Question about Porter Cable 7336 6 Inch Variable Speed Random Orbit Sander Only
Porter Cable 7336 polisher - pad/backer plate will not begin to start without starting it by hand. Will changinging the brushes fix it?
    Problem Solver:
  • 9 Answers
The first thing to do is to make sure the unit is completely clean. Many of the contaminates that get airborne while you are sanding can and will affect the motor's performance with time. Pay particular attention to the brushes/commutator or any kind of centrifugal switch it may have.
Posted on Jan 02, 2009
How do I remove the rotating disk on a porter cable polisher model 7336
You have to use a wrench behind the disk for a stop and then unscrew from the housing Porter Cable
Feb 23, 2013 | Porter Cable Porter-Cable Variable Speed...
Installing brushes in porter cable 7336
Go on line to porter cable customer service ask for a blow out of the motor of your 7336 assembly 6 inch variable speed sander they will have the parts blow up showing each part with a line going into each area where the parts fit together Good luck
Aug 26, 2012 | Porter Cable 7336 6 Inch Variable Speed...
How to change pad?
this is easy done, just follow the steps:
1. disconnect the power cord
2. turn polisher pad up
3, grip firmly randomiser in one hand (that is this bulky bit between pad and polisher)
4. grip pad and rotate it against arrow direction.
if you just need to change the abrasive, these are on hook and loop and you just lift it from the pad and replace with new one.
this action will separate pad from randomiser, if you need to remove randomiser as well, you will need spanner of appriopriate size or adjustable.
you have manual available for download on this site:
http://powertool.manualsonline.com/manuals/mfg/portercable/7335_7336_7336sp_7355_7366_7424.html
if you find my advice useful, please do not hesitate to leave a comment and vote4 for me, thanx!
Aug 01, 2010 | Porter Cable 7336 6 Inch Variable Speed...
I have the porter cable 7424 buffer/polisher. My problem is when you apply any pressure, even the weight of only the buffer on the car it stops spinning. You have to hold it up slightly lifting the we
The armiture has a winding problem, common in a lot of power tools. Replacing the armiture is not cost affective unless your time put into it is worth it, sorry. I recomend the Dewalt veriable speed, nice professional buffer!
May 07, 2009 | Porter Cable 7336 6 Inch Variable Speed...
Porter cable beffer
Check for string or build ups where the spindle come out of the housing, a little light oil at that point will help, 3-in 0ne is good, not to much, a little goes a long way
Jan 02, 2009 | Porter Cable 7336 6 Inch Variable Speed...
7336 orbital sander
If you are talking about the actual sanding pad itself it should just pull of .If you are talking about the backing pad it should un screw
Sep 10, 2008 | Porter Cable 7336 6 Inch Variable Speed...
Porter Cable 7336 6 Inch Variable Speed Random Orbit Sander Only Logo
258 people viewed this question
Top Porter Cable Tools & Hardware - Others Experts
John Trevino
T bone 1963
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
