrong with the SD card.
Aug 29, 2005 | Canon PowerShot SD100 / IXUS II Digital...
Computers & Internet Logo
David Payne
David Payne
