Question about Frigidaire 24 in. FDB1050RE Built-in Dishwasher
Flashing "Washing" light on my frigidaire 1000 series dishwasher
I just worked the other day now when I press the start/cancel button to start the dishwasher all it does is flash the "washing" light...no water is coming into the unit. I've tried the breakers in the house, no luck. The unit is just over one year old...Any ideas? Thanks
  • 11 more comments
  • Jmun Jan 03, 2009
    I'm having the same problem. The wash light comes on and starts blinking, but the water doesn't come on.
  • nurse5 Jan 07, 2009
    I have the same problem mine worked yesturday jan 5-09 but today just the light is blinking and no water will run. Amy
  • Jmun Jan 07, 2009
    I just had someone come look at my dishwasher (flashing light, won't run). It will cost $250 to replace the controls. It is only 2 years old! I might as well buy a new one for what it will cost me.
  • Anonymous Jan 07, 2009
    Same problem here, my FDB1050RES won't start and the "washing" light keeps flashing. Luckily I have 1 day left on my factory warranty. I've had 3 new Frigidaire appliances do this, fall to **** just about at the end or after the end of the warranty. Last Frigidaire piece of **** I buy - don't make 'em like they used to.
  • Anonymous Feb 11, 2009
    Looking for the solution to this problem also. It just started out of the blue.
  • Anonymous Mar 28, 2009
    wash light comes on blinking and will not start.
  • reneeandbill May 17, 2009
    I have the same problem with the same model, just started today and it has worked for the past 2.5 years. Anyone got a good answer yet, or do we just need to buy a new machine?
  • Anonymous May 20, 2009
    light flashes when it is supposed to be washing
  • Nancy Jones Jan 20, 2012
    I had the same problem. Followed the suggestion below and it worked. If looking at the picture below please take note that you have to pry the black tab out a bit to be able to pull the connector out. I had called Frigidaire first and they were unable to help me. Told me I needed to call a repair man.
  • mark Mar 05, 2012
    awesome soloution below .. thanks so much
  • mark Mar 05, 2012
    awesome soloution below .. thanks for the the problem and the detailed resoloution
  • Jim MacGuire May 23, 2012
    great fix, hardly any work involved. thanks!
    Jim M-Washington
  • marthashephe
    marthashephe Jan 27, 2013
    THANK YOU!!! This worked for me..... :-)
Possible solution. I had the same problem of "washing" light flashing last year and now today. Warranty has been expired for awhile, so no harm in trying. What worked for my situation was removing the six screws for the back of the plastic control cover. Take of the plastic cover. There are are two connectors to the HANDLE with white and black wires. To be safe I would shut off the ciruit to the dishwasher. Safety first. Carefully disconnect and inspect the contacts inside the connectors. Do not insert any metal objects if you left the power on. I believe that the moisture from the dishwasher can degrade the connectivity. I cleaned the contacts with q-tips and re-installed. Be careful to not bend the contacts. If you had sound, you could hear my dishwasher running. Total cost is about three cents. I believe that the connectors do not full close when corroded, which prevents the completion of the circuit to the controlls. The flashing light indicates that the door is open, when in fact it is closed. Hopefully this will help someone. Semper Fi
Posted on Feb 06, 2010
  • 5 more comments
  • lquinn7 Sep 19, 2010
    Thank you - this worked! My dishwasher is now running again.
  • southkormp Dec 29, 2010
    thank you thank you!!! this worked great.
  • rinkor Dec 29, 2010
    Thank you SOOOO much. I did everything step-by-step as you have it listed and it works perfectly now. The only thing I couldn't figure out was how to disconnect the black and white cables to clean the connectors but sure enough somebody posted pictures of it a few hours ago. Thanks again!
  • charmeyer Feb 10, 2011
    Thank you sooo much my dishwasher is less than 3 yrs old and I didn't expect to have troubles with it just yet, but my washing light was flashing and I thought that I was going to have to have to come up with money that I didn't have, but because of this post my dishwasher is working. It was easy to do and took all of three minutes and a couple of Q-tips. Thanks for sharing I really appreciate it.
