Question about Acer Computers & Internet
Acer laptop charging cable connection
The little pin inside the connection point for the cable has come out and needs replacing where is the best place to go?
  • 24 Answers
Acer Aspire 6930 charge port problems
The DC jack in the laptop may need to be replaced, go to www.ebay.com Type: make and model of laptop, refine search to DC jack or scroll through the list. The laptop must be completely dismantled down to the motherboard and removed from bottom base, soldering equipment a must with the skills to use it, suggest a computer repair shop.
May 13, 2012 | Acer Aspire 6930-6455 Notebook PC
My Acer aspire aoa 150 will not charge. Its not the charger or battery It seems to be that little thing inside the computer that transfers it. Any idea as to how i may be able to fix that?
Hello.
If you wiggle the cable where it connects to the laptop and the power goes on and off, the power jack (inside the laptop) needs repair or replacement.
Hope this helps.
Aug 18, 2010 | Acer Aspire One AOA150-1570 Notebook PC
Hi i am having troubl with my power cord to where i have to wiggle it around to charge my laptop what does that mean
The problem could in one of 2 places.
1st: check the adapter on the laptop itself. This part gets very hot causing dry solder points and also the pin can become loose. Check that.
2nd: get a multimeter and check the voltage output on the end as in most cases the wire inside the cord breaks causing a loss of connection thus not powering the laptop up.
If you have to wiggle the wire when its plugged in to the laptop the best place to start is at the laptop adapter.
Good luck.
Jun 28, 2010 | Acer Aspire 4520-5582 Notebook
Acer 5920-6864 ac plug only works when pulled to 1 side
Either the center pin on the dc plug or the small tension band inside the DC jack is loosing its spring, this spring action is what holds tension on the shaft of the pluug. The center pin that conducts the positive charge tends to break its solder point and therfore the chrge unless it is manipulated, the jack at this point needs to be replaced.
Sep 27, 2009 | Acer Computers & Internet
Charger is no longer working
Oh, believe it or not. My computer use to do the same thing all the time. Just take the prongs on the plugin and bend them outwards slowly. This will make a tighter fit in the outlet.
Jun 11, 2009 | Acer Aspire 7720-4428 Notebook PC
Wont charge
No there isn't, the laptop need this adapter to charge the battery and monitors the charge state. You need to get this connector repaired.
Apr 27, 2009 | Acer Aspire 3100-1405 Notebook
Acer Aspire won't start
make sure the plug is completely secure into the back of the laptop.. i also have an acer aspire..
maybe someone spilled their drink on it...
..idk..
Jul 30, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
No power,not charging
It is most likely that there was nothing wrong with the original adapter/charger. What I suspect is there could very well be a loose connection more aptly a cold solder among the pins of the power jack that is soldered to the motherboard. Normally, this jack would have two (2) pins and your description "...unless the cord was in a certain position..." indicates that one or both pins are not connecting right to the motherboard solder points.
It is relatively easy to resolder the said pins. What would be more challenging would be opening the laptop and exposing the motherboard's to be able to do solder work underneath.
Should you venture a DIY, then you would be needing a set of jeweler's screwdrivers and a soldering iron and a little lead. Should you be uncomfortable and unfamiliar with electronic works, perhaps your best bet would be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 11, 2008 | Acer Aspire 3680 Laptop
Acer 3690
Once you get the pin repaired be sure and use some sort of cable stay or restraint so it doesn't happen again. . .
Here's something I recommend. . .
Mar 20, 2008 | Acer Aspire 3690-2196 Notebook
Computers & Internet Logo
37 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
