Question about HP Office Equipment & Supplies
I have a HP Officejet 6310 All in One printer. It's stuck. It continuously repeats the same page over and over again. It tries to go to the next page but printer stops. I've cleared it, restarted it, Reset it, turned it off, and unplugged it. when turned back on, it does the same thing. over and over.
  • 4 more comments
  • norman_higgi Jan 02, 2009
    Sulation did not work. was a waste of good money. still won't stop printing repeat pages.
    office jet printer still will not work. Keeps reprinting same page over and over.
    I hate to be a dummy but I use the linux system with firefos beta 5 as a search engine. Where do I find the control panel.
    nothing seems to work. where can I find the control panel?.
    Thanks. that seemed to work. really appreciate the help.
    Genius:
  • 1,199 Answers
If you have the software re=download it and try again! It sounds like it may be currupted!
Posted on Jan 02, 2009
    Brigadier General:
  • 8,619 Answers
Hi! Open Control Panel and open printer & faxes options, now double click on your default printer and delete all the pending tasks(if any) in printing queue. And, then hard reset your printer by following way-
Unplug the printer from power. And then wait for about 1 min for the power to be totally drained out of the printer. And then press and hold onto # and 3 buttons on the number pad on the printer and then plug in the power cable while keep on pressing the # and 3 buttons. Now wait till a message comes up on the printer display. Normally this will come up with Language selection.
Now Check For Page Settings.
To reprogram service menu you can do the following-
While the printer is fully powered on and it is in standby mode. press * and # button together. This will show a message on the display of the printer similar to this "********########" . once you get this message key in the following number in sequence using the number pad 329. Once you done that a message will come on the display saying "Service" and a number. Now using the arrow buttons browse through the menu options.
  • HP Master
  • 19,396 Answers
CAlso ensure that the printer cue is empty. You access the printer cue from Control Panel>> Installed printer.
    Novelist:
  • 163 Answers
K...
try the blow link to know how to stop repeating page --
http://www.dwfaq.com/Tutorials/Dynamic/MultipleRepeatRegion2.asp
    President:
  • 2,110 Answers
Goto command prompt and typr net stop spooler
and type spool in RUN
delete the contains of printer folder..
and again in command prompt type net start spooler
  • 837 Answers
Is the printer connected via a network or USB directly to your PC?
  • 1 more comment
  • Jay Glendenning
    Jay Glendenning Jan 02, 2009
    lpstat
    that will show you a list of print job(s)
    example :
    $ lpstat
    laserjet-25 .... .... other stuff
    $ cancel 25
    Should do it .. obviously change it for whatever your result is
  • Jay Glendenning
    $ cancel -a
    will rid you of all the jobs in your linux print queue
  • Jay Glendenning
    You are using linux .. there isn't a contol panel .. get to a command prompt and use my instructions above.
    Genius:
  • 1,239 Answers
HI I THINK IT IS THE CATRIDGE PROBLEM CLEAN THE CATRIDGES FOR 4 OR 5 TIMES.....SEE NOW IF IT IS CONTINUING CHANGE CATRIDGES
  • ABHISHEK.C
    ABHISHEK.C Jan 02, 2009
    Open control panel then open administrative tools, click on services.
    in services right click on print spooler and click stop, now you navigate to this folder "C:you want to delete the files in the PRINTERS folder, they are the print jobs waiting to be printed, after you delete them return the print spooler to a running state in services and try to use the printer again.
    WARNING only delete the files in the printers folder.
    DON'T GO TO PRINTERS AND FAXES AND REMOVE YOUR PRINTER OR TRY REINSTALLING IT, BIG WASTE OF TIME AND IT MAY NOT HELP.
    this works for me every time, and it only takes a minute.
    it truly is the quickest way to remove a print job gone bad.
    my wireless print server sometimes skips a beat then gets stuck trying to print pages of random junk forever and i have to do this to clear it off, then its good as new afterwords again.
    here is a link to some advice called I have something stuck in my print queue.
    http://www.able2know.com/forums/about478...
    good luck
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, pls Cancel the print job from your computer. Goto Printers (& Faxes) in the Control Panel, right click on HP Officejet 6310 and "Cancel All Print Jobs". Alternately, double click on the printer icon in the Sytems Tray and delete all pending print jobs. Reboot your computer.
Good luck and Thank you for using FixYa. Happy New Year.
