Question about Numark TTX1 Turntable
Numark ttx with variable torque, platter turns slowly, weak torqu
I have a numark ttx with variable torque, platter turns slowly, weak torque, if platter builds up speed a finger touch to platter can stop it. stop button sometimes doesnt instantly stop the platter. do you know what can be replaced and estimate cost? thanks
  • 515 Answers
More than likely one of the Drive IC's has failed, and needs to be replaced.
- OPTiC
Numark Repair Videos
Numark DJ Repair
DJ Equipment Sales
Numark Parts
Posted on Jan 17, 2009
HOW DO I ADJUST THE TORQUE ON MY NUMARK TTX TURNTABLE?
If i may ask, do you need extra torque above the stock one, which can be done or don't you know how to adjust the torque on a standard table and which torque do you want to increase, the start torque, which is the nonsense eveybody talks about, but your standard drive torque is way lower and why do you want it higher. Not to scratch, there's the standard torque high enough for. Or you have a cheap plattermat with way to high resistance, but as high as a vestax you won't get it. The ttx is nice...... i would spend money get rid of the space on the tonearm and cheap capacitors replacement in the unit, cause they ain't made for a constant higher current.
Aug 02, 2014 | Numark Audio Players & Recorders
Numark ttx/ttx1 pitch fader wonky
Try spraying the slider with Servisol Video 40.
Mar 15, 2013 | Numark TTX1 Turntable
Numark TTX-1 turntable starts slow but then is okay.
A drop or two of light oil at the center of the spindle will surely solve the problem.Remove the platter and check if its clean
Jul 06, 2009 | Numark TTX Turntable
Numark tt200 motor
The knocking sound is NOT normal, and you should not ignore it.
The tt200 is a HIGH TORQUE turntable, and as such is a highly accurate lathe for the accurately determined speed of the platter.
The lathe is in need of adjustment, which is recommended.
Apr 06, 2009 | Numark TT200 Turntable
Numark ttx wont spin
some tables require the tonearm to be over the record area before the patter starts to spin. If thats not it, have you tried "jump starting" the platter with your finger? the direct drive "stepper" motor might be confused as to where it is at the moment. and finally remove power from the wall for a few minutes then retry.
Feb 09, 2009 | Numark TTX Turntable
How do I remove the Numark TTX platter
Nope, nothing to it. The platter is just held down by gravity. Take a mallet or a piece of 2x4 block, and give the spindle a little whack. Not too hard, just enough to break the hold.
- OPTiC
Numark DJ Repair
DJ Equipment Sales
Numark Parts
Jan 04, 2009 | Numark TTX1 Turntable
Numark ttx turntable
More than likely the drive IC (integrated circuit) has shorted, and needs to be replaced. Not an easy fix, and you'll have to take it to a service center for replacement.
This is a common problem on this turntable.
- OPTiC
Turntable Repair Expert
Digital Analog Therapy
Nov 14, 2008 | Numark TTX1 Turntable
Numark TTX1 Turntable Problem-Platter stops
This is a drive issue. Unfortunately the TTX direct drive system isn't the greatest. It's good, but it's no Technics 1200. The only way to 'fix' this issue is to have a professional look at main circuit board to see if there are any components which are burned, or damaged in any way.
Hope this helps some.
- OPTiC.
www.djprolab.com
Nov 04, 2008 | Numark TTX1 Turntable
Numark cdx
have you checked the brake and start up settings they are the dials by the start and stop buttons it it is turned too far the platter will start up slow, you just trun to dial till you get the right start up speed you want
Jul 25, 2008 | Nu Mark Numark Cdx Table Top CD Player CD...
Numark TTX1 Turntable Logo
593 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
