Question about Canon PIXMA iP1600 Printer
New Printer carridge is installed, still not printing?
Says alignment is needed can you tell me how to do that, since I can. not fing the mannuel. It just stopped printing before the cartridge was replaced Help please
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 26, 2009
New Print head installed. It will not align printer
is the paper coming out with the print on it, if so on most all in one printers it needs you to take the paper out and put it in the scanner and press the go button on the screen or the flashing light button on the printer to finish alignment.
Jun 21, 2017 | Office Equipment & Supplies
HP Designjet 500, I have replaced the black print head twice, the first new print head would align and then fail the color calibration, the second new head aligns and pass's color calibration, but when I...
it seems there r some air in ur ink tube *** inser the priming heads & done the priming & reinstall the print heads if problem not resolved replace the carridge assembly,,,,,,,,,
Jun 03, 2010 | HP DesignJet 500ps (42 in.) InkJet Printer
I just installed a new color cartridge in my 8650 Lexmark printer. The ink cartridge acts as if it is empty. Printer keeps telling me to align cargridge. Worked perfectly before the new ink installed. Not...
  1. On your computer, go to "Start," "Programs," "Lexmark Series." Click "Lexmark Control Program."
  2. Step 2 Select the "Cartridges" tab. Click "Change Cartridges." The Change Cartridges screen appears, displaying the animated instructions for installing or changing cartridges. When you have finished viewing the animation, click the "Finished" button.
  3. Step 3 Remove the tape covering the print head of the new print cartridge. Insert the new print cartridge as shown in the animation.
  4. Step 4 When the "Choose Cartridges" screen appears, select the cartridge(s) you installed in your printer from the list boxes. Click the appropriate box to reset the ink levels to full. Click "OK."
  5. Step 5 The Automatic Alignment screen appears. Click "Align" to align the print cartridges for best print quality. The printer prints a page with a bi-directional alignment pattern. On the printed test page, locate the number that comes closest to forming a straight line under the bi-directional alignment pattern. Enter that number as the bi-directional alignment setting in the Alignment Cartridge dialog box. Click "OK."
Nov 25, 2009 | Lexmark All-in-One Printer with PictBridge
I have an HPL7780 Office Jet Pro that is 16 mos old in pristine condition - less than 2,000 pages printed. I am told I have a hardwarefailure. (After replacing printheads twice and all ink cartridges) Reds...
The alignement problem is likely to be a issue with the carridge as well as the print head. Usually after doing all of that you have to look at causes other than the prnt head.
Unfortunetly I would agree that replacement is probably the better option. I'm surprised that they didn't suggest that before the first print head. Usually a replacement print head will cost more than the new printer does. I would suggest that you replace it with a laser all in one. The print and maintenance costs are lower than an inkjet. There are several excellant models available and the cost of these has dropped to probably less than what you paid for your inkjet.
Wish I had a better suggestion but you may end up fixing one part of the problem and still have other issues.
Nov 04, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Printing alignment problem
First thing to try is to remove the power brick (not just the cord the whole brick) from printer for a minute then re insert and try it again. If this doesn't help try uninstalling it then re installing the printer
Aug 20, 2008 | Dell 926 All-In-One InkJet Printer
Left side margin is fading out right side margin is printing correctly
First try to align the printer head either with software or at the printer control panel. If that one couldn't solve the problem then you may have the encoder strip dirty at left side. It is not easy to access the encoder strip, sent it to workshop.
May 12, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
How do you align your printer
goto control panel check add printer and the wizard will guide you.
May 03, 2008 | HP Deskjet D2360 InkJet Printer
Printer is telling me i have alignement problems
Anytime you remove the cartridge the printer wants to align the print head. It doesn't matter whether you used it or not as long as you change/remove and/or install a new or old cartridge, it will ask to align. If you are printing text only and no pictures, then usually alignment is not critical. Though from experience, it is but usually 9 times out of 10 I don't need to re-align. But if you want to print pictures then you must align.
Mar 31, 2008 | HP DeskJet F380 All-In-One Printer
WTF...wheres the solution. Bunch a ****!
Oct 14, 2007 | Lexmark X2470 All-In-One InkJet Printer
Streaks / Bands of broken print area
First with a clean soft cloth and a very small amt of alcohol clean off the underside of the printer carridge (the holder for the print heads) also where the print heads cleaning station is clean out any large masses of congealed link. Then remove the ink cartridge in question and with a pencil eraser gently rub the contacts and both the cartridge and the carridge replace the cartridge. Using the software tools for the printer clean and align the printheads ( if there is an option to do so). If this dosn't fix the problem try a different ink cartridge.
Sep 04, 2007 | HP OfficeJet Pro k550 Printer
Canon PIXMA iP1600 Printer Logo
21 people viewed this question
old marine
old marine
