Question about Haier BC112G Wine Cooler
Wine cooler haire hvw18bss - no power/ will not run
No pwr / is there a reset / want is the mostly fault / is it worth repairing ?
  • geneglass Jan 02, 2009
    hi
    just so I understand , the thermostat is inside the door of the cooler , dial type control just cool and colder setting . is this the area you want me to connect wires? . how to I access wires . . are you thinking its the thermostat that failed? assuming I bypass the thermostat and the unit is powered - reults is a bad thermostat - correct ?
    Gene
    test
    Sergeant:
  • 311 Answers
Hi geneglass,no rest ,they are built into unit.first fin thermostat and put the two wires together[unit unplug first]then when to gether plug in.the thermo controls run time.if not doing it will need volt meter to check at compresor relay.please help with my ratings if i have been helpful.god bless you,tom
Posted on Jan 02, 2009
  • Thomas Malailua
    Thomas Malailua Jan 02, 2009
    those are simple units[no defrost stuff,fans etc..]youl have to see how to get into that thermo area. or they may make it as a throw away cooler but i dont think so.yes put the thermo wires together with a paper clip or somthing of that nature.dont allow it to touch ground[metal]or you ither .it is the same side off the power the thermo is only a switch not a power consuming part
I have a 5 year old cuisinart 32 bottle wine cooler that I bought at Crate & Barrel. It does not work any longer - worth it to get it repaired and where - I am in Scottsdale AZ
Contact a local appliance repair shop and get an estimate on repair and then make that decision as to if it is worth it to repair, my vote is no.
Oct 25, 2016 | Furniture
Vinotemp wine cooler just stop working.
Ok check the power supply input. Assume you have do e that and all ok. More than likely it could be a thermostat or compressor gas leakage. Has the compressor been running more than usual before it gave up working. Check for rust on the internal coils as sometimes they fail. Depending on what you paid for the wine cooler it may be cheaper to simply replace it. Can highly recommend Delongi 145
litre bar fridge, after replacing several cheaper brands and it is very reliable and cools really well though they are not at the cheap end of the market. You get what you pay for with appliances. Best of luck resolving the problem but if the wine cooler no longer is getting cold but the compressor continues to run, you can bet that it's out if gas from a leak in the internal pipe work and generally not worth attempting to either locate and or repair.
Apr 28, 2014 | VinoTemp (VT60GNV) Wine Cooler
Not colling
Check the back to see if the compressor is running or just really hot. If it is not running it could be a thermostat issue, but if it is hot and not running, that means your compressor has problems and will need to be replaced.
Apr 07, 2014 | Whirlpool 22" Dual Zone 38 Bottle Wine...
Have a Haier 18-bottle wine cooler. In 3 occasions since I bought it I'v needed to unplug it. Every single time I plug it back it will not work. 1rst & 2nd time, fans stopped working, they sounded...
I don't know. It might just be really old? If you bought it like in 2000-2005, it might just be old. You probebly just need to get a new one. Don't feel bad. :3
Dec 16, 2013 | Haier HVW18BSS Wine Cooler
My Hair 12 bottle wine cooler quit cooling. what is the main cause?
Possible bad thermostat. Bypass the thermostat wire to run the compressor. If the compressor start, replace the thermostat. On the other hand if the compressor is running, and there is no cooling; there is a leak and all the refrigerant probably escaped. If it is the case, you need to call serviceman and have him evaluate the wine cooler for possible repairs. P.S. The serviceman may charge a fee for evaluating or estimating the cost of repairs.
Dec 29, 2010 | Haier BC112G Wine Cooler
No power, lights or anything
This is easy. It's the power supply problem. I bet you there is no juice coming out of the same electrical plug. So fix the plug or reset the circuit breaker.
Jul 31, 2009 | Avanti WCR683DZD Stainless Steel Wine...
No power, no cooling, no light
check your outlet with a lamp to see if you have outlet pwr,then chk pwr cord, normally not cord(chk the easy things first!!!!)
Jul 19, 2009 | Emerson (025806803716) Wine Cooler
HAIER WINE COOLER HVW18bss I have this wine cooler and is not cooling anymore I wonder what type of termoelectric module this cooler has and If its worth the fix
GO TO THE LOWER BACK OF COOLER PUT YOUR HAND ON THE COMPRESSORTO SEE IF IT IS RUNNING ,BR CAREFULL IT MIGHT BE HOT,LET ME KNOW AND WE'LL GO FROM THER,MIIKE
Sep 20, 2008 | Refrigerators
Haier BC112G Wine Cooler Logo
324 people viewed this question
Top Haier Furniture Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
jasbo
jasbo
Are you a Haier Furniture Expert? Answer questions, earn points and help others