  • jbeyers52 Mar 07, 2011
    Thank you very much -- my door locking mechanism has akways been a little awkward and I must have been loosening the connectioin for a while. I removed the power, pushed the tab up a bit and the unit is working great.
  • Edward barth
    Edward barth Mar 25, 2014
    Oh man! I am soooo happy right now!! No Name 2 - I could kiss you wherever you are!!!
  • Ruben Chan
    Ruben Chan Mar 04, 2017
    Thank you so much, this fix worked perfectly! I used a bit of nail polish remover and a q-tip to clean out the contacts.
No name 2's solution worked great for us so far. It took me while to figure out how to disconnect the two connectors, so I thought some pictures might help.Flashing _12.png
Posted on Dec 29, 2010
  • 4 more comments
    Thanks for posting pictures of how to disconnect the black and white cable connectors. I printed off no name 2's instructions last night and could figure everything out but that part. I was scared I would break something off permanentely. Fortunately I was able to clean the connectors off enough without removing them that the dishwasher works again. I came on here to thank him and, sure enough, you posted pictures of it last night. I'm glad i saw them in case I have to do this again. Thanks again for posting the pictures!
  • Steve Deramee
    Steve Deramee Sep 01, 2012
    thanks for the pictures....couldn't have done it without them. I was trying to clean the 2 black and 2 white connectors
  • dallesmith10
    dallesmith10 Nov 22, 2012
    Thank you so much I would not have been able to clean the connections without the pics.
  • Leigh Ann Gosney
    Leigh Ann Gosney Nov 04, 2013
    VERY helpful! Thank you for posting the pictures, I wouldn't have known how to take the connectors off without them. The dishwasher is alive again!!
  • Robb Schuster
    Robb Schuster Feb 01, 2014
    My switch was broken so I bypassed it with a jumper. My washer is too old to repair the switch so I bypassed it untill I can buy a new washer. Use two slide in connectors with the same size jumper wire. If you cannot get the right connectors then you can use twist on wire nuts. Dont do this untill you have tried to clean the contacts first.
  • Edward barth
    Thanks to Southkormp as well! Took a little bit of patience but your pictures were very helpfull
    New Friend:
Worked for us too! Thanks for the pictures!
Posted on Mar 06, 2013
    New Friend:
This totally works! I didn't even have to clean the connections, just tighten them. Thank you.
Posted on Dec 19, 2012
Zanussi dishwasher ZDF601M 1 in 3 red light comes on and programme doesn't work through
26269906-aipk5px1bmfkdpsmrgevaqwn-3-0.jpg "3 in 1" function
This appliance is equipped with the "3 in 1" function, that
allows the use of the "3 in 1" combi detergent tablets.
This function can be selected with all washing programmes.
With the selection of this function the inflow of rinse aid and
salt from each respective supply container is automatically
deactivated and also the indicator lights for salt and rinse aid
are deactivated.
Select the "3 in 1" function before the set of a washing
programme.
Once this option is selected (indicator light illuminated) it will
remain active also for the following washing programmes.
With the use of the "3 in 1" function, the cycle durations may
change. In this case, in the digital display, the indication of the
running time of the programme is automatically updated.
NOTE: Once the programme is running, the "3 in 1" function
can NO longer be changed. If you want to exclude the "3 in 1"
function you have to cancel the programme setting (see
chapter "Starting a washing programme" - "Cancel a washing
programme in progress") and then deactivate the "3 in 1"
function.
In this case you have to set a washing programme (and
options) again.
Activation/deactivation of the "3 in 1" function
(The dishwasher must be switched off)
1. Press the On/Off button. The On/Off indicator light
illuminates (setting mode).If a programme button indicator light is on, this means that a washing programme is set. The programme must be cancelled: press simultaneously function buttons 2 and 3
for about 2 seconds. All the indicator lights will turn off (except for the On/Off indicator light and eventually salt and rinse aid indicator lights) indicating that the set programme has been cancelled and the machine is now in setting mode.