  • HP Master
  • 13,433 Answers
Unplug the printer from the computer usb.
do a semi full reset 1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord. Continue holding until it displays Semi Full Reset message in the front panel of the All in one
plug the usb back to the computer ones it is turned on and not printing.
Is the printer working normally?
  • Ekse Jan 02, 2009
    Will it not stop printing when you unplug the usb? you have something in the printing queue and the computer seems to be sending the documents to the printer again.
  • Ekse Jan 02, 2009
    -unplug the usb
    -unplug the power from the printer
    -perform the semi full reset
    -turn the printer off and then on normally
    has the printer stoped printing? Does the printer stop printing if you just unplug it and then cut the power for a minute.
Paper jam message no paper jam cartridge gets stuck HP 6310 all in one
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Jan 11, 2010 | HP Officejet 6310 All-In-One InkJet...
HP 6310 print problem-prints first 10 lines OK then next 10 are on a new page etc. Re-booting PC fixes problem.
Please check the Page selecton
check the page setup click on file -click on pagesetup
Press Ctrl+P
Check the layout settings
Check print priver if print privew is ok then its software issue
Check the printer drivers
DRIVERS HP Officejet 6310 All-in-One Printer
Jan 05, 2010 | HP OfficeJet 6310 All-in-One Printer...
How do i scan pictures to my computer on my HP Officejet 6310
Here is a link to the user manual for your 6310. Download it free from HP. The steps to scan pictures start on page 86. Good luck!
http://h10032.www1.hp.com/ctg/Manual/c00633922.pdf
Sep 05, 2009 | HP OfficeJet 6310 All-in-One Printer...
I need to install my new HP Officejet 6310 and set it as the default printer . I don't have a Installation CD Rom
STEPS FOR INSTALLING THE HP OFFICEJET 6310 PRINTER WITHOUT CD-Rom
STEP 1: In your computer window click the Start button and select the option Devices and Printers.
STEP 2: A new menu Devices and Printers appear on the screen. Then click the option Add a printer.
STEP 3: After clicking the Add a Printer option two options appears on the screen.
Add a local printer
Add a network & wireless or Bluetooth printer.
Select the option that suits to your printer
STEP 4: If your printer is not a wireless then select the Add a local printer and select the option Use an existing port then click next.
STEP 5: Scroll down to select the HP in the manufacturer section.
STEP 6: Select your Hp printer model in the printer section then click next.
STEP 7: If your model number is not present then click the windows update it will automatically add your printer model.
Note: You must need internet connection to update the printer model to your computer.
STEP 8: Then click next and finish.
STEPS FOR INSTALLING THE HP OFFICEJET 6310 PRINTER FOR WIRELESS CONNECTION:
Add a local printer
STEP 4: Select the option Add a network, wireless or Bluetooth printer and click your printer name and address.
STEP 5: After the HP officejet 6310 printer installation of your wireless printer next step is to add your printer name and click next.
STEP 6: Set default printer as your HP Officejet 6310 printer and select the option print a test page.
STEP 7: A new popup window appears on the screen, then close it and finish.
Jun 11, 2009 | HP Officejet 6310 All-In-One InkJet...
Hp 6310 show offline wont print
Hi, how do you connect to the printer? USB/parallel/Network? Does it prints fine if you print an information page from the printer display/butons? I would try to uninstall the printer driver and install it again to start. It's definately a communication problem so it may take a few tries to get it to work again.
Jun 03, 2009 | HP Officejet 6310 All-In-One InkJet...
Half page is stuck in HP 6310 All-in-one Printer. I can't see it
CLICK HERE for a step by Step details to clear a paper Jam in the 6310 All-In-One.
CLICK HERE for your User manual in PDF Format.
Thanks for using FixYa - If you need further clarification, please reply to me first before moving on to another expert.
Thank You!!
Apr 10, 2009 | HP Officejet 6310 All-In-One InkJet...
Unable to print on my computer
Hello sir,
you go on HP Officejet 6310 All-in-One printer, double click on it, a small window will appear, delete all recent commands
if problem not solve then turn off your pc and printer both and unplug the U.S.B cable, now turn on the pc and delete HP Officejet 6310 All-in-One driver and restart pc then install the driver manually again and print your documents again.
thanks
Jan 14, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Bad print outs.
You could try putting your printer through a few cleans and calibrations. If this doesnt work try changing the ink cartridges, as one may have a damaged printhead
Jan 03, 2009 | HP Officejet 6310 All-In-One InkJet...
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
