Question about Adobe Acrobat 7.0 for PC
Acrobat Professional 7.1.0 freezes my computer.
Running on windows XP when opening a document or saving from In Design CS2 Acrobat does the required proceedure but then freeses the whole system making it necessary to reboot. I have reloaded the programme twice the second time as suggested by Adobe.
Any further suggestions please.
Check to make sure you have enough hard drive space available. How much memory (RAM) do you have available? Be sure to UNinstall Acrobat before re-installing.
Posted on Jan 03, 2009
Adobe Acrobat 7.0 Pro Error
Adobe has disabled the activation server for CS2 products, including Acrobat 7, because of a technical issue. These products were released more than seven years ago, do not run on many modern operating systems, and are no longer supported.
Download the New Copy of Acrobat and activate it with the new serial Number .
Click this Link CS2 downloads
Apr 22, 2013 | Adobe Acrobat 7.0 Professional
An error has been detected with a required application library and the product cannot continue. Please reinstall the application.
Basically lot of people are getting errors with Acrobat 7 and older versions as Adobe has disabled the activation server for CS2 products, including Acrobat 7, because of a technical issue.
Go to the Click here for the Link to Download Acrobat
Download the New Copy of Acrobat and Activate it with the new Serial No, however you need to un install the old copy from your computer
Apr 16, 2013 | Adobe Acrobat 7.0 Professional
Difficulty to open pdf files
1. Make sure that the system meets the requirements for the Acrobat product that you use.
Acrobat can't run correctly if the system doesn't meet the following requirements:
  • Intel Pentium processor
  • Microsoft Windows XP Professional or Home Edition with Service Pack 1 or 2, or Tablet PC Edition, or Windows 2000 with Service Pack 2
  • 128 MB of RAM (256 MB recommended)
  • 460 MB (Professional) or 360 MB (Standard) of available hard-disk space; optional installation files cache (recommended) requires an additional 300 MB of available hard-disk space.
  • 1024 x 768 (Professional) or 800 x 600 (Standard) screen resolution
  • CD-ROM drive, if installing from a CD
  • Internet Explorer 5.5 or later
Jun 16, 2011 | Adobe Acrobat 7.0 Professional
How to save in acrobat .pdf ?
PDF (Acrobat) files are a great way to make sure documents are viewed with the correct layout and fonts - even when the recipients don't have the program you used to create the documents. It's also a format that is viewable across multiple platforms. In order to create a PDF file in Windows you need to be using Adobe Acrobat Distiller.
Open the file you want to make into a PDF.
Choose File, then Print.
Use the PDFwriter option when printing from a word-processing application: Choose PDFwriter from the Name pull-down menu in the Print dialog box. Fill in the document information, then click Save.
Use Acrobat Distiller option when printing from a page layout or design program: Choose Acrobat Distiller from the Name pull-down menu in the Print dialog box. Fill in the document information, then click Save.
Jan 03, 2010 | Adobe PageMaker 7.0 for PC
I have Adobe Photoshop CS2 on my PC (windows xp), and after i adjust a photo, and click "Save As," the whole program freezes and i have to restart my computer to access the program. I've checked the RAM...
Use the combo fix, this software fix the problem of your software, OS or hardware/ driver related issues. Your problem will resolve and work it properly.
Good Luck
Dec 04, 2009 | Adobe Photoshop CS2 for PC
I just installed acrobat pro 7.0 on our new computer and when I try to open any document it freezes and says it's not responding. I've used it on our old computer with no problems. I did the full...
Restart your computer and try again! If not acrobat pro 7.0 is not compitable with the operating system on the new computer.
If the O/S on your neww PC is vista plaese read the link below.
http://vistalounge.com/windows-vista/adobe-acrobat-7-and-windows-vista
All the best!
Jul 28, 2009 | Adobe Acrobat Professional 7.0 for PC
Cannot Create PDF from Word Document Using Adobe Professional 6.0
You can try to create PDF file directly from Microsoft Word. Adobe Acrobat Professional installs a virtual printer on your computer. Print the document from Microsoft Word, but make sure you select appropriate printer from the list. It should be called "Adobe Acrobat PDF Printer", or similar.
Jan 15, 2009 | Adobe Acrobat 6.0 Professional for PC
Failed export to a word document from Adobe Acrobat 9 professiona
I am not sure that I would calssify this as a real solution but I had the same issue on an XP machine running Word 2003 (with the 2007 compatibility module).
When I took the exported document to a Vista machine with Word 2007, it opened it fine.
Of course, I think it converted or imported it to 2007 format.
The Vista machine does have more memory in it and a better processor but not that much more/better.
So, don't despair, there probably IS a way to read it and edit it, but possibly not with the machine you are on (sorry).
I am still researching to see if I can find a work around for the XP machine.
Jan 15, 2009 | Adobe Acrobat 7.0 Professional
Abby FineReader 7 does not read/input PDF document
you need to open the pdf in acrobat professional and export it as a word doc
May 30, 2007 | ABBYY Software House FineReader 7.0...
Adobe Acrobat 7.0 for PC Logo
345 people viewed this question
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