2. Press simultaneously function buttons 2 and 3, until the
indicator lights of function buttons 1, 2, 3 and 4 start
flashing.
3. Press function button 4, the indicator lights of function
buttons 1, 2 and 3 turn off while the indicator light of function
button 4 goes on flashing.
4. Press function button 4 again, the "3 in 1" indicator light
illuminates, indicating that the "3 in 1" function is active.
To deactivate the function press function button 4 again, the
indicator light turns off.
5. To memorise the operation, switch off the dishwasher by
pressing the On/Off button or wait about 60 seconds after
which the dishwasher will automatically return to setting
mode.
Dado
Aug 29, 2016 | Zanussi Dishwashers
Kenmore elite dishwasher model 630 Smart Wash light is flashing
You may want to try:
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test.
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel.
Check to make sure that there's no standing water in the bottom of your dishwasher. Standing water in your dishwasher may indicate that your dishwasher has stopped mid-cycle. You will need to press the "Cancel/Drain" button before you can reset your dishwasher control panel.
Dec 18, 2013 | Dishwashers
GE dishwasher with tactile board. Worked fine until special fingers caused issue? Now only the CANCEL and timer light-up when CANCEL pressed. Pump runs to drain for 2 minutes. Stops. NOTHING. Dont see...
This should help: PDW8000 series: press the resetbutton once. This will cancel the washing cycle and pump the water out of themachine. PDW9000 series: open the door aninch and wait for the machine to stop. Touch the reset button to cancel thewashing cycle and reboot the panel.
According to the GE Owner's Manual for the PDW9000 series only: If the"start/reset" light is flashing, close the door until the water pumpsout (this takes approximately 2 minutes) and the light stops flashing. When thelight stops flashing, the dishwasher can be reprogrammed and restarted. If the machine is unresponsive, killthe power to the machine by turning it off on the wall switch (if applicable)or turning the circuit breaker off. Leave the power off for 30 seconds,then turn the power back on. If thatdoes not work here is the repair info: Get into the service mode by pressingkeypads #8 and #4 for 3 seconds. Then reset from service mode. LINK to SCHEMATIC
Mar 28, 2011 | Dishwashers
My frigidaire dishwasher model #fghd2433kf1
It is in a delay wash mode.
Disconnect power for 60 seconds.
Re-connect power.
Press the Cancel button.
Press the regular wash cycle and start the dw.
Jul 17, 2010 | Frigidaire Dishwashers
Dishwasher wont start, light are flashing
should indicate that a power failure has occurred try pushing start cancel then reset options and re start
Feb 12, 2009 | Electrolux Frigidaire Professional Series...
Frigidaire PLD4460REC Dishwasher will not start
This is very likely due to a bad main electronic control board but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance. If possible use the meter and the wiring diagram to check input/output voltages looking for discrepancies between the diagram and the actual meter readings.
Go here for Frigidaire Dishwasher Parts: http://www.repairclinic.com/Frigidaire-Dishwasher-Parts
www.RepairClinic.com
Feb 03, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Flashing Power Failure Light on Frigidaire Diswasher Model # FD989GFC2
I have a Frigidaire that does the same thing. I was able to push the start cancel button then select a cycle and press the start button, shut the door and presto it worked.
Oct 17, 2008 | Frigidaire 24 in. GLD2162RDC Stainless...
All the lights are flashing on Maytag Quiet Series 300
Try pressing heated wash, heated dry, then heated wash, heated dry. It should reset it. Also try pressing and holding the cancel button for 5 seconds to see if that works if the other doesnt.
Sep 23, 2007 | Maytag 24 in. MDB5651A Built-in Dishwasher
Frigidaire 24 in. FDB1050RE Built-in Dishwasher Logo
3,014 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
