Question about Panasonic TH-37PX60U 37 in. Plasma HDTV
Panasonic Plasma as PC Monitor using HDMI
I am trying to connect my PC to my Panasonic Plasma.
I have the following eqipment:
Video Card = NVIDIA Geforce 9800GTX+
Panasonic Plasma = TH-50PZ850U
I can connect through the analog PC input on the TV. But, I want to use an HDMI connection to get the best resolution. The Geforce 9800GTX+ has DVI out, so I have a DVI to HDMI connector and plug in HDMI to the TV.
Here's the sequence of events that's happening:
1. Conncect PC (DVI to analog adapter) to TV PC analog connector.
2. Everything works fine.
3. Enable the Geforce video card.
4. Reboot to enable viseo card, still using the analog connection.
5. Everything works fine.
6. Shut down.
7. Change connection to DVI/HDMI.
8. System boots up OK. Then, even if I make no changes to any settings:
9. Next time the system boots up, the screen is black.
I've tried changing the video card settings. I've made sure the refresh rate is at 60Hz (which is what Panasonic says the TV refresh rate is). I've connected my TV to a LAN line and updated the software. The video card software is also up to date.
I don't know if it's an issue with the TV or the video card.
  • mdejongh Jan 04, 2009
    Actually, I can't seem to repeat these steps. I thought I could, but I tried today and I can't.
    I've connected the following ways:
    1. TV only with analog connection...always OK
    2. TV only with HDMI connection...today never OK, boots OK into safe mode.
    3. Separate monitor from my other computer...always OK
    4. Separate monitor plus TV HDMI...monitor OK, TV no good
    5. Separate monitor plus TV analog connection...both OK
    My TV manual lists all the HDMI possible connections, for example:
    1125 (1080) / 60p with Horiz freq 67.50 and Vert freq 60.00
    but, I don't know what that means relative to the possible video card settings.
    The TV manual also lists the analog PC connections, for example:
    1280 x 1024 @ 60 with Horix freq 63.98 and Vert freq 60.02
    I can understand this relative to the video card settings, but like
    I said, the analog PC connection works fine.
  • mdejongh Jan 07, 2009
    I got it! The DVI/HDMI adapter had a broken pin.
    It must've been loose at first, that's why sometimes it worked and sometimes it didn't. Then it must've finally broke and that's when I couldn't get anything to work.
    Thanks for your help.
    Genius:
  • 1,239 Answers
HI
Use your TV's PC input with DVI or RGB.
Connecting a computer using HDMI is basically the same thing as connecting it through a yellow composite (RCA) cable.
The TV does not seem to be able to grab the sync information from the computer. In other words, the computer will just detect no monitor, and won't let you change resolution from 640x480 or 800x600.
Posted on Jan 02, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Have you tried connecting to another HDMI on the Panasonic, specifically the front? An HDMI input, an AV input, and an SD card slot are hidden beneath a door on the front panel.
Good luck and Thank you for using FixYa. Happy New Year.
    Novelist:
  • 163 Answers
K...
go to the link to know how to use your tv as a computer monitor --
http://chris.pirillo.com/2007/09/22/using-hdtv-as-pc-monitor/
  • ronny2051 Jan 02, 2009
    or try the blow link to know how to connect plasma TV to a computer (with complet figure diagrams)---
    http://www2.panasonic.com/consumer-elect...
  • 837 Answers
Shutdown, connect BOTH connections to the tv (pc & hdmi)
Now when you startup you will have video .. then in the control panel for the Nvidia card you will see that it should show both connections .. switch to the hdmi connection and you "should" have video on the TV
  • Panasonic Master
  • 13,433 Answers
If you can repeat the steps over and over again it means the issue is in your computer settings, seems they won't stay the way you want them to.
disconnect any extra cables from the computer. do you have it connected to anything else but the tv?
  • Ekse Jan 04, 2009
    I suspect its a problem with the nvidia drivers, you could try updateing the drivers from nvidia.com. Also if you look into the nvidia control panel, look into the video & televison look at the change the signal or HD format.
    the settings seem to have a mind of their own at sometimes (in my own experience), try selecting another signal format.
    let me know if it helps.
Is the 42" philip plasma
If you really want, you can use an old CRT TV as a monitor provided you get it connected.... so your plasma... YES. If your PC has a DVI port, you could use a DVI - HDMI cable to connect. If your PC does NOT have a DVI port, you could install a video card that does... better yet, get a video card that has a HDMI port. This way, you'll only need a HDMI cable to connect the PC to the TV for audio and video.
Aug 05, 2011 | Televison & Video
Acer T230 H monitor Hdmi ConnectionProblem
I don't think your doing nothing wrong, but I may be wrong. I would just stick with the other connections. HOpe this helps!?
Please rate solution - Thanks.
May 14, 2010 | Acer T230H 23 inch LCD Monitor
Use TV as external monitor from laptop
no tube tv won't mirror monitor. needs vga connection at the back of tv.go to store have a look at lcd or plasma screen.the card is ok.
Jun 26, 2009 | HP Pavilion DV6500Z Notebook
Connecting asus M51V to Panasonic TH-42PX8A plasma via HDMI
Hi
Make sure your TV does indeed support the resolutions you are trying to use. Some low quality HDMI cables can also be troublesome in higher resolution so try one you are sure to work.
Regarding to the desktop only being extended when using the RGB cables, try bringing up the desktop properties window, select the TV as the primary monitor and select "Use this monitor as Primary monitor". You might have to drag the windows Taskbar over to the other monitor, just rightclick the taskbar, uncheck "Lock the Taskbar" and drag it over to the other monitor.
