RE: COMPUTER MONITOR--X2GEN MW22U My x2gen monitor (MW22U)buzzes (especially with a lot of white on the screen)and ghosts the images (especially on desktop).
  • 1 more comment
  • robertgraves Jan 02, 2009
    To ronny2051: I am using Vista.
    How is the suggested connection change accomplished?
    Current setting is 1024 x 768.
    Video card is Generic PnP Monitor on NVIDIA GeForce 7350 LE.
    Thanks.
  • robertgraves Jan 03, 2009
    I'm still in need of a solution for this buzzing and ghosting on my monitor. (Note: I took the first monitor back and got a new one; it does the same thing.)
    Genius:
  • 2,920 Answers
It may be to do with your video card,,,,it may be bad and need changed out. usually when you run into issues like yours thats what it turns out to be
Posted on Jan 03, 2009
    Genius:
  • 1,199 Answers
I think at this point it would be cheaper to replace then fix the old one!
  • 8,220 Answers
Hit start then RUN then type MSCONFIG in the box bring up the system utility configuration and hit the LAUNCH SYSTEM RESTORE button. Let it go through and reboot and your probo should disapeer.
Posted on Jan 02, 2009
    President:
  • 2,110 Answers
Try to update the graphics driver...
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, have you tried the alternative mode of connection? If yes, does the problem persists? Your monitor has both DVI and analog VGA, whichever you are using, pls try connecting using the other.
Or you could try lowering from the 1680X1050 resolution, and see if it improves.
Additionally, pls postback the video card that you are using.
Good luck and Thank you for using FixYa. Happy New Year.
  • Louie  Role
    Louie Role Jan 02, 2009
    If you are currently using DVI switch to VGA or vice versa.
  • Louie  Role
    Louie Role Jan 04, 2009
    You could of course try the X2GEN MW22U with another computer and determine if the problem persists. If yes, monitor issue, most likely video processing/interface. If not, then video card issue. Might there be a spare video card or even perhaps a built-in one that you could try.
    Cheers.
    Novelist:
  • 163 Answers
Please tell me is the problem is with some spacific operting system?
  • ronny2051 Jan 02, 2009
    there are 2 chances --
    1) the problem is in the display card of your computer
    if yes you need a new one.
    2) there is some problem in monitor display IC needs a repair.
The MW22U displays horizontal grey stripes that continually move down the screen. Is this worth fixing?
Hey there.
I have recently written a tip on this problem. I suggest you give it a read and let me know how it goes.
You can see my tip here: http://www.fixya.com/support/r9352105-fix_colored_vertical_lines_lcd_display
Enjoy my tip.
Slasher_X
Aug 16, 2011 | X2Gen MW22U Monitor
How do I resize the images on the screen. They are too large.
Download _FREE_ software named "The Graphical Image Manipulation Program"
Among many things, it can "crop" and "resize" pictures.
Dec 11, 2010 | X2Gen MW22U Monitor
My X2gen MW22U gets dim on the left side of the screen. Can this be fixed?
jim5944, It depends on how old the unit is and if you would think it was a cost effective fix for the unit. You will be the deciding factor in the fate of the MW22U. To change the "cold-cathode-fluorescent-lamps" the unit will need to be stripped down to be able to cut loose the ends of the
lamps from the silicone sealer used to mount them to the lcd panel. Before installing new lamps they should be BENCH TESTED to prove that the new ARE NOT doing what the OLD ONES were doing! If new act same as old then the power supply/inverter supply may also need REFURBISHMENT!!! FYI check out www.lcdparts.net , www.ccl-la.com and other places like YOUTUBE for video clips of "LCD monitor disassembly", "LCD monitor repair" for additional info. If this info was of some help, please rate on FIXYA. 12fixlouie nrt of windy city. BYE for now.
Nov 13, 2009 | X2Gen MW22U Monitor
Monitor comes up white on computer start up
see if you have bent pins on cable.
Aug 19, 2009 | X2Gen MW22U Monitor
Ghosting of images and buzzing when on mostly white screen X2gen 19" monitor (HP/Vista )
Please bring the unit to an authorized service center as there's an internal electronic part/s of your monitor that is cold soldered / defective. regards
May 27, 2009 | X2Gen MG19VT 19" LCD Monitor
Mw22u monitor has white screen.
Manufacturer out of business. Local repair shops want more $ to fix than the cost of a new one.
Solution --- Trash old and replace with new display.
Mar 25, 2009 | X2Gen MW22U Monitor
Black screen. Power light binking from dim to bright
I have exact same problem but mine happened to 2 of my x2gen monitors at the same time,really strange.
One was purchased 01/07 and the second 04/07
Took my PC in, no problems
Took one of the x2gen in,was told monitor is bad
How could both monitors go bad at the same time???????
Mar 20, 2009 | X2Gen MW22U Monitor
Good picture for 30 seconds then screen goes black with a faint ghost of the image
i hope the problem will be in LOT of the monitor...you need to replace the LOT
Jun 14, 2007 | Mag Innovision LT576s 15" Flat Panel LCD...
Televison & Video Logo
130 people viewed this question
Top Televison & Video Experts
