Battery on Sony Walkman NWZ-E436F
The player says 'LOW BATTERY - PLEASE CHARGE'
When i plug my player into the computer it connects an charges for 10 seconds then says full.
I then unplug the connection and turn the player on this then gives me the message
This is repeated everytime i try to charge the player.
  • 4 more comments
  • Anonymous Jan 16, 2009
    i have same problem tryed to reset it, that did not work.
  • mamax2bb Feb 27, 2009
    I plug my mp3 player into the computer to charge. When i check it later, it says full battery. I try to use it and when I turn in on it says low battery please charge. That is every time and now I can not use it.
  • Anonymous Apr 02, 2009
    i just got my walkman i finnally got some music on it but now i cant listen to it becuse it says the battery is low so i plug it in it charges for about 4 seconds and them says its full but its not
  • valhallen Apr 24, 2009
    I have the same problem. It used to work fine. I just copied some music on the device, waited untill battery was full and suddenly when i disconnect my mp4 it says "low battery - please charge" .....
    hmmm
  • Anonymous Apr 26, 2009
    NWZ-E436F sony walkman. Battery indicator has one bar. I plugged it into my pc via usb port. The battery indicator reads full. When I unplugged it reads ony one bar. Help.
    same problem :C
Ok, just tried something with maybe a solution....
I was connected via an usb hub to my laptop, then it said battery is full, it apparently didn't charge.
When i connect my usb cable directly to my laptop it started to charge again!!.
My usb hub is not connected to a adapter so all power comes from the USB port, this may be not strong enough to charge your walkman.
Try this (so directly connect to your desk / laptop) it may work!
regards
me
Posted on Apr 24, 2009
Even I had the same issue, I was trying to connect it to my assembled PC, the battery showed full though it was not...connected it to my laptop and it worked like a dream...as valhallen suggested connect the player directly to your PC or Laptop USB, do not use USB extension/Hub...Thanks valhallen
Posted on Aug 01, 2009
  • electric1928 Dec 23, 2010
    Ok, so my walkman (should we now use the non sexist term "walkperson" ?) will charge from the PC. But, I want to charge it from an AC mains driven powered USB hub when I am away from home and I do not have a a laptop. Since my Belkin 4-port hub used to supply all manner of devices, why not charge the walkman? Power rating of the hub is 7.5V, 2.1A. This is sufficient to melt a walkman, So forget all the superstition of low volts, insufficient current, too much resistance in leads. Regards,Ted
I was using a USB extension cable and had the exact same problem. I took out the extension and plugged it directly in. Problem solved. Guess there was too much resistance in the extension cable. Thanks all! jb
Posted on Mar 09, 2010
I am facing some different problem.I have charged my walkman full but when I try to start it, it just display walkman icon for around 3 sec n it gets off. I don't know what is the exact problem.
I have reset it, again charged it to full, still the same issue.
I have also deleted all songs from it...but no luck..:(
can someone please advise........
Posted on May 05, 2013
  • Neha n May 05, 2013
    model is 'Sony walkman NWD B100'
My sony nwz e 436f says that I need to charge it but when I plug it into charge, it says Battery full.
I think you are using a USB-Hub. Connect the player directly to the computers USB port. See the manuel on page 100 (English version)
Nov 20, 2010 | Sony NWZ-E436F MP3 Player
My sony walkman NWZ-E436F is charged but the will
It may be a loose ribbon cable going from battery compartment to main circuit board. THey have tendency to work loose.
Jul 07, 2009 | Sony NWZ-E436F MP3 Player
My sony walkman nwz-e436f was working fine and all the sudden its taking no charge from any usb ports
Check the connector of the USB Ports and Sony. Also it's internal battery require replacement.
Jul 06, 2009 | Sony NWZ-E436F MP3 Player
Cannot charge
SONY NWZ-E436F DIGITAL media player | PROBLEM : my battery was low So i tried charging it by connecting the usb to my computer...it charges for 3-4 seconds till the time it shows do not disconnect the moment it shows connecting it shows the battery sign full.... i tried it again and now it has hung and i try to put it on it just shows every moment has its music...and the battery is still low i believe it doesnt go further
Jun 25, 2009 | Sony Audio Players & Recorders
Battery does not hold charge
Solution// I plugeed it directly into my computer opposed to into the usb hub it was plugged into prior. now, it is charging. Hope this will work for you
Apr 25, 2009 | Sony Walkman NWZ-S616F MP3 Player
Fully charge sony walkman NWZ-E436F does not turn on power at all
well u might have gone wrong u should charge ur walkman for abt 3 hrs first use untill full appears and it is recommended that even if u dont plan to use u r walkman u should atlest charge the battery once a while for battery mentainance try to reset ur update the player firmware.or even then if it dont comes send it to sony or have a converstion with sony support
Jan 31, 2009 | Sony Walkman NWZ-S616F MP3 Player
Sony walkman nwz-s18f froze
I had this problem a few days ago and now my sony nwzs18f has different problems, the way i got it to charge back up was by using a usb charger that plugs into a socket rather than into your computer this should hopfully charge it back up and also it should unfreeze the screen.
hope this helps
Dec 29, 2008 | Sony Walkman Video NWZ-A816 Digital Media...
Frozen screen
you should hit the reset button and that should do the trick and always make sure it's charged
Sep 13, 2008 | Sony NWZ-S616FRED Digital Media Player
3,051 people viewed this question
 Grubhead
Grubhead