Hope you find this solution helpful, and please rate it if you do so..
best regards,
Karl
Mar 14, 2009 | ASUS Computers & Internet
How to conect a pc to a panasonic plasma th50px75u?
Panasonic didn't make it a simple matter to connect a computer to this TV since they didn't include a VGA input connector. You can still do it, but it will require some adapters or changes to your PC.
If you're using a laptop, you have two options. If the laptop offers an s-video output, you can use a suitable cable from there to one of the set's s-video inputs. If there's no s-video output, the other option is to purchase a VGA-to-component breakout cable, available at a number of online vendors (search with Google). This cable has the VGA connector to the computer on one end, and 3 RCA plugs at the other end. You would use this cable into one of the set's component video inputs.
With a desktop PC, you can still use one of those two options. In addition, there may be a DVI video output connector available as well. This is not common on computers with integrated video, but is frequently found on many newer expansion video cards. If your computer has this connector (or you install a new video card with one), you can use a DVI-to-HDMI adapter and connect an HDMI cable to one of the set's HDMI inputs. Many video cards with DVI outputs include one of these adapters already.
So while it's not going to be simple, it's certainly possible to connect your PC to this TV.
Feb 03, 2009 | Panasonic TH-50PX75U Plasma HDTV
Connect HD Plasma to Laptop using HDMI cable
so what you ****, this a problem telling website not a website of telling your happiness of your succession
Jan 21, 2009 | Dell XPS M1530 Notebook
How connect Panasonic TH-50PX75U to PC? it said the PX75 series cant connect to pc, cuz it dont accept pc signal. what i can do? send me a mail: tiancai_6969@hotmail.com thanx a lot dude!
You have to have a couple of things to make this work: 1) a PC with DVI or HDMI output, 2) a video card capable of 1280x720 resolution and 3) a video card driver/utility capable of correcting for overscan.
I have my laptop connected to one of the HDMI inputs via a DVI-to-HDMI cable. I have Windows at 1280x720 resolution on the DVI port (the external monitor). I set this through Control Panel-> Display. Once I did this I was able to see my PC desktop on my TV. The only problem then was the desktop was cutoff on all side. To fix this it was a bit more of an adventure and this solution would only work if you have an ATI Radeon video card.
I installed ATI Catalyst Control Center (CCC). In CCC, it recognized that I was connected to a Panny 50" plasma. Than enabled the DTV settings. Under those settings I put the video card into 720p@60Hz mode. I then had to create a custom format to shrink the screen to fit my Panny display. I then saved this as the default setting for the Windows desktop. Whenever Windows boots it runs CCC and sets this setting for me.
I hope that helps! It can be done and it looks great.
Dec 29, 2008 | Panasonic TH-50PX75U Plasma HDTV
Help
Step 1
Shutdown your computer and look at the rear of the case to determine the type of video connections that your machine has. Nearly all computers will have the standard 15-pin VGA output port. In addition, you may also find that your computer has an S-video port, an RCA composite video port, a set of three component RCA video outputs or perhaps even an HDMI output port.
Step 2Determine the types of video inputs that are available on your plasma TV. There should be a standard RCA composite input, a three-jack RCA component input and an S-video input. In addition, you may also find a 15-pin VGA input, a DVI input or an HDMI input. Step 3 Select which type of connection you will use. HDMI and DVI represent the highest-quality connections, followed by VGA, Component, S-video, and composite. If your computer has only a VGA output and you will not using it solely to drive the plasma TV, you may want to invest in a video card upgrade. Most new video cards will offer dual monitor connections and possibly a separate TV connection. The first monitor connection is intended for the main computer monitor, and the second monitor connection, or the TV output, can be used for either a second monitor or a TV. Depending on the card, the TV output may be DVI, HDMI, component, S-video or composite. Step 4Purchase a video cable long enough to reach from your PC’s video output to your plasma TV. If the distance is over ten feet, you may want to invest in high-quality cables to ensure that the plasma TV receives a clean signal for the best possible picture. Cables over thirty feet in length, depending on the connection type, may result in poor video performance. Step 5Set your computer’s screen resolution to something that your plasma TV can accept, using the “Display” settings in the “Control Panel” in Windows. Refer to the owner’s manual of your plasma TV for the supported resolution and refresh rate. If you are using the S-video, composite or component outputs on your computer, this step may not be necessary. Step 6Connect your PC to your plasma TV using the appropriate cable. Start the computer up and it should recognize the attached display. In the “Display” settings, you will need to configure how the plasma TV is used if it is attached a second display. Most video cards support “Clone” or “Mirror” mode, which displays the same content on both displays. In addition, there is the “Extended” mode, where the second display will operate independently, and windows can be dragged from one screen to the other. If your plasma TV is the only monitor for the computer, you will not to configure the multiple display modes. Step 7Connect a cable from the sound output of your PC to your plasma TV using the appropriate audio adapters. Then relax on the couch and enjoy your videos on the big screen.
Aug 09, 2008 | Computers & Internet
Plasma Hook up
listen what you do is go down your local electronics shop and buy a video card or scart card which allows yyou to connect your pc to your television and v v . and the surround system wer you connect your pc speakers you buy a lead whiocih allows your to convert a phono plug to a 9mm phone jack and use that. hope it helps you.
Aug 22, 2007 | Sylvania 6842PF 42 in. EDTV-Ready Plasma...
Panasonic TH-37PX60U 37 in. Plasma HDTV Logo
413 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
