Question about Vizio L32 32 in. LCD HDTV
My picture 37" vizio hd tv does not fill in the whole screen when watching an HD channel
    Sergeant:
  • 152 Answers
You need to change the aspect ratio on your cable box from 4:3 to 16:9. sould be under menu/setting/. if not try using the format button on the remote. hope this helps
Posted on Jan 02, 2009
Screen seems stretched. How do I fix it?
60'' Vizio TV screen is stretched in 'normal' screen mode on HD ...
https://answers.yahoo.com/question/index?qid...
Jul 21, 2013 - Ive had this tv for almost a year and the screen has never given me problems, but just recently all the HD channels are stretched. ... If your Vizio is like my 47" it has 4 Picture Modes - Wide, Normal, Zoom and Panoramic. ... Why isnt my viziotv able to play full screen hd channels?
TV Problem: The picture on my television is stretched out on the ...
Aug 23, 2008 - It is a High Definition Vizio TV. The center of the screen is clear, but the television stretches the image out on the sides. Is there anyway to fix ...
How to Fix the Most Annoying Features of Your New HDTV ...
Dec 31, 2015 | Vizio VA Televison & Video
I have a Vizio 55" TV model M55ONV. I can't
Are you using a cable box like a DVR?...there should be a setting on that for aspect ratio, not sure this is a TV issue
Dec 18, 2017 | Televison & Video
Picture problem
If all your wanted is to widen the picture then just push aspect or format on your remote control and put it on either 16:9 or full. But if your referring to HD then an HD picture fills the screen by itself no matter what setting you have the tv set to. If the screen isnt full then the program your watching isnt broadcasting in HD at that time. A common misconception is that because its an HD tv or an HD channel that it always should show in HD. This isnt true. It goes by the broadcast
Apr 07, 2010 | Insignia 42" LCD Flat-Panel HDTV
I re-scanned my channels this weekend because I lost HD on 2 of my local channels. Now I have HD back, but I have 2 black lines on each side the picture on all of the HD channels. How do I get rid of the...
A broadcaster will transmit an HD channel in 1 format. This may be 720p or 1080i, both of which are HDTV formats. HDTV formats have an aspect ratio of 16:9. SDTV or standard definition broadcast have an aspect ratio of 4:3. Because not all content is record in an HD format (ex: Judy Judy), the broadcast is faced with 2 options. #1, stretch the 4:3 picture do that it fills the 16:9 canvas. #2, simple place black side bars on each side of the 4:3 image. What you are seeing is the latter of the 2 options. You will notice a change during the evening programming. The bars are only there when the content is not HD. You can use the WIDE feature of your TV to stretch the picture so that it fills the screen, just like broadcaster option #1 above.
Mar 15, 2010 | Vizio VW37L 37 in. LCD HDTV
I am having a problem with my new vizio tv. I am
Try this solution....
1) On the original TV remote press the menu button.
2) Scroll down to SETUP and press MENU button to select it.
3) Scroll down to WIDE
4) Use the LEFT and RIGHT arrow keys to adjust to your viewing preference.
**** NOTE: When you adjust these settings you may notice a difference in the picture on the HD channels. When you are viewing an HD channel but the network is not broadcasting that show in HD they push in the sides to compensate and try to make it a sharper picture but know this is normal.
Good Luck and please rate this solution....
Jan 10, 2010 | Vizio VF550M 55 in. LCD HDTV
I'm new to the HD world...just purchased a LG 42LH40 a couple days ago...and have a couple questions to make sure my TV is operating right. 1) When watching an HD channel (CBS for instance) there is about...
Check in the manual or with the manufacturer, but the TV should auto configure the picture based on the signal.
I have a Toshiba that does the same thing.
There is no mistake when HD is in effect, as the picture is superb.
Jan 09, 2010 | LG 42LH40 LCD TV
Heads cut off on the screen
Ocean's Eleven. Best remake movie, I think.
I believe your TV is in "ZOOM" mode for the screen. This will make a 4x3 picture come up closer to fill in the 16x9 screen, but this cuts off the top and the bottom.
Keep pressing the WIDE button on your remote until the picture looks best.
If you have HD channels, the screen mode should be on NORMAL. HD channels will have the 16x9 screen format.
The non-HD channels will have 4x3 screen format. When the screen mode is on NORMAL, you will have the cut off picture on the sides because the 4x3 format will not fill in a 16x9 screen.
May 30, 2009 | Vizio Gallevia GV42LF 42 in. LCD...
Horizontal Black Bars on HD channels?
You can change aspect ratio by remote. I hope it will be solve
Apr 02, 2017 | Dell W4201C 42 in. Plasma HDTV
Picture Issues
When your watching non HD channels you have to stretch your screen.Your TV has that input option to do so.
May 08, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
The picture has shrunk - maybe 720P vs 480P?
make sure your hd cable connection from your cable box is going to an hd connection to your tv.[via hdmi, dvi,or componant.] if you have a different hook up such as rca out or coax out, these are not hd connections and you are probably streching out the picture.look at the rear of the tv & cable box and see how the connections are.the hd hook up to the hd input should make the picture the right size only if it's set on the hd input channel.hook up the dvd player to a aux/line in or video/source input and try changing the picture size. you may have to play around with it till you get it the way you want.
hope this helps.
wg
Feb 06, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio L32 32 in. LCD HDTV Logo
193 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
