Advent roma 2000 screen just goes black but works when i plug my hdmi lead into laptop to my tv
SOURCE: No picture when i connect to tv via hdmi
If you can give me some more detail, I might be able to help. Are you trying to connect your computer to your TV? If that is the case, most graphic cards can be set for dual output, but in most cases this has to be enabled through the software that came with your graphics card or by going to the properties screen on your computer monitor. There are several ways to do it. Hope this helps
SOURCE: how do i get the webcam to work on my advent roma
you need to install the webcam driver to access your webcam
SOURCE: how do i get the web cam to work on advent roma
while you purchasing the webcam in that pouch you can find the driver CD you need to install it first
SOURCE: my laptop will not start up
Hi mgforlife, try this solution:
turn off the pc, unplug all the cables on your laptop , remove the battery
then press & hold the power button for 5 seconds. Then replug the cable and reinsert the battery on it. Turn on the pc and check if the video in full screen would work..
